LED control 1.0
Kit purchase
Includes Arduino board
PURCHASE LINK
Ultimate Sensor Kit
Arduino Uno R4 Minima
Elite Explorer Kit
Arduino Uno R4 WiFi
3 in 1 Ultimate Starter Kit
Universal Maker Sensor Kit
Course Introduction
In this lesson, you will use Arduino together with two buttons and a row of LEDs to create a directional light-flow effect.
Pressing the green button makes the LEDs light up in a forward flowing pattern, while pressing the red button triggers a backward flow.
Each button controls the direction of the LED animation, allowing you to switch between the two lighting modes at any time.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino UNO R4 Minima
USB Type-C cable
Wires
Several
1kΩ resistor
Several
Button
LED
Several
../_images/LED_Control1.0_bb.png
Common Connections:
  • LED
    • Connect the LEDs cathode to the negative power bus on the breadboard, and the LEDs anode to 1kΩ resistor then to 5 to 10 on the Arduino.
  • Button
    • Connect to breadboard’s negative power bus.
    • Connect to 3 , 12 on the Arduino.
Writing the Code
  • Don’t forget to select the board(Arduino UNO R4 Minima) and the correct port before clicking the Upload button.
// Pins for buttons
const int buttonGreen = 3;   // Green button = forward
const int buttonRed   = 12;  // Red button = backward
// LED pins from 5 to 10
const int ledPins[] = {5, 6, 7, 8, 9, 10};
const int ledCount = 6;
int delayTime = 80;   // Speed of flowing
  // LEDs as output
  for (int i = 0; i < ledCount; i++) {
    pinMode(ledPins[i], OUTPUT);
  // Buttons use internal pull-up
  pinMode(buttonGreen, INPUT_PULLUP);
  pinMode(buttonRed, INPUT_PULLUP);
  // Read buttons (LOW = pressed)
  bool greenPressed = (digitalRead(buttonGreen) == LOW);
  bool redPressed   = (digitalRead(buttonRed) == LOW);
  // ----- Forward Flow: 5 → 10 -----
  if (greenPressed) {
      digitalWrite(ledPins[i], HIGH);   // Light current LED
      delay(delayTime);
      if (i > 0) {
        digitalWrite(ledPins[i - 1], LOW); // Turn off previous LED
    digitalWrite(ledPins[ledCount - 1], LOW); // Turn off last LED
  // ----- Backward Flow: 10 → 5 -----
  if (redPressed) {
    for (int i = ledCount - 1; i >= 0; i--) {
      delay(delayTime);
      if (i < ledCount - 1) {
        digitalWrite(ledPins[i + 1], LOW); // Turn off previous LED
    digitalWrite(ledPins[0], LOW); // Turn off last LED
