Dino Run3.0
Kit purchase
Includes Arduino board |
PURCHASE LINK |
Ultimate Sensor Kit |
Arduino Uno R4 Minima |
Elite Explorer Kit |
Arduino Uno R4 WiFi |
3 in 1 Ultimate Starter Kit |
Universal Maker Sensor Kit |
Course Introduction
In this lesson, you’ll learn how to use an OLED display and two buttons with the Arduino UNO R4 WIFI to create a Dino Run Game. We’ll use the Adafruit SSD1306 and GFX libraries to draw the game graphics on the screen.
Players can press the red button to jump and the blue button to crouch while avoiding cacti and flying birds. The game also tracks the current score and high score.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R4 WIFI |
USB Type-C cable |
Breadboard |
Wires |
Several |
Button |
OLED Display Module |
Common Connections:
OLED Display Module
SDA: Connect to SDA on the Arduino.
SCK: Connect to SCL on the Arduino.
Button 1
Connect to the breadboard’s negative power bus, and the other end to 2 on the Arduino board.
Button 2
Connect to the breadboard’s negative power bus, and the other end to 12 on the Arduino board.
Writing the Code
To install the library, use the Arduino Library Manager and search for Adafruit SSD1306 and Adafruit GFX and install it.
Don’t forget to select the board(Arduino UNO R4 Minima/WIFI) and the correct port before clicking the Upload button.
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
// OLED screen settings
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 64
#define OLED_RESET -1
#define OLED_ADDRESS 0x3C
Adafruit_SSD1306 display(
SCREEN_WIDTH,
SCREEN_HEIGHT,
&Wire,
OLED_RESET
// Button pins
// Blue button: crouch
// Red button: jump, start, and restart
const int CROUCH_BUTTON_PIN = 2;
const int JUMP_BUTTON_PIN = 12;
// Game layout
const int GROUND_Y = 55;
const int DINO_X = 10;
// Dinosaur sizes
const int DINO_STAND_WIDTH = 14;
const int DINO_STAND_HEIGHT = 18;
const int DINO_CROUCH_WIDTH = 21;
const int DINO_CROUCH_HEIGHT = 10;
// Dinosaur vertical position and movement speed
float dinoY = GROUND_Y - DINO_STAND_HEIGHT;
float dinoVelocityY = 0;
// Gravity pulls the dinosaur downward
// A negative jump velocity moves it upward
const float GRAVITY = 520.0;
const float JUMP_VELOCITY = -195.0;
// Dinosaur status
bool dinoOnGround = true;
bool isCrouching = false;
// Available obstacle types
enum ObstacleType {
SINGLE_CACTUS,
DOUBLE_CACTUS,
TRIPLE_CACTUS,
LARGE_CACTUS,
BIRD
// Stores the current obstacle information
struct Obstacle {
float x;
int y;
int width;
int height;
ObstacleType type;
Obstacle obstacle;
// Main game states
enum GameState {
START_SCREEN,
PLAYING,
GAME_OVER
GameState gameState = START_SCREEN;
// Score values
unsigned long score = 0;
unsigned long highScore = 0;
unsigned long lastScoreTime = 0;
// Current obstacle movement speed
float obstacleSpeed = 85.0;
// Frame and animation timing
unsigned long lastFrameTime = 0;
unsigned long lastAnimationTime = 0;
const unsigned long FRAME_INTERVAL = 30;
const unsigned long RUN_ANIMATION_INTERVAL = 120;
// Switches between two running animation frames
