Flame Monitor 2.0
Kit purchase
Includes Arduino board |
PURCHASE LINK |
Ultimate Sensor Kit |
Arduino Uno R4 Minima |
Universal Maker Sensor Kit |
Course Introduction
In this lesson, you’ll learn how to use a Flame Sensor, an I2C LCD Display, and the Arduino UNO R4 to monitor fire intensity. The LCD shows real-time readings, while LEDs and a buzzer provide visual and sound alerts for different flame levels.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R4 Minima |
USB Type-C cable |
Breadboard |
Wires |
Several |
Flame Sensor Module |
Buzzer Modudle |
7 |
I2C LCD 1602 |
8 |
Traffic Light LED |
Common Connections:
Flame Sensor Module
A0: Connect to A0 on the Arduino.
Traffic light LED
R: Connect to 5 on the Arduino.
Y: Connect to 4 on the Arduino.
G: Connect to 3 on the Arduino.
Buzzer Modudle
I/O: Connect to 10 on the Arduino.
I2C LCD 1602
SDA: Connect to A4 on the Arduino.
SCL: Connect to A5 on the Arduino.
Writing the Code
To install the library, use the Arduino Library Manager and search for LiquidCrystal_I2C and install it.
Don’t forget to select the board(Arduino UNO R4 Minima) and the correct port before clicking the Upload button.
#include <Wire.h>
// Define pin connections
const int sensorPin = A0; // Analog pin connected to the flame sensor
const int redPin = 5; // Red LED pin
const int yellowPin = 4; // Yellow LED pin
const int greenPin = 3; // Green LED pin
const int buzzerPin = 10; // Buzzer pin
LiquidCrystal_I2C lcd(0x27, 16, 2); // I2C LCD address and size
int flameValue = 0; // Variable to store the flame sensor reading
Serial.begin(9600); // Initialize serial monitor for debugging
lcd.init(); // Initialize LCD
lcd.backlight(); // Turn on LCD backlight
// Set pin modes
pinMode(redPin, OUTPUT);
pinMode(yellowPin, OUTPUT);
pinMode(greenPin, OUTPUT);
pinMode(buzzerPin, OUTPUT);
// Display startup message
lcd.setCursor(0, 0);
lcd.print("Flame Monitor");
delay(1000);
// Read analog value from flame sensor (0–1023)
int rawValue = analogRead(sensorPin);
// Invert value: when flame is closer, the value increases
flameValue = 1023 - rawValue;
// Print flame value to Serial Monitor
Serial.print("Flame Sensor Value: ");
Serial.println(flameValue);
// Show value on LCD
lcd.setCursor(0, 1);
lcd.print("Value: ");
lcd.print(flameValue);
lcd.print(" "); // Clear leftover digits
// Flame detection logic
if (flameValue < 250) {
// No flame detected
setLights(HIGH, LOW, LOW); // Green ON, others OFF
noTone(buzzerPin); // Turn off buzzer
else if (flameValue < 450) {
// Weak flame detected
setLights(LOW, HIGH, LOW); // Yellow ON
tone(buzzerPin, 800, 200); // Short beep sound
else {
// Strong flame detected (danger)
setLights(LOW, LOW, HIGH); // Red ON
tone(buzzerPin, 1000, 400); // Longer alarm sound
delay(200); // Small delay for stability
// Helper function to control the three LEDs
void setLights(int greenState, int yellowState, int redState) {
digitalWrite(greenPin, greenState);
digitalWrite(yellowPin, yellowState);
digitalWrite(redPin, redState);
