Traffic light
  • 🎁 Looking for parts?Check out our all-in-one kits below — packed with components, beginner-friendly guides, and tons of fun.
Includes Arduino board
PURCHASE LINK
Ultimate Sensor Kit
Arduino Uno R4 Minima
Elite Explorer Kit
Arduino Uno R4 WiFi
3 in 1 Ultimate Starter Kit
Course Introduction
In this lesson, you’ll learn how to build a simple traffic light system using the Arduino UNO R4, a TM1637 4-digit display, and LED.
The display counts down each light phase—red, yellow, and green—just like a real traffic signal.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino UNO R4 Minima/Arduino UNO R4 WIFI
USB Type-C cable
Wires
Several
4-Digit Segment Display Module
Traffic Light LED
../_images/traffic_light_bb.png
Common Connections:
  • Traffic light LED
    • R: Connect to 10 on the Arduino.
    • Y: Connect to 11 on the Arduino.
    • G: Connect to 12 on the Arduino.
  • 4-Digit Segment Display Module
    • CLK: Connect to 3 on the Arduino.
    • DIO: Connect to 2 on the Arduino.
Writing the Code
  • To install the library, use the Arduino Library Manager and search for TM1637Display and install it.
  • Don’t forget to select the board(Arduino UNO R4 Minima/WIFI) and the correct port before clicking the Upload button.
#include <TM1637Display.h>
// TM1637 pin definitions
#define CLK 3
#define DIO 2
// Traffic light pins
const int redPin = 10;
const int yellowPin = 11;
const int greenPin = 12;
// Create display object
TM1637Display display(CLK, DIO);
  // Setup traffic light pins
  pinMode(redPin, OUTPUT);
  pinMode(yellowPin, OUTPUT);
  pinMode(greenPin, OUTPUT);
  // Initialize display
  display.setBrightness(7);  // Brightness: 0 (dim) to 7 (bright)
  // Red light phase - 10s
  digitalWrite(redPin, HIGH);
  digitalWrite(yellowPin, LOW);
  digitalWrite(greenPin, LOW);
  countdown(10);
  // Yellow light phase - 3s
  digitalWrite(redPin, LOW);
  digitalWrite(yellowPin, HIGH);
  countdown(3);
  // Green light phase - 10s
  digitalWrite(greenPin, HIGH);
  countdown(10);
// Countdown function using TM1637 display
void countdown(int seconds) {
  for (int i = seconds; i > 0; i--) {
    display.showNumberDec(i, true, 2, 2); // Display in rightmost 2 digits
    delay(1000);
  display.clear();