bool runFrame = false;
// Jump button debounce variables
bool lastJumpReading = HIGH;
bool stableJumpState = HIGH;
unsigned long lastJumpDebounceTime = 0;
const unsigned long BUTTON_DEBOUNCE_DELAY = 35;
// Use the Arduino internal pull-up resistors
pinMode(CROUCH_BUTTON_PIN, INPUT_PULLUP);
pinMode(JUMP_BUTTON_PIN, INPUT_PULLUP);
Serial.begin(9600);
// Stop the program if the OLED cannot be initialized
if (!display.begin(SSD1306_SWITCHCAPVCC, OLED_ADDRESS)) {
Serial.println("SSD1306 OLED initialization failed.");
while (true) {
display.clearDisplay();
display.setTextColor(SSD1306_WHITE);
display.display();
// Create a different obstacle sequence after each restart
randomSeed(analogRead(A0) ^ micros());
showStartScreen();
// Detect one complete press of the jump button
bool jumpPressed = readJumpButtonPressed();
// Start the game when the red button is pressed
if (gameState == START_SCREEN) {
if (jumpPressed) {
startGame();
return;
// Restart the game after a collision
if (gameState == GAME_OVER) {
if (jumpPressed) {
startGame();
return;
// The dinosaur can jump only while touching the ground
if (jumpPressed && dinoOnGround) {
startJump();
unsigned long currentTime = millis();
// Wait until it is time to draw the next frame
if (currentTime - lastFrameTime < FRAME_INTERVAL) {
return;
// Convert the time between frames into seconds
float deltaTime =
(currentTime - lastFrameTime) / 1000.0;
lastFrameTime = currentTime;
readCrouchButton();
updateDinosaur(deltaTime);
updateObstacle(deltaTime);
updateScore();
updateRunAnimation();
// End the game when the dinosaur touches an obstacle
if (checkCollision()) {
endGame();
return;
drawGame();
void startGame() {
gameState = PLAYING;
// Reset the score and game speed
score = 0;
// Return the dinosaur to its starting position
dinoVelocityY = 0;
// Reset all timing values
lastFrameTime = millis();
lastScoreTime = millis();
lastAnimationTime = millis();
// Create the first obstacle
spawnObstacle(true);
display.display();
// Draws one line of text in the horizontal center
void drawCenteredText(
const char *text,
int y,
int textSize
display.setTextSize(textSize);
int16_t x1;
int16_t y1;
uint16_t textWidth;
uint16_t textHeight;
display.getTextBounds(
text,
0,
y,
&x1,
&y1,
&textWidth,
&textHeight
int x = (SCREEN_WIDTH - textWidth) / 2;
display.setCursor(x, y);
display.print(text);
void showStartScreen() {
drawCenteredText("DINO RUN", 5, 2);
drawCenteredText("BLUE: CROUCH", 30, 1);
drawCenteredText("RED: JUMP", 42, 1);
drawCenteredText("PRESS RED", 55, 1);
display.display();
// Returns true only once for each jump button press
bool readJumpButtonPressed() {
bool currentReading =
digitalRead(JUMP_BUTTON_PIN);
// Restart the debounce timer when the reading changes
if (currentReading != lastJumpReading) {
lastJumpDebounceTime = millis();
bool buttonPressed = false;
// Accept the new state after it stays stable
if (
millis() - lastJumpDebounceTime >
if (currentReading != stableJumpState) {
stableJumpState = currentReading;
// INPUT_PULLUP means LOW is pressed
