3D Simulator
  • βœ… Be the first to get free learning resources.
  • βœ… Stay updated on new products & exclusive giveaways.
  • βœ… Share your creations and get real feedback.
  • πŸ‘‰ Need faster updates or support? Click [here] join our Facebook community
  • πŸ‘‰ Or join our WhatsApp group: Click [here]
Kit purchase
Looking for parts? Check out our all-in-one kits below β€” packed with components, beginner-friendly guides, and tons of fun.
../_images/ultimate_sensor_kit.png
Includes Arduino board
PURCHASE LINK
Elite Explorer Kit
Arduino Uno R4 WiFi
3 in 1 Ultimate Starter Kit
Arduino Uno R4 Minima
Course Introduction
In this lesson, we will learn how to use the MPU6050 Module with Arduino R4 and Processing to create dynamic motion tracking for a 3D model.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino UNO R4 Minima
USB Type-C cable
Wires
Several
MPU6050 Module
../_images/3d_plane_bb.png
Common Connections:
  • MPU6050
    • SDA: Connect to SDA on the Arduino.
    • SCL: Connect to SCL on the Arduino.
    • GND: Connect to GND on the Arduino.
    • VCC: Connect to 5V on the Arduino.
Writing the Code
  • Build the circuit.
  • Upload the code to the Arduino board using Arduino IDE.
  • In the Arduino IDE, check the current Arduino port(COMx).
  • The 3DSimulator is used here. You can click here 3DSimulator.zip to download it.
  • Open 3DSimulator.pde in the Processing IDE .
  • Modify the code in line 8 to ensure the correct port number(COMx).
  • Run the Processing sketch.
#include <Wire.h>
#include <MPU6050.h>
MPU6050 mpu;
// Raw data
int16_t ax, ay, az;
int16_t gx, gy, gz;
// Angle data
float roll = 0.0;
float pitch = 0.0;
float yaw = 0.0;
// Gyro offset
float gyroOffsetX = 0.0;
float gyroOffsetY = 0.0;
float gyroOffsetZ = 0.0;
// Timing
unsigned long lastTime = 0;
float dt = 0.0;
// Complementary filter coefficient
const float alpha = 0.98;
// ---------------------- Gyro Calibration ----------------------
void calibrateGyro() {
  const int samples = 500;
  long sumX = 0;
  long sumY = 0;
  long sumZ = 0;
  Serial.println("Calibrating gyro... Keep MPU6050 still.");
  for (int i = 0; i < samples; i++) {
    mpu.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
    sumX += gx;
    sumY += gy;
    sumZ += gz;
    delay(5);
  gyroOffsetX = sumX / (float)samples;
  gyroOffsetY = sumY / (float)samples;
  gyroOffsetZ = sumZ / (float)samples;
  Serial.println("Calibration done.");
  Serial.begin(115200);
  Wire.begin();
  mpu.initialize();
  if (!mpu.testConnection()) {
    Serial.println("MPU6050 Connection Failed");
    while (1);
  delay(1000);
  calibrateGyro();
  lastTime = millis();
  // Read MPU6050 data
  // Calculate delta time
  unsigned long currentTime = millis();
  dt = (currentTime - lastTime) / 1000.0;
  lastTime = currentTime;
  // Convert accelerometer raw data to g
  float accX = ax / 16384.0;
  float accY = ay / 16384.0;
  float accZ = az / 16384.0;
  // Convert gyro raw data to deg/s and remove offset
  float gyroX = (gx - gyroOffsetX) / 131.0;
  float gyroY = (gy - gyroOffsetY) / 131.0;
  float gyroZ = (gz - gyroOffsetZ) / 131.0;
  // Calculate accelerometer angles
  float accRoll  = atan2(accY, accZ) * 180.0 / PI;
  float accPitch = atan2(-accX, sqrt(accY * accY + accZ * accZ)) * 180.0 / PI;
  roll  = alpha * (roll + gyroX * dt) + (1.0 - alpha) * accRoll;
  pitch = alpha * (pitch + gyroY * dt) + (1.0 - alpha) * accPitch;
  // Yaw only from gyro integration
  yaw += gyroZ * dt;
  // Send data to Processing
  Serial.print(roll);
  Serial.print(",");
  Serial.print(pitch);
  Serial.print(",");
  Serial.println(yaw);
  delay(10);  // about 100Hz
