Dodge Game 2.0
Kit purchase
Includes Arduino board
PURCHASE LINK
Ultimate Sensor Kit
Arduino Uno R4 Minima
Elite Explorer Kit
Arduino Uno R4 WiFi
3 in 1 Ultimate Starter Kit
Universal Maker Sensor Kit
Course Introduction
In this lesson, you’ll use an MPU6050 motion sensor, an OLED display, a buzzer, and a button with the Arduino R4 UNO to create a tilt‑controlled obstacle game.
By tilting the device, you control a ball on the screen to dodge moving obstacles. Collisions trigger a buzzer alert, and pressing the button restarts the game.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino UNO R4 Minima
USB Type-C cable
Wires
Several
Button
OLED Display Module
Active Buzzer
MPU6050 Module
../_images/dodge_ball2_bb.png
Common Connections:
  • OLED Display Module
    • SDA: Connect to A4 on the Arduino.
    • SCK: Connect to A5 on the Arduino.
  • Button
    • Connect to the breadboard’s negative power bus, and the other end to 2 on the Arduino board.
  • Active Buzzer
    • +: Connect to 2 on the Arduino.
    • -: Connect to breadboard’s negative power bus.
  • MPU6050
    • SCL: Connect to A5 on the Arduino.
Writing the Code
  • To install the library, use the Arduino Library Manager and search for Adafruit SSD1306 and Adafruit GFX and MPU6050 and install it.
  • Don’t forget to select the board(Arduino UNO R4 Minima) and the correct port before clicking the Upload button.
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <MPU6050.h>
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 64
#define OLED_RESET -1
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
#define BUZZER_PIN 6
#define BUTTON_PIN 2
MPU6050 mpu;
struct Obstacle {
  int x, y, width, height;
  bool active;
const int MAX_OBS = 3;
Obstacle obstacles[MAX_OBS];
float ax, ay;
float ballX = SCREEN_WIDTH / 4;
float ballY = SCREEN_HEIGHT / 2;
float ballVx = 0, ballVy = 0;
const int BALL_RADIUS = 3;
bool gameOver = false;
  Serial.begin(9600);
  pinMode(BUZZER_PIN, OUTPUT);
  pinMode(BUTTON_PIN, INPUT_PULLUP);
  // Initialize OLED
  if (!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) {
    Serial.println("OLED init failed!");
    for(;;);
  display.clearDisplay();
  display.display();
  // Initialize MPU6050
  Wire.begin();
  mpu.initialize();
  if (!mpu.testConnection()) {
    Serial.println("MPU6050 connection failed!");
    while (1);
  resetGame();
  if (gameOver) {
    display.setTextSize(2);
    display.setCursor(20, 20);
    display.println("Game Over");
    display.setTextSize(1);
    display.setCursor(20, 50);
    display.println("Press Btn");
    display.display();
    if (digitalRead(BUTTON_PIN) == LOW) {
      delay(300);
      resetGame();
    return;
  readMPU();
  updateBall();
  updateObstacles();
  checkCollision();
  render();
  delay(2);
void resetGame() {
  ballVx = ballVy = 0;
  for (int i = 0; i < MAX_OBS; i++) {
    obstacles[i].active = false;
  gameOver = false;
void readMPU() {
  int16_t ax_raw, ay_raw, az_raw;
  mpu.getAcceleration(&ax_raw, &ay_raw, &az_raw);
  ax = ax_raw / 16384.0;
  ay = ay_raw / 16384.0;
void updateBall() {
  ballVx += (ay) * 3.8;  // Horizontal movement
  ballVy += (ax) * 3.8;   // Vertical movement
  ballX += ballVx;
  ballY += ballVy;
  // Friction damping
  ballVx *= 1.0 ;
  ballVy *= 1.0 ;
  // Boundary detection
  if (ballX < BALL_RADIUS) { ballX = BALL_RADIUS; ballVx = 0; }
  if (ballX > SCREEN_WIDTH - BALL_RADIUS) { ballX = SCREEN_WIDTH - BALL_RADIUS; ballVx = 0; }
  if (ballY < BALL_RADIUS) { ballY = BALL_RADIUS; ballVy = 0; }
  if (ballY > SCREEN_HEIGHT - BALL_RADIUS) { ballY = SCREEN_HEIGHT - BALL_RADIUS; ballVy = 0; }
void updateObstacles() {
    if (obstacles[i].active) {
      obstacles[i].x -= 6;
      if (obstacles[i].x + obstacles[i].width < 0) {
    } else {
      if (random(0, 100) < 3) { // Randomly generate obstacles
        obstacles[i].x = SCREEN_WIDTH;
        obstacles[i].y = random(10, SCREEN_HEIGHT - 20);
        obstacles[i].width = 8;
        obstacles[i].height = 20;
        obstacles[i].active = true;
void checkCollision() {
      if (ballX + BALL_RADIUS > obstacles[i].x &&
          ballX - BALL_RADIUS < obstacles[i].x + obstacles[i].width &&
          ballY + BALL_RADIUS > obstacles[i].y &&
          ballY - BALL_RADIUS < obstacles[i].y + obstacles[i].height) {
        gameOver = true;
        tone(BUZZER_PIN, 1000, 500); // Play buzzer alert
void render() {
  display.drawCircle(ballX, ballY, BALL_RADIUS, SSD1306_WHITE);
      display.fillRect(obstacles[i].x, obstacles[i].y, obstacles[i].width, obstacles[i].height, SSD1306_WHITE);
  display.display();