if (stableJumpState == LOW) {
buttonPressed = true;
lastJumpReading = currentReading;
return buttonPressed;
void readCrouchButton() {
bool crouchButtonPressed =
digitalRead(CROUCH_BUTTON_PIN) == LOW;
// Crouching is allowed only on the ground
if (dinoOnGround) {
isCrouching = crouchButtonPressed;
} else {
void startJump() {
// Cancel crouching before jumping
dinoOnGround = false;
// Give the dinosaur an upward starting speed
dinoVelocityY = JUMP_VELOCITY;
void updateDinosaur(float deltaTime) {
if (!dinoOnGround) {
// Apply gravity and update the vertical position
dinoVelocityY += GRAVITY * deltaTime;
dinoY += dinoVelocityY * deltaTime;
int standingGroundY =
// Stop the fall when the dinosaur reaches the ground
if (dinoY >= standingGroundY) {
dinoY = standingGroundY;
dinoVelocityY = 0;
} else {
// Change the drawing position when crouching
if (isCrouching) {
dinoY =
GROUND_Y - DINO_CROUCH_HEIGHT;
} else {
dinoY =
void spawnObstacle(bool firstObstacle) {
// Place the obstacle just outside the right side
if (firstObstacle) {
obstacle.x = SCREEN_WIDTH + 20;
} else {
obstacle.x =
SCREEN_WIDTH + random(10, 40);
int randomType = random(100);
// Unlock more obstacle types as the score increases
if (score < 40) {
if (randomType < 45) {
obstacle.type = SINGLE_CACTUS;
} else if (randomType < 80) {
obstacle.type = DOUBLE_CACTUS;
} else {
obstacle.type = LARGE_CACTUS;
} else if (score < 80) {
if (randomType < 25) {
} else if (randomType < 50) {
} else if (randomType < 75) {
obstacle.type = TRIPLE_CACTUS;
} else {
} else {
if (randomType < 20) {
} else if (randomType < 40) {
} else if (randomType < 60) {
} else {
obstacle.type = BIRD;
// Set the size and position for the selected obstacle
switch (obstacle.type) {
case SINGLE_CACTUS:
obstacle.width = 7;
obstacle.height = 13;
obstacle.y =
GROUND_Y - obstacle.height;
break;
case DOUBLE_CACTUS:
obstacle.width = 13;
obstacle.y =
break;
case TRIPLE_CACTUS:
obstacle.width = 19;
obstacle.y =
break;
case LARGE_CACTUS:
obstacle.width = 10;
obstacle.height = 19;
obstacle.y =
break;
case BIRD:
obstacle.width = 15;
obstacle.height = 8;
// The bird is low enough to require crouching
obstacle.y = GROUND_Y - 19;
break;
void updateObstacle(float deltaTime) {
// Move the obstacle from right to left
obstacle.x -=
obstacleSpeed * deltaTime;
// Create a new obstacle after the current one leaves
if (obstacle.x + obstacle.width < 0) {
spawnObstacle(false);
// Increase the game speed with the score
obstacleSpeed =
85.0 + score * 0.25;
// Limit the maximum speed
if (obstacleSpeed > 160.0) {
obstacleSpeed = 160.0;
void updateScore() {
// Add one point every 100 milliseconds
if (
currentTime - lastScoreTime >= 100
lastScoreTime = currentTime;
if (score < 9999) {
score++;
void updateRunAnimation() {
// Change the leg position while running
if (
dinoOnGround &&
currentTime - lastAnimationTime >=
lastAnimationTime = currentTime;
runFrame = !runFrame;
// Checks whether two rectangular areas overlap
bool rectanglesOverlap(
int ax,
int ay,
int aw,
int ah,
int bx,
int by,
