Whac a Mole
Kit purchase
../_images/ultimate_sensor_kit.png
Includes Arduino board
PURCHASE LINK
Elite Explorer Kit
Arduino Uno R4 WiFi
3 in 1 Ultimate Starter Kit
Arduino Uno R4 Minima
Course Introduction
In this lesson, we’ll build a Whac-A-Mole game using LEDs, buttons, an LCD display, and a buzzer, where players hit lit targets to score points before time runs out.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino UNO R4 Minima
USB Type-C cable
Wires
Several
Passive Buzzer
Button
LED
220Ω resistor
I2C LCD 1602
../_images/whac_a_mole_bb.png
Common Connections:
  • I2C LCD 1602
    • SDA: Connect to A4 on the Arduino.
    • SCL: Connect to A5 on the Arduino.
  • LEDS
    • Blue: Connect the LED anode to 7 on the Arduino, and the cathode to a 220Ω resistor, then to the negative power bus on the breadboard.
    • Green: Connect the LED anode to 9 on the Arduino, and the cathode to a 220Ω resistor, then to the negative power bus on the breadboard.
    • Yellow: Connect the LED anode to 5 on the Arduino , and the cathode to a 220Ω resistor, then to the negative power bus on the breadboard.
    • Red: Connect the LED anode to 11 on the Arduino, and the cathode to a 220Ω resistor, then to the negative power bus on the breadboard.
  • Passive Buzzer
    • +: Connect to 3 on the Arduino.
    • -: Connect to breadboard’s negative power bus.
  • Buttons
    • Blue Button: Connect to the negative power bus on the breadboard, and the other end to 6 on the Arduino board.
    • Green Button: Connect to the negative power bus on the breadboard, and the other end to 8 on the Arduino board.
    • Yellow Button: Connect to the negative power bus on the breadboard, and the other end to 4 on the Arduino board.
    • Red Button: Connect to the negative power bus on the breadboard, and the other end to 10 on the Arduino board.
Writing the Code
  • To install the library, use the Arduino Library Manager and search for LiquidCrystal I2C and install it.
  • Don’t forget to select the board(Arduino UNO R4 Minima) and the correct port before clicking the Upload button.
#include <Wire.h>
#define BUZZER_PIN 3
#define NUM_HOLES 4
#define GAME_DURATION 30000  // 30 seconds
// Updated pin mapping
const int ledPins[NUM_HOLES] = {5, 7, 9, 11};
const int btnPins[NUM_HOLES] = {4, 6, 8, 10};
LiquidCrystal_I2C lcd(0x27, 16, 2);
bool gameRunning = false;
int score = 0;
int hits = 0;
unsigned long gameStartTime;
unsigned long lastMoleTime = 0;
unsigned long lastLcdUpdate = 0;
unsigned long moleInterval = 1000; // initial spawn interval
bool activeMoles[NUM_HOLES];
  for (int i = 0; i < NUM_HOLES; i++) {
    pinMode(ledPins[i], OUTPUT);
    pinMode(btnPins[i], INPUT_PULLUP);
  pinMode(BUZZER_PIN, OUTPUT);
  lcd.init();
  lcd.backlight();
  showStartMessage();
  if (!gameRunning) {
    if (digitalRead(btnPins[0]) == LOW) { // long press to start
      delay(500);
      if (digitalRead(btnPins[0]) == LOW) startGame();
  } else {
    unsigned long now = millis();
    unsigned long elapsed = now - gameStartTime;
    // spawn moles
    if (now - lastMoleTime > moleInterval) {
      spawnMoles();
    // check hits
    checkHit();
    // difficulty scaling
    if (elapsed > 20000) moleInterval = 400;
    else if (elapsed > 10000) moleInterval = 600;
    // update LCD every 200ms
    if (now - lastLcdUpdate > 200) {
      updateGameLCD(elapsed);
      lastLcdUpdate = now;
    // game end
    if (elapsed > GAME_DURATION) {
      endGame();
void showStartMessage() {
  lcd.clear();
  lcd.setCursor(0, 0);
  lcd.print("Hold Btn1");
  lcd.setCursor(0, 1);
  lcd.print("to start game");
void startGame() {
  gameRunning = true;
  score = 0;
  hits = 0;
  gameStartTime = millis();
  clearAllMoles();
  lcd.clear();
  lcd.print("Game Started!");
  delay(1000);
  lcd.clear();
void updateGameLCD(unsigned long elapsed) {
  int timeLeft = (GAME_DURATION - elapsed) / 1000;
  lcd.print("Score:");
  lcd.print(score);
  lcd.print("    ");
  lcd.print("Time:");
  lcd.print(timeLeft);
  lcd.print("s   ");
void spawnMoles() {
  clearAllMoles();
  int numMoles = random(1, 3); // 1 or 2 moles
  if (millis() - gameStartTime > 20000) numMoles = random(2, 4); // late game more moles
  for (int i = 0; i < numMoles; i++) {
    int hole;
    do {
      hole = random(NUM_HOLES);
    } while (activeMoles[hole]);
    activeMoles[hole] = true;
    digitalWrite(ledPins[hole], HIGH);
  lastMoleTime = millis();
void clearAllMoles() {
    activeMoles[i] = false;
    digitalWrite(ledPins[i], LOW);
void checkHit() {
    if (digitalRead(btnPins[i]) == LOW) {
      delay(20); // debounce
      if (activeMoles[i]) {
        score += 10;
        hits++;
        tone(BUZZER_PIN, 1500, 100);
      } else {
        score -= 5;
        tone(BUZZER_PIN, 500, 100);
      delay(150);
void endGame() {
  clearAllMoles();
  lcd.clear();
  lcd.print(score);
  lcd.print("Hits:");
  lcd.print(hits);
  tone(BUZZER_PIN, 1000, 300);
  delay(300);
  tone(BUZZER_PIN, 1500, 300);
  delay(300);
  noTone(BUZZER_PIN);
  delay(3000);
  showStartMessage();
