Speed Dial
Kit purchase
Includes Arduino board |
PURCHASE LINK |
Elite Explorer Kit |
Arduino Uno R4 WiFi |
3 in 1 Ultimate Starter Kit |
Arduino Uno R4 Minima |
Course Introduction
In this lesson, you’ll use a potentiometer and a DC motor with the Arduino R4 UNO to create a simple motor speed control system.
By rotating the potentiometer, you can adjust the motor speed from stop to full speed. The Arduino reads the potentiometer value, maps it to PWM output, and drives the motor in one direction with variable speed.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R4 Minima/Arduino UNO R4 WIFI |
USB Cable |
Breadboard |
Wires |
Several |
TA6586 - Motor Driver Chip |
Potentiometer Sensor Module |
7 |
TT Motor |
8 |
Power Supply |
Common Connections:
OUT: Connect to A0 on the Arduino.
BI: Connect to 10 on the Arduino.
FI: Connect to 9 on the Arduino.
TT Motor
Connect to B0, F0 on the TA6586 - Motor Driver Chip.
Writing the Code
Don’t forget to select the board(Arduino UNO R3) and the correct port before clicking the Upload button.
const int potPin = A0; // Potentiometer signal pin
const int motorPin1 = 9; // Motor IN1 pin (PWM)
const int motorPin2 = 10; // Motor IN2 pin (LOW for direction control)
pinMode(motorPin1, OUTPUT); // Set motorPin1 as output
pinMode(motorPin2, OUTPUT); // Set motorPin2 as output
int val = analogRead(potPin); // Read analog value from potentiometer (0–1023)
int speed = map(val, 0, 1023, 0, 255); // Map value to PWM range (0–255)
analogWrite(motorPin1, speed); // Drive motor with mapped speed (one direction)
analogWrite(motorPin2, 0); // Keep the other pin LOW to set rotation direction