int bw,
int bh
return (
ax < bx + bw &&
ax + aw > bx &&
ay < by + bh &&
ay + ah > by
bool checkCollision() {
int dinoWidth;
int dinoHeight;
int dinoCollisionY;
// Use a shorter collision box while crouching
if (isCrouching && dinoOnGround) {
dinoWidth = DINO_CROUCH_WIDTH;
dinoHeight = DINO_CROUCH_HEIGHT;
dinoCollisionY =
} else {
dinoWidth = DINO_STAND_WIDTH;
dinoHeight = DINO_STAND_HEIGHT;
dinoCollisionY = (int)dinoY;
// Slightly reduce both hitboxes to make collisions fairer
int dinoHitboxX = DINO_X + 2;
int dinoHitboxY = dinoCollisionY + 2;
int dinoHitboxWidth = dinoWidth - 4;
int dinoHitboxHeight = dinoHeight - 3;
int obstacleHitboxX =
(int)obstacle.x + 1;
int obstacleHitboxY =
obstacle.y + 1;
int obstacleHitboxWidth =
obstacle.width - 2;
int obstacleHitboxHeight =
obstacle.height - 2;
return rectanglesOverlap(
dinoHitboxX,
dinoHitboxY,
dinoHitboxWidth,
dinoHitboxHeight,
obstacleHitboxX,
obstacleHitboxY,
obstacleHitboxWidth,
void drawGame() {
// Draw the score last so it stays visible
drawGround();
drawDinosaur();
drawObstacle();
drawScore();
display.display();
void drawScore() {
display.setTextSize(1);
// Limit both displayed values to four digits
unsigned long shownHighScore =
highScore > 9999
? 9999
: highScore;
unsigned long shownScore =
score > 9999
? 9999
: score;
char scoreText[15];
snprintf(
scoreText,
sizeof(scoreText),
"HI %04lu %04lu",
shownHighScore,
shownScore
int16_t x1;
int16_t y1;
uint16_t textWidth;
scoreText,
0,
0,
&x1,
&y1,
&textWidth,
&textHeight
// Align the complete score text to the right edge
int scoreX =
SCREEN_WIDTH - textWidth;
if (scoreX < 0) {
scoreX = 0;
display.setCursor(scoreX, 0);
display.print(scoreText);
void drawGround() {
// Draw the main ground line
display.drawLine(
0,
GROUND_Y,
SCREEN_WIDTH - 1,
GROUND_Y,
SSD1306_WHITE
// Small moving pixels create a scrolling ground effect
int groundOffset =
((int)obstacle.x) % 16;
for (
int x = groundOffset;
x < SCREEN_WIDTH;
x += 16
if (x >= 0) {
display.drawPixel(
x,
GROUND_Y + 4,
SSD1306_WHITE
void drawDinosaur() {
drawCrouchingDinosaur(
DINO_X,
} else {
drawStandingDinosaur(
DINO_X,
(int)dinoY
void drawStandingDinosaur(int x, int y) {
// Head
display.fillRect(
x + 6,
y,
8,
7,
SSD1306_WHITE
// Eye
display.drawPixel(
x + 11,
y + 2,
SSD1306_BLACK
// Mouth
display.drawPixel(
x + 13,
y + 5,
SSD1306_BLACK
// Neck
display.fillRect(
x + 5,
y + 5,
5,
6,
SSD1306_WHITE
// Body
display.fillRect(
x + 3,
y + 8,
8,
7,
SSD1306_WHITE
// Tail
display.drawLine(
x + 3,
y + 10,
x,
y + 7,
SSD1306_WHITE
display.drawLine(
x + 2,
y + 11,
x,
y + 9,
SSD1306_WHITE
// Arm
display.drawLine(
x + 9,
y + 10,
x + 13,
y + 11,
SSD1306_WHITE
// Alternate the legs while running
if (dinoOnGround) {
if (runFrame) {
display.drawLine(
x + 5,
y + 14,
x + 3,
y + 17,
SSD1306_WHITE
display.drawLine(
x + 9,
y + 14,
x + 11,
y + 17,
SSD1306_WHITE
} else {
display.drawLine(
x + 5,
y + 14,
x + 7,
y + 17,
SSD1306_WHITE
display.drawLine(
x + 9,
y + 14,
x + 7,
y + 17,
SSD1306_WHITE
} else {
// Fixed leg position while jumping
display.drawLine(
x + 5,
y + 14,
