Pong Game
Kit purchase
Includes Arduino board |
PURCHASE LINK |
Ultimate Sensor Kit |
Arduino Uno R4 Minima |
Universal Maker Sensor Kit |
Course Introduction
In this lesson, you’ll learn how to use a OLED Display Module, two buttons with the Arduino R4 UNO to create a Pong Game. We’ll cover using the Adafruit SSD1306 and GFX libraries to display on the screen.
The OLED Screen will display the game screen, and players can use button to control the game.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R4 Wifi |
USB Type-C cable |
Breadboard |
Wires |
Several |
Button |
OLED Display Module |
Common Connections:
OLED Display Module
SDA: Connect to SDA on the Arduino.
SCK: Connect to SCL on the Arduino.
Writing the Code
To install the library, use the Arduino Library Manager and search for Adafruit SSD1306 and Adafruit GFX and install it.
Don’t forget to select the board(Arduino UNO R4 WIFI) and the correct port before clicking the Upload button.
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
// Button pins
#define UP_BUTTON 3
#define DOWN_BUTTON 2
// OLED display sized
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 64
// OLED reset pin
#define OLED_RESET 4
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
// === Ball settings ===
// How often (ms) we update the ball’s position
const unsigned long BALL_RATE = 16;
// Current x/y position of the ball
int ball_x = SCREEN_WIDTH / 2;
int ball_y = SCREEN_HEIGHT / 2;
// How many pixels the ball moves each update
int ball_speed = 1;
// Direction: +1 means right/down, −1 means left/up
int8_t ball_dir_x = 1, ball_dir_y = 1;
// === Paddle settings ===
// How often (ms) we update paddles
const unsigned long PADDLE_RATE = 33;
// Paddle height in pixels
const uint8_t PADDLE_H = 16;
// X position of the CPU’s paddle
const uint8_t CPU_X = 12;
// Current y position of the CPU paddle
int8_t cpu_y = 16;
// X position of the player’s paddle
const uint8_t PLAYER_X = 115;
// Current y position of the player paddle
int8_t player_y = 16;
// How many pixels the player paddle moves per button press
int paddle_spd = 3;
// For timing the updates
unsigned long ball_update, paddle_update;
// === Score and game state ===
uint8_t player_score = 0;
uint8_t cpu_score = 0;
bool game_over = false;
Serial.begin(115200);
// Initialize random starting direction
randomSeed(analogRead(A0));
ball_dir_x = random(0, 2) * 2 - 1;
ball_dir_y = random(0, 2) * 2 - 1;
// Start the OLED display
display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
display.clearDisplay();
// Draw the border once at startup
drawCourt();
display.display();
// Set up button inputs
pinMode(UP_BUTTON, INPUT);
pinMode(DOWN_BUTTON, INPUT);
// Pause briefly so you can see the court before play begins
delay(2000);
// Show the initial score
displayScore();
display.display();
// Initialize the update timers
ball_update = millis();
paddle_update = ball_update;
// If the game has ended, do nothing further
if (game_over) return;
unsigned long now = millis();
bool updated = false;
// === Move the ball if it’s time ===
if (now >= ball_update) {
ball_update += BALL_RATE;
int new_x = ball_x + ball_dir_x * ball_speed;
int new_y = ball_y + ball_dir_y * ball_speed;
// Bounce off top and bottom edges
if (new_y <= 0 || new_y >= SCREEN_HEIGHT - 1) {
ball_dir_y = -ball_dir_y;
new_y += ball_dir_y * ball_speed;
// Bounce off the CPU paddle
if (new_x <= CPU_X + 1
&& ball_x > CPU_X + 1
&& new_y >= cpu_y
&& new_y <= cpu_y + PADDLE_H) {
ball_dir_x = -ball_dir_x;
new_x = CPU_X + 1; // Prevent clipping into the paddle
ball_speed++; // Speed up on each hit
// Bounce off the player’s paddle
if (new_x >= PLAYER_X - 1
&& ball_x < PLAYER_X - 1
&& new_y >= player_y
&& new_y <= player_y + PADDLE_H) {
new_x = PLAYER_X - 1;
ball_speed++;
// Check left/right edges for a score and reset
if (new_x <= 0) {
// Ball hit CPU’s side → player scores
player_score++;
resetBall();
else if (new_x >= SCREEN_WIDTH - 1) {
// Ball hit player’s side → CPU scores
cpu_score++;
resetBall();
else {
// No score: update ball position normally
ball_x = new_x;
ball_y = new_y;
updated = true;
// === Move the paddles if it’s time ===
if (now >= paddle_update) {
paddle_update += PADDLE_RATE;
// CPU paddle follows the ball slowly
int8_t mid = cpu_y + (PADDLE_H >> 1);
if (mid < ball_y) cpu_y++;
if (mid > ball_y) cpu_y--;
cpu_y = constrain(cpu_y, 1, SCREEN_HEIGHT - 1 - PADDLE_H);
// Player paddle moves on button press
if (digitalRead(UP_BUTTON) == LOW) player_y -= paddle_spd;
if (digitalRead(DOWN_BUTTON) == LOW) player_y += paddle_spd;
player_y = constrain(player_y, 1, SCREEN_HEIGHT - 1 - PADDLE_H);
updated = true;
// === Redraw everything if something moved ===
if (updated) {
drawCourt();
displayScore();
// Draw CPU paddle (4 pixels wide for visibility)
display.fillRect(CPU_X - 1, cpu_y - 1, 4, PADDLE_H + 2, WHITE);
// Draw player paddle
display.fillRect(PLAYER_X - 1, player_y - 1, 4, PADDLE_H + 2, WHITE);
// Draw ball as a 5×5 square
display.fillRect(ball_x - 2, ball_y - 2, 5, 5, WHITE);
display.display();
// === Check for end‑of‑game ===
if (player_score >= 3 || cpu_score >= 3) {
game_over = true;
// Decide which message to show
String msg = (player_score >= 3) ? "You win!" : "You lose!";
// Calculate text centering
uint8_t ts = 2; // Text size
uint8_t charW = 6 * ts; // Character width in pixels
uint8_t textW = msg.length() * charW;
uint8_t textH = 8 * ts; // Character height in pixels
int16_t x = (SCREEN_WIDTH - textW) / 2;
int16_t y = (SCREEN_HEIGHT - textH) / 2;
// Show the final message
display.setTextSize(ts);
display.setTextColor(WHITE);
display.setCursor(x, y);
display.print(msg);
display.display();
// Draw the outer border of the court
void drawCourt() {
display.drawRect(0, 0, SCREEN_WIDTH, SCREEN_HEIGHT, WHITE);
// Display the current score at the top center
void displayScore() {
display.fillRect((SCREEN_WIDTH / 2) - 20, 10, 60, 10, BLACK);
display.setTextSize(1);
display.setCursor((SCREEN_WIDTH / 2) - 20, 10);
display.print(cpu_score);
display.print(" - ");
display.print(player_score);
// Reset the ball to the center and set a new random direction
void resetBall() {
ball_speed = 1;
ball_dir_x = (ball_dir_x > 0 ? -1 : 1);
