Touch Toggle
Kit purchase
Includes Arduino board |
PURCHASE LINK |
Ultimate Sensor Kit |
Arduino Uno R4 Minima |
Elite Explorer Kit |
Arduino Uno R4 WiFi |
3 in 1 Ultimate Starter Kit |
Universal Maker Sensor Kit |
Course Introduction
This Arduino project uses a touch sensor and a traffic light LED module to simulate a simple traffic light system. Each time the touch sensor is pressed, the LEDs switch in sequence from red to yellow to green. This example demonstrates how to use a touch sensor as an input trigger to control multiple LEDs in a sequence.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R4 Minima |
USB Type-C cable |
Breadboard |
Wires |
Several |
Touch Sensor Module |
Traffic Light LED |
Common Connections:
Traffic light LED
R: Connect to 7 on the Arduino.
Y: Connect to 8 on the Arduino.
G: Connect to 9 on the Arduino.
GND: Connect to GND on the Arduino.
Touch Sensor Module
SIG: Connect to 2 on the Arduino.
Writing the Code
Don’t forget to select the board(Arduino UNO R4 Minima/WIFI) and the correct port before clicking the Upload button.
The code controls a traffic light LED module with a touch sensor.
Once the touch sensor is activated, the LEDs cycle through turning
on in sequence: Red -> Yellow -> Green.
Board: Arduino Uno R4 (or R3)
Component: Touch Sensor Module and Traffic Light Module
// Define pins for touch sensor and LEDs
const int touchSensorPin = 2; // touch sensor pin
const int rledPin = 7; // red LED pin
const int yledPin = 8; // yellow LED pin
const int gledPin = 9; // green LED pin
int lastTouchState; // the previous state of touch sensor
int currentTouchState; // the current state of touch sensor
int currentLED = 0; // current LED 0->Red, 1->Yellow, 2->Green
Serial.begin(9600); // initialize serial
pinMode(touchSensorPin, INPUT); // configure touch sensor pin as input
// set LED pins as outputs
pinMode(rledPin, OUTPUT);
pinMode(yledPin, OUTPUT);
pinMode(gledPin, OUTPUT);
currentTouchState = digitalRead(touchSensorPin);
lastTouchState = currentTouchState; // save the last state
currentTouchState = digitalRead(touchSensorPin); // read new state
// check if the touch sensor was just touched
if (lastTouchState == LOW && currentTouchState == HIGH) {
Serial.println("The sensor is touched");
turnAllLEDsOff(); // Turn off all LEDs
// switch on the next LED in sequence
switch (currentLED) {
case 0:
digitalWrite(rledPin, HIGH);
currentLED = 1;
break;
case 1:
digitalWrite(yledPin, HIGH);
currentLED = 2;
break;
case 2:
digitalWrite(gledPin, HIGH);
currentLED = 0;
break;
// function to turn off all LEDs
void turnAllLEDsOff() {
digitalWrite(rledPin, LOW);
digitalWrite(yledPin, LOW);
digitalWrite(gledPin, LOW);
