TempHumid Monitor
Kit purchase
Includes Arduino board |
PURCHASE LINK |
Elite Explorer Kit |
Arduino Uno R4 WiFi |
3 in 1 Ultimate Starter Kit |
Arduino Uno R4 Minima |
Course Introduction
This Arduino project uses a DHT11 sensor and an OLED display to monitor and display real-time temperature and humidity.
The data is updated every 0.5 seconds and shown clearly on a 128x64 I2C OLED screen. If sensor readings fail, an error message is displayed.
This setup is ideal for simple environmental monitoring applications.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R4 WIFI |
USB Type-C cable |
Breadboard |
Wires |
Several |
DHT-11 Module |
OLED Display Module |
Common Connections:
DHT-11 Module
OUT: Connect to 2 on the Arduino.
-: Connect to breadboard’s negative power bus.
+: Connect to breadboard’s red power bus.
OLED Display Module
SDA: Connect to SDA on the Arduino.
SCK: Connect to SCL on the Arduino.
Writing the Code
To install the library, use the Arduino Library Manager and search for DHT , Adafruit SSD1306 and Adafruit GFX and install it.
Don’t forget to select the board(Arduino UNO R4 Minima) and the correct port before clicking the Upload button.
#include <DHT.h>
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
// Declaration for SSD1306 display connected using I2C
#define OLED_RESET -1 // Reset pin # (or -1 if sharing Arduino reset pin)
#define SCREEN_ADDRESS 0x3C
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
// DHT sensor settings
#define DHTPIN 2 // Define the pin used to connect the sensor
#define DHTTYPE DHT11 // Define the sensor type
DHT dht(DHTPIN, DHTTYPE); // Create a DHT object
// Initialize the serial communication
Serial.begin(9600);
Serial.println(F("DHT11 with OLED test!"));
// Initialize the DHT sensor
dht.begin();
// Initialize the OLED object
if (!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS)) {
Serial.println(F("SSD1306 allocation failed"));
for (;;)
// Clear the buffer.
display.clearDisplay();
// Wait a shorter time between measurements to increase the update speed
delay(500); // 500 milliseconds delay for faster updates
float h = dht.readHumidity();
float t = dht.readTemperature();
if (isnan(h) || isnan(t)) {
Serial.println(F("Failed to read from DHT sensor!"));
display.setCursor(0, 0);
display.setTextSize(1);
display.setTextColor(WHITE);
display.println("Sensor error");
display.display();
return;
// Clear the display before showing new data
// Display humidity label on the first line
display.setTextSize(1); // Smaller text size for label
display.setTextColor(WHITE); // Set text color
display.setCursor(0, 0); // Set cursor position for humidity label
display.println("Humidity:");
// Display humidity value on the second line
display.setTextSize(2); // Larger text size for value
display.setCursor(0, 10); // Move to next line for humidity value
display.print(h);
display.println("%");
// Display temperature label on the third line
display.setCursor(0, 35); // Set cursor position for temperature label
display.println("Temperature:");
// Display temperature value on the fourth line
display.setCursor(0, 45); // Move to next line for temperature value
display.print(t);
display.println("C");
// Update the display with new information
display.display();
// Also print to serial monitor (for debugging)
Serial.print(F("Humidity: "));
Serial.print(h);
Serial.print(F("% Temperature: "));
Serial.print(t);
Serial.println(F("°C"));
