Smart Fan1.0
  • 🎁 Looking for parts? Check out our all-in-one kits below — packed with components, beginner-friendly guides, and tons of fun.
Includes Arduino board
PURCHASE LINK
Elite Explorer Kit
Arduino Uno R4 WiFi
Universal Maker Sensor Kit
3 in 1 Ultimate Starter Kit
Arduino Uno R3
Course Introduction
In this lesson, you’ll build a temperature-controlled fan using a DHT11 sensor and a DC motor with the Arduino UNO R4.
When the temperature reaches a set threshold, the Arduino turns the fan on at a fixed speed using PWM. As the temperature drops below the threshold, the fan stops automatically.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino UNO R4 Minima/Arduino UNO R4 WIFI
USB Cable
Wires
Several
TA6586 - Motor Driver Chip
Humiture Sensor Module
Type Miniature DC Motor
Power Supply
../_images/smartfan1.0_bb.png
Common Connections:
  • DHT11 Humiture Sensor Module
    • DATA: Connect to 2 on the Arduino.
  • TA6586 - Motor Driver Chip
    • BI: Connect to 10 on the Arduino.
    • FI: Connect to 9 on the Arduino.
  • DC Motor
    • Connect to B0, F0 on the TA6586 - Motor Driver Chip.
Writing the Code
  • Don’t forget to select the board(Arduino UNO R3) and the correct port before clicking the Upload button.
#include <Arduino.h>
#include <DHT.h>
Smart Fan Controller (UNO R4 + DHT11 + TA6586)
Behavior:
    - If T < 27°C  -> Fan OFF
    - If T >= 27°C -> Fan ON at PWM 225
Output:
    - Serial prints temperature and fan state
// ---------- Pin definitions ----------
#define DHT_PIN   2        // DHT11 data pin
#define DHT_TYPE  DHT11
// TA6586 inputs
#define TA_IN1_PWM  9       // Must be PWM-capable pin
#define TA_IN2_DIR  10      // Direction pin (kept LOW for forward)
// ---------- DHT ----------
DHT dht(DHT_PIN, DHT_TYPE);
// ---------- Fan tuning ----------
const float   TEMP_THRESHOLD_C = 27.0f;
const uint8_t FAN_PWM_ON       = 225;   // fixed speed when ON
// ---------- Timing ----------
const unsigned long READ_INTERVAL_MS = 2000; // DHT11 should not be read too fast
unsigned long lastReadMs = 0;
// ---------- Helper: fan control ----------
void fanStop() {
analogWrite(TA_IN1_PWM, 0);
digitalWrite(TA_IN2_DIR, LOW);
void fanForward(uint8_t pwm) {
analogWrite(TA_IN1_PWM, pwm);
// ---------- Setup ----------
pinMode(TA_IN1_PWM, OUTPUT);
pinMode(TA_IN2_DIR, OUTPUT);
fanStop();
Serial.begin(115200);
dht.begin();
Serial.println("Smart Fan Controller Started.");
// ---------- Main loop ----------
unsigned long now = millis();
if (now - lastReadMs < READ_INTERVAL_MS) return;
lastReadMs = now;
// Read temperature from DHT11
float t = dht.readTemperature(); // Celsius
if (isnan(t)) {
    fanStop();
    Serial.println("DHT11 read failed! Fan -> OFF");
    return;
// Fan control by threshold
if (t >= TEMP_THRESHOLD_C) {
    fanForward(FAN_PWM_ON);
    Serial.print("Temp(C): ");
    Serial.print(t, 1);
    Serial.println(" | Fan: ON (PWM 225)");
} else {
    fanStop();
    Serial.print(t, 1);
    Serial.println(" | Fan: OFF");
