Traffic light 2.0
👉 Need faster updates or support? Click [here] join our Facebook community
👉 Or join our WhatsApp group: Click [here]
🎁 Looking for parts?Check out our all-in-one kits below — packed with components, beginner-friendly guides, and tons of fun.
Includes Arduino board |
PURCHASE LINK |
Ultimate Sensor Kit |
Arduino Uno R4 Minima |
Elite Explorer Kit |
Arduino Uno R4 WiFi |
3 in 1 Ultimate Starter Kit |
Course Introduction
In this lesson, you’ll learn how to build a simple traffic light system using the Arduino, a TM1637 4-digit display, and LED Modules.
This experiment simulates the operation of street traffic lights and pedestrian crossing signals.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R4 Minima/Arduino UNO R4 WIFI |
USB Type-C cable |
Breadboard |
Wires |
Several |
4-Digit Segment Display Module |
Traffic Light LED |
Common Connections:
Traffic light LED #1
R: Connect to 10 on the Arduino.
Y: Connect to 11 on the Arduino.
G: Connect to 12 on the Arduino.
Traffic light LED #2
R: Connect to 7 on the Arduino.
G: Connect to 8 on the Arduino.
CLK: Connect to 3 on the Arduino.
DIO: Connect to 2 on the Arduino.
Writing the Code
To install the library, use the Arduino Library Manager and search for TM1637Display and install it.
Don’t forget to select the board(Arduino UNO R4 Minima/WIFI) and the correct port before clicking the Upload button.
#include <TM1637Display.h>
// TM1637 display pins
#define CLK 3
#define DIO 2
// Traffic light 1 (vehicle traffic)
const int carRedPin = 10;
const int carYellowPin = 11;
const int carGreenPin = 12;
// Traffic light 2 (pedestrian traffic)
const int pedRedPin = 7;
const int pedGreenPin = 8;
// Create TM1637 display object
TM1637Display display(CLK, DIO);
// Set all traffic light pins as output
pinMode(carRedPin, OUTPUT);
pinMode(carYellowPin, OUTPUT);
pinMode(carGreenPin, OUTPUT);
pinMode(pedRedPin, OUTPUT);
pinMode(pedGreenPin, OUTPUT);
display.setBrightness(7); // Brightness range 0-7
// Initial state: vehicle red light ON, pedestrian green light ON
digitalWrite(carRedPin, HIGH);
digitalWrite(pedGreenPin, HIGH);
digitalWrite(carYellowPin, LOW);
digitalWrite(carGreenPin, LOW);
digitalWrite(pedRedPin, LOW);
// 1. Vehicle red light 5 seconds, pedestrian green light ON
setTrafficLights(HIGH, LOW, LOW, LOW, HIGH);
countdown(5);
// 2. Vehicle yellow light 3 seconds, pedestrian green light flashing fast
setTrafficLights(LOW, HIGH, LOW, LOW, LOW);
flashPedGreen(3);
// 3. Vehicle green light 5 seconds, pedestrian red light ON
setTrafficLights(LOW, LOW, HIGH, HIGH, LOW);
countdown(5);
// Set traffic light states
void setTrafficLights(int carRed, int carYellow, int carGreen, int pedRed, int pedGreen) {
digitalWrite(carRedPin, carRed);
digitalWrite(carYellowPin, carYellow);
digitalWrite(carGreenPin, carGreen);
digitalWrite(pedRedPin, pedRed);
digitalWrite(pedGreenPin, pedGreen);
// Countdown on 7-segment display
void countdown(int seconds) {
for (int i = seconds; i > 0; i--) {
display.showNumberDec(i, true, 2, 2);
delay(1000);
display.clear();
// Pedestrian green light flashing (during yellow phase)
void flashPedGreen(int seconds) {
// Flash 2 times per second
for (int j = 0; j < 2; j++) {
delay(250);
digitalWrite(pedGreenPin, LOW);
delay(250);
display.clear();
