Mini Fan 1.0
👉 Need faster updates or support? Click [here] join our Facebook community
👉 Or join our WhatsApp group: Click [here]
🎁 Looking for parts?Check out our all-in-one kits below — packed with components, beginner-friendly guides, and tons of fun.
Includes Arduino board |
PURCHASE LINK |
Elite Explorer Kit |
Arduino Uno R4 WiFi |
Universal Maker Sensor Kit |
3 in 1 Ultimate Starter Kit |
Arduino Uno R3 |
Course Introduction
This Arduino project controls a DC motor using a TA6586 motor driver and three push buttons. The blue button runs the motor at full speed in reverse, the yellow button runs it at half speed in reverse, and the red button stops the motor. The system uses PWM control to adjust speed and responds immediately to button input.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R4 Minima/Arduino UNO R4 WIFI |
USB Cable |
Breadboard |
Wires |
Several |
DC Motor |
TA6586 - Motor Driver Chip |
7 |
Button |
7 |
Power Module |
Common Connections:
BI: Connect to 6 on the Arduino.
FI: Connect to 5 on the Arduino.
DC Motor
GND: Connect to TA6586 B0.
VCC: Connect to TA6586 F0.
Button1
Connect to 9 on the Arduino.
Button2
Connect to 10 on the Arduino.
Button3
Connect to 11 on the Arduino.
Writing the Code
Don’t forget to select the board(Arduino UNO R4) and the correct port before clicking the Upload button.
// Control a motor using TA6586 driver and three buttons
// Blue button: full speed (reverse direction)
// Yellow button: half speed (reverse direction)
// Red button: stop
const int fiPin = 5; // Forward Input pin of TA6586
const int biPin = 6; // Backward Input pin of TA6586
const int blueBtn = 9; // Blue button pin - full speed
const int yellowBtn = 10;// Yellow button pin - half speed
const int redBtn = 11; // Red button pin - stop
// Set motor control pins as outputs
pinMode(fiPin, OUTPUT);
pinMode(biPin, OUTPUT);
// Set button pins as inputs with internal pull-up resistors
// (HIGH when not pressed, LOW when pressed)
pinMode(blueBtn, INPUT_PULLUP);
pinMode(yellowBtn, INPUT_PULLUP);
pinMode(redBtn, INPUT_PULLUP);
// When the blue button is pressed: full speed reverse
if (digitalRead(blueBtn) == LOW) {
analogWrite(biPin, 255); // Full speed reverse
analogWrite(fiPin, 0); // Stop forward output
// When the yellow button is pressed: half speed reverse
else if (digitalRead(yellowBtn) == LOW) {
analogWrite(biPin, 128); // Half speed reverse
// When the red button is pressed: stop the motor
else if (digitalRead(redBtn) == LOW) {
analogWrite(biPin, 0);
