Lidar Guard
Kit purchase
Includes Arduino board |
PURCHASE LINK |
Elite Explorer Kit |
Arduino Uno R4 WiFi |
3 in 1 Ultimate Starter Kit |
Arduino Uno R4 Minima |
Course Introduction
In this lesson, we will learn how to use the VL53L0X distance sensor, a digital servo motor, and the Arduino Board to build a simple Lidar system.
The servo rotates the sensor to scan the area. Distance data and angles are sent via the serial port for monitoring.
This setup provides accurate obstacle detection using laser-based sensing.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R4 Minima |
USB Type-C cable |
Breadboard |
Wires |
Several |
Laser Ranging Module |
Digital Servo Motor |
Common Connections:
Digital Servo Motor
Connect to breadboard’s positive power bus.
Connect to breadboard’s negative power bus.
Connect to 12 on the Arduino.
SDA: Connect to A4 on the Arduino.
SCL: Connect to A5 on the Arduino.
Writing the Code
Build the circuit.
Install the library, use the Arduino Library Manager and search for Adafruit_VL53L0X install it.
Upload the code to the Arduino board using Arduino IDE.
In the Arduino IDE, check the current Arduino port(COMx).
The
ArduinoLidarGUIis used here. You can click hereArduinoSonarGUI.zipto download it.Open ArduinoLidarGUI.pde in the Processing IDE .
Modify the code in line 35 to ensure the correct port number(COMx).
Run the Processing sketch to visualize the Lidar data.
#include <Adafruit_VL53L0X.h>
#include <Servo.h>
// Initialize components
Adafruit_VL53L0X lox = Adafruit_VL53L0X();
Servo myServo;
const int servoPin = 12;
const int minAngle = 5;
const int maxAngle = 175;
int currentAngle = minAngle;
int step = 1; // Angle increment for each movement
int direction = 1; // 1 for increasing angle, -1 for decreasing
Serial.begin(9600);
myServo.attach(servoPin);
while (!Serial) {
delay(1);
if (!lox.begin()) {
Serial.println(F("Failed to boot VL53L0X"));
while (1);
// Set servo angle
myServo.write(currentAngle);
// Read distance
int distance = getDistance();
// Print data to serial port
Serial.print(currentAngle);
Serial.print(",");
Serial.print(distance);
Serial.print(".");
// Update angle
currentAngle += step * direction;
// Reverse direction at limits
if (currentAngle >= maxAngle || currentAngle <= minAngle) {
direction = -direction;
// Small delay to control scanning speed and smoothness
delay(15); // Adjust as needed: smaller = faster, but may cause jerkiness
// Function to read distance from VL53L0X
int getDistance() {
VL53L0X_RangingMeasurementData_t measure;
lox.rangingTest(&measure, false);
if (measure.RangeStatus != 4) {
return measure.RangeMilliMeter / 10; // Convert mm to cm
} else {
return 0; // Out of range
