Servo Control
Kit purchase
../_images/ultimate_sensor_kit.png
Includes Arduino board
PURCHASE LINK
Elite Explorer Kit
Arduino Uno R4 WiFi
3 in 1 Ultimate Starter Kit
Arduino Uno R4 Minima
Course Introduction
This Arduino project uses a potentiometer to control a servo motor. As the potentiometer is turned, its analog value is read and mapped to an angle between 0° and 180°, which adjusts the servo’s position accordingly.
The angle and raw value are displayed via serial monitor, making it a simple and interactive demo of analog input to motor control.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino UNO R4 WIFI
USB Type-C cable
Wires
Several
Digital Servo Motor
Potentiometer Sensor Module
../_images/Servo_Control_bb.png
Common Connections:
  • Digital Servo Motor
    • Connect to breadboard’s positive power bus.
    • Connect to breadboard’s negative power bus.
    • Connect to 3 on the Arduino.
  • Potentiometer Sensor Module
    • OUT: Connect to A0 on the Arduino.
Writing the Code
  • Don’t forget to select the board(Arduino UNO R4 Minima/WIFI) and the correct port before clicking the Upload button.
#include <Servo.h>
// Define the potentiometer pin and the servo pin
const int potPin = A0;     // Potentiometer connected to analog pin A0
const int servoPin = 3;    // Servo connected to digital pin 3
// Create a servo object
Servo myServo;
  myServo.attach(servoPin);  // Attach the servo to pin 3
  Serial.begin(9600);        // Start serial communication
  int potValue = analogRead(potPin);                // Read analog value (0~1023)
  int angle = map(potValue, 0, 1023, 0, 180);        // Map to servo angle
  myServo.write(angle);                             // Set servo position
  // Debug output
  Serial.print("Potentiometer Value: ");
  Serial.print(potValue);
  Serial.print(" | Servo Angle: ");
  Serial.println(angle);
  delay(15); // Delay to smooth out the signal
