Reversing Radar
  • 🎁 Looking for parts?Check out our all-in-one kits below — packed with components, beginner-friendly guides, and tons of fun.
Kit purchase
../_images/ultimate_sensor_kit.png
Includes Arduino board
PURCHASE LINK
Elite Explorer Kit
Arduino Uno R4 WiFi
3 in 1 Ultimate Starter Kit
Arduino Uno R4 Minima
Course Introduction
In this lesson, you’ll learn how to build a reverse parking sensor system using an Ultrasonic Sensor Module, an OLED display, an RGB LED strip, and buzzer module.
The OLED displays the distance to nearby obstacles, while the LED strip changes color and the buzzer beeps faster as obstacles get closer, providing real-time parking assistance.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino UNO R4 Minima
USB Type-C cable
Wires
Several
LED Strip
Buzzer Modudle
OLED Display Module
../_images/Reversing_radar_bb.png
Common Connections:
  • LED Strip
    • Din: Connect to 6 on the Arduino.
    • +5V: Connect to breadboard’s passive power bus.
  • Ultrasonic Sensor Module
    • Trig: Connect to 9 on the Arduino.
    • Echo: Connect to 10 on the Arduino.
  • OLED Display Module
    • SDA: Connect to SDA on the Arduino.
    • SCK: Connect to SCL on the Arduino.
  • Buzzer Module
    • I/0: Connect to 5 on the Arduino.
    • +: Connect to breadboard’s red power bus.
    • -: Connect to breadboard’s negative power bus.
Writing the Code
  • To install the library, use the Arduino Library Manager and search for Adafruit_NeoPixel, Adafruit SSD1306 and Adafruit GFX and install it.
  • Don’t forget to select the board(Arduino UNO R4 Minima) and the correct port before clicking the Upload button.
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <Adafruit_NeoPixel.h>
// OLED
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 64
#define OLED_RESET -1
#define OLED_ADDR 0x3C
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
// Pins
const int TRIG_PIN = 9;
const int ECHO_PIN = 10;
const int BUZZER_PIN = 5;
const int LED_PIN = 6;
// LED strip
const int LED_COUNT = 8;
Adafruit_NeoPixel strip(LED_COUNT, LED_PIN, NEO_GRB + NEO_KHZ800);
// Distance settings
const int SAFE_DISTANCE_CM = 20;
const int LED_START_CM = 15;
const int DANGER_DISTANCE_CM = 3;
// Buzzer timing
unsigned long lastBeepTime = 0;
bool buzzerState = false;
// Passive buzzer frequency
const int BUZZER_FREQ = 2000;
  pinMode(TRIG_PIN, OUTPUT);
  pinMode(ECHO_PIN, INPUT);
  pinMode(BUZZER_PIN, OUTPUT);
  noTone(BUZZER_PIN);
  strip.begin();
  strip.show();
  if (!display.begin(SSD1306_SWITCHCAPVCC, OLED_ADDR)) {
    while (true);
  display.clearDisplay();
  display.display();
  float distanceCM = readDistanceCM();
  int distanceMM = distanceCM * 10;
  updateOLED(distanceMM, distanceCM);
  updateLEDStrip(distanceCM);
  updateBuzzer(distanceCM);
  delay(50);
float readDistanceCM() {
  digitalWrite(TRIG_PIN, LOW);
  delayMicroseconds(2);
  digitalWrite(TRIG_PIN, HIGH);
  delayMicroseconds(10);
  long duration = pulseIn(ECHO_PIN, HIGH, 30000);
  if (duration == 0) {
    return 999;
  return duration * 0.0343 / 2.0;
void updateOLED(int distanceMM, float distanceCM) {
  display.setTextColor(SSD1306_WHITE);
  display.setTextSize(1);
  display.setCursor(0, 0);
  display.print("Reverse Radar");
  display.setTextSize(2);
  display.setCursor(0, 22);
  if (distanceCM > SAFE_DISTANCE_CM) {
    display.print("SAFE");
  } else {
    display.print(distanceMM);
    display.print("mm");
  display.display();
void updateLEDStrip(float distanceCM) {
    clearLEDs();
    return;
  if (distanceCM > LED_START_CM) {
    clearLEDs();
    return;
  int ledsOn = 0;
  if (distanceCM <= 0) {
    ledsOn = 1;
  } else {
    ledsOn = ceil(distanceCM / 2.0);
  ledsOn = constrain(ledsOn, 1, LED_COUNT);
  uint32_t color;
  if (distanceCM >= 9 && distanceCM <= 15) {
    color = strip.Color(0, 255, 0);       // Green
  } else if (distanceCM > 5 && distanceCM < 9) {
    color = strip.Color(255, 180, 0);     // Yellow
  } else {
    color = strip.Color(255, 0, 0);       // Red
  clearLEDs();
  for (int i = 0; i < ledsOn; i++) {
    strip.setPixelColor(i, color);
  strip.show();
void updateBuzzer(float distanceCM) {
    noTone(BUZZER_PIN);
    return;
  if (distanceCM < DANGER_DISTANCE_CM) {
    tone(BUZZER_PIN, BUZZER_FREQ);  // Long beep
    return;
  int beepInterval = map(distanceCM, 3, 20, 100, 800);
  beepInterval = constrain(beepInterval, 100, 800);
  if (millis() - lastBeepTime >= beepInterval) {
    lastBeepTime = millis();
    buzzerState = !buzzerState;
    if (buzzerState) {
    } else {
      noTone(BUZZER_PIN);
void clearLEDs() {
  for (int i = 0; i < LED_COUNT; i++) {
    strip.setPixelColor(i, 0, 0, 0);
  strip.show();
