Mini Fan 4.0
👉 Need faster updates or support? Click [here] join our Facebook community
👉 Or join our WhatsApp group: Click [here]
🎁 Looking for parts?Check out our all-in-one kits below — packed with components, beginner-friendly guides, and tons of fun.
Includes Arduino board |
PURCHASE LINK |
Elite Explorer Kit |
Arduino Uno R4 WiFi |
Universal Maker Sensor Kit |
3 in 1 Ultimate Starter Kit |
Arduino Uno R3 |
Course Introduction
In this lesson, you’ll create a simple control system using a rotary encoder to steer a servo and adjust fan speed. Turning the encoder changes the servo angle, while pressing the button cycles through multiple fan speed levels.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R4 Minima/Arduino UNO R4 WIFI |
USB Cable |
Breadboard |
Wires |
Several |
DC Motor |
TA6586 - Motor Driver Chip |
7 |
Rotary Encoder Module |
8 |
Digital Servo Motor |
Common Connections:
BI: Connect to 6 on the Arduino.
FI: Connect to 5 on the Arduino.
DC Motor
GND: Connect to TA6586 B0.
VCC: Connect to TA6586 F0.
CLK: Connect to 12 on the Arduino.
DT: Connect to 11 on the Arduino.
SW: Connect to 10 on the Arduino.
Digital Servo Motor
Connect to breadboard’s positive power bus.
Connect to 3 on the Arduino.
Writing the Code
Don’t forget to select the board(Arduino UNO R4) and the correct port before clicking the Upload button.
#include <Servo.h>
// Fan motor pins
const int fiPin = 5; // fixed LOW in this project
const int biPin = 6; // PWM output to control fan speed
// Servo setup
Servo servo;
const int servoPin = 3; // servo signal pin
// Rotary encoder pins
const int CLK = 12; // main signal: detects rotation steps
const int DT = 11; // direction signal
const int SW = 10; // encoder button (LOW when pressed)
// Variables for encoder reading
int lastCLK = HIGH; // used to detect edge
unsigned long lastPress = 0; // debounce timer for SW
// Servo angle control
int angle = 90; // starting angle
const int angleMin = 45; // left limit
const int angleMax = 135; // right limit
const int angleStep = 2; // angle change per encoder step
// Fan gear control
int gear = 0; // 0~3 speed levels
int fanSpeed = 0; // actual PWM value
// Motor pins
pinMode(fiPin, OUTPUT);
pinMode(biPin, OUTPUT);
// Encoder pins
pinMode(CLK, INPUT);
pinMode(DT, INPUT);
pinMode(SW, INPUT_PULLUP); // button is active LOW
// Servo setup
servo.attach(servoPin);
servo.write(angle);
// Read encoder rotation
int currentCLK = digitalRead(CLK);
// Detect the rising edge of CLK (means one "tick")
if (currentCLK != lastCLK && currentCLK == HIGH) {
// Compare DT to decide direction
if (digitalRead(DT) == currentCLK) {
angle += angleStep; // clockwise → angle increases
} else {
angle -= angleStep; // counterclockwise → angle decreases
// Keep the servo angle inside safe limits
angle = constrain(angle, angleMin, angleMax);
// Move servo to new angle
servo.write(angle);
lastCLK = currentCLK;
// Read encoder button (SW)
// Button pressed (active LOW)
if (digitalRead(SW) == LOW) {
// Simple debounce check
if (millis() - lastPress > 300) {
gear++; // next speed level
if (gear > 3) gear = 0; // wrap around (0→1→2→3→0...)
lastPress = millis();
// Convert gear level to PWM speed
if (gear == 0) fanSpeed = 0; // fan off
if (gear == 1) fanSpeed = 85; // low
if (gear == 2) fanSpeed = 170; // medium
if (gear == 3) fanSpeed = 255; // high
// Output speed to fan motor
if (fanSpeed > 0) {
analogWrite(biPin, fanSpeed); // send PWM speed
analogWrite(fiPin, 0); // keep opposite pin LOW
} else {
analogWrite(biPin, 0); // stop fan