x + 3,
y + 16,
SSD1306_WHITE
display.drawLine(
x + 9,
y + 14,
x + 11,
y + 16,
SSD1306_WHITE
void drawCrouchingDinosaur(int x, int y) {
// Longer and lower body
display.fillRect(
x + 3,
y + 3,
13,
6,
SSD1306_WHITE
// Head
display.fillRect(
x + 14,
y,
7,
7,
SSD1306_WHITE
// Eye
display.drawPixel(
x + 18,
y + 2,
SSD1306_BLACK
// Mouth
display.drawPixel(
x + 20,
y + 5,
SSD1306_BLACK
// Tail
display.drawLine(
x + 3,
y + 4,
x,
y + 1,
SSD1306_WHITE
display.drawLine(
x + 3,
y + 6,
x,
y + 4,
SSD1306_WHITE
// Alternate the crouching leg positions
if (runFrame) {
display.drawLine(
x + 6,
y + 8,
x + 4,
y + 9,
SSD1306_WHITE
display.drawLine(
x + 12,
y + 8,
x + 14,
y + 9,
SSD1306_WHITE
} else {
display.drawLine(
x + 7,
y + 8,
x + 9,
y + 9,
SSD1306_WHITE
display.drawLine(
x + 13,
y + 8,
x + 11,
y + 9,
SSD1306_WHITE
void drawObstacle() {
int x = (int)obstacle.x;
// Draw the correct shape for the current obstacle
case SINGLE_CACTUS:
drawSingleCactus(
x,
obstacle.y
break;
case DOUBLE_CACTUS:
drawDoubleCactus(
x,
obstacle.y
break;
case TRIPLE_CACTUS:
drawTripleCactus(
x,
obstacle.y
break;
case LARGE_CACTUS:
drawLargeCactus(
x,
obstacle.y
break;
case BIRD:
drawBird(
x,
obstacle.y
break;
void drawSingleCactus(int x, int y) {
// Main stem
display.fillRect(
x + 2,
y,
3,
13,
SSD1306_WHITE
// Left branch
display.fillRect(
x,
y + 5,
2,
3,
SSD1306_WHITE
// Right branch
display.fillRect(
x + 5,
y + 3,
2,
4,
SSD1306_WHITE
void drawDoubleCactus(int x, int y) {
// Draw two small cacti next to each other
drawSingleCactus(x, y);
drawSingleCactus(x + 6, y);
void drawTripleCactus(int x, int y) {
// Draw three small cacti next to each other
drawSingleCactus(x + 12, y);
void drawLargeCactus(int x, int y) {
// Main stem
display.fillRect(
x + 4,
y,
4,
19,
SSD1306_WHITE
// Left branch
display.fillRect(
x,
y + 7,
4,
4,
SSD1306_WHITE
// Right branch
display.fillRect(
x + 7,
y + 4,
3,
6,
SSD1306_WHITE
void drawBird(int x, int y) {
// Body
display.fillRect(
x + 5,
y + 3,
7,
4,
SSD1306_WHITE
// Head
display.fillRect(
x + 11,
y + 1,
4,
4,
SSD1306_WHITE
// Beak
display.drawPixel(
x + 15,
y + 3,
SSD1306_WHITE
// Eye
display.drawPixel(
x + 13,
y + 2,
SSD1306_BLACK
// Tail
display.drawLine(
x + 5,
y + 4,
x + 1,
y + 2,
SSD1306_WHITE
// Alternate the wing position
if (runFrame) {
display.drawLine(
x + 7,
y + 3,
x + 3,
y,
SSD1306_WHITE
display.drawLine(
x + 8,
y + 4,
x + 4,
y,
SSD1306_WHITE
} else {
display.drawLine(
x + 7,
y + 6,
x + 3,
y + 8,
SSD1306_WHITE
display.drawLine(
x + 8,
y + 6,
x + 5,
y + 8,
SSD1306_WHITE
void endGame() {
gameState = GAME_OVER;
// Save the new high score
if (score > highScore) {
highScore = score;
showGameOverScreen();
void showGameOverScreen() {
char scoreLine[16];
char bestLine[16];
score > 9999 ? 9999 : score;
highScore > 9999 ? 9999 : highScore;
snprintf(
scoreLine,
sizeof(scoreLine),
"SCORE: %04lu",
shownScore
snprintf(
bestLine,
sizeof(bestLine),
"BEST: %04lu",
shownHighScore
drawCenteredText("GAME OVER", 5, 2);
drawCenteredText(scoreLine, 31, 1);
drawCenteredText(bestLine, 42, 1);
display.display();
