RFID Access8.0
Kit purchase
Includes Arduino board |
PURCHASE LINK |
Elite Explorer Kit |
Arduino Uno R4 WiFi |
Inventor Lab Kit |
Arduino Uno R3 |
Course Introduction
In this lesson, we’ll build a 8.0 access-control system using the MFRC522 module, I2C LCD, a digital servo motor, buzzer module, traffic light.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R4 Minima/Arduino UNO R4 WIFI |
USB Type-C cable |
Breadboard |
Wires |
Several |
Traffic Light LED |
Buzzer Modudle |
7 |
MFRC522 Module |
8 |
Power Supply Module |
9 |
Digital Servo Motor |
10 |
I2C LCD 1602 |
Common Connections:
MFRC522 Module
IRQ: Connect to 7 on the ESP32.
SDA: Connect to 6 on the ESP32.
SCK: Connect to 5 on the ESP32.
MOSI: Connect to 4 on the ESP32.
MISO: Connect to 3 on the ESP32.
RST: Connect to 2 on the ESP32.
3.3V: Connect to breadboard’s passive power bus.
Traffic light LED
R: Connect to 11 on the Arduino.
Y: Connect to 10 on the Arduino.
G: Connect to 9 on the Arduino.
Buzzer Module
I/0: Connect to 12 on the Arduino.
+: Connect to breadboard’s red power bus.
-: Connect to breadboard’s negative power bus.
Digital Servo Motor
Connect to breadboard’s positive power bus.
Connect to 8 on the Arduino.
I2C LCD 1602
SDA: Connect to A4 on the Arduino.
SCL: Connect to A5 on the Arduino.
Writing the Code
The
RFID1library is used here. You can click hereRFID1.zipto download it.Don’t forget to select the board(Arduino UNO R4 WIFI) and the correct port before clicking the Upload button.
#include <rfid1.h>
#include <Servo.h>
#define ID_LEN 4 // Length of the RFID card UID (4 bytes)
RFID1 rfid;
Servo myServo;
LiquidCrystal_I2C lcd(0x27, 16, 2); // I2C LCD (address 0x27, 16 columns, 2 rows)
// Pin definitions
const int servoPin = 8;
const int buzzerPin = 12;
const int greenPin = 9;
const int yellowPin = 10;
const int redPin = 11;
// Authorized card UID (modify to your own card)
uchar userId[ID_LEN] = {0x33, 0xF8, 0xB8, 0x1A};
uchar userIdRead[ID_LEN];
int currentPos = 0; // Current servo angle
int targetPos = 0; // Target servo angle
bool busy = false; // Prevents scanning while gate animation plays
// Smoothly move the servo toward the target angle
void setServoAngle(int angle) {
targetPos = constrain(angle, 0, 90);
bool servoSmoothRun() {
static unsigned long lastStep = 0;
// Update every 15 ms for smooth movement
if (millis() - lastStep >= 15) {
lastStep = millis();
if (currentPos < targetPos) currentPos++;
else if (currentPos > targetPos) currentPos--;
else return true; // Movement completed
myServo.write(currentPos);
return false;
// Default LCD interface
void showNormal() {
lcd.clear();
lcd.setCursor(0,0); lcd.print("Gate Locked");
lcd.setCursor(0,1); lcd.print("Tap Your Card");
// Short beep for authorized card
void beepShort() {
tone(buzzerPin, 1800);
delay(80);
noTone(buzzerPin);
// Softer beep for denied card
void beepDeniedSoft() {
tone(buzzerPin, 1200);
delay(60);
noTone(buzzerPin);
// Read RFID UID
void getId() {
uchar status, str[MAX_LEN];
status = rfid.anticoll(str);
if (status == MI_OK) {
for (int i = 0; i < ID_LEN; i++)
userIdRead[i] = str[i];
rfid.halt();
// Compare scanned UID to authorized UID
bool idVerify() {
if (userIdRead[i] != userId[i]) return false;
return true;
void clearBuffer() {
userIdRead[i] = 0;
// Authorized card behavior
void authorizedSequence() {
busy = true;
beepShort();
lcd.clear();
lcd.setCursor(0,0); lcd.print("Access Granted");
lcd.setCursor(0,1); lcd.print("Please Pass");
digitalWrite(redPin, LOW);
digitalWrite(greenPin, LOW);
digitalWrite(yellowPin, LOW);
// Open gate
setServoAngle(90);
while (true) {
bool done = servoSmoothRun();
// Yellow blinking during opening
static unsigned long t = 0;
if (millis() - t >= 150) {
t = millis();
digitalWrite(yellowPin, !digitalRead(yellowPin));
if (done) break;
digitalWrite(greenPin, HIGH); // Green ON
delay(1000); // Wait 1 second
// Close gate
setServoAngle(0);
while (true) {
// Yellow blinking during closing
static unsigned long t2 = 0;
if (millis() - t2 >= 150) {
t2 = millis();
if (done) break;
digitalWrite(redPin, HIGH); // Red ON (locked)
showNormal();
busy = false;
// Denied card behavior — Version B (LED first → then sound)
void deniedSequence() {
busy = true;
lcd.clear();
lcd.setCursor(0,0); lcd.print("Access Denied");
lcd.setCursor(0,1); lcd.print("No Entry");
// Flash 4 times
for (int i = 0; i < 4; i++) {
// LED ON first (visual priority)
delay(80);
// Then beep (sound follows light)
delay(80);
noTone(buzzerPin);
// LED OFF
delay(80);
// Keep red ON after flashing
delay(500); // Keep LCD message visible
showNormal();
busy = false;
// setup()
// Runs once at startup
// Initialize RFID module (pins depend on library)
rfid.begin(7,5,4,3,6,2);
rfid.init();
// Attach servo to pin
myServo.attach(servoPin);
// Set pin modes
pinMode(buzzerPin, OUTPUT);
pinMode(greenPin, OUTPUT);
pinMode(yellowPin, OUTPUT);
pinMode(redPin, OUTPUT);
// Start with gate fully closed
myServo.write(0);
currentPos = 0;
targetPos = 0;
// Initialize LCD screen
lcd.init();
lcd.backlight();
showNormal(); // Display idle screen
// Default traffic light state
digitalWrite(redPin, HIGH); // Gate locked
// loop()
// Main program — runs forever
// If gate animation is running, ignore card scanning
if (busy) return;
// Check for RFID card
status = rfid.request(PICC_REQIDL, str);
// Card detected
getId();
// Authorized card
if (idVerify()) {
clearBuffer();
authorizedSequence();
// Unauthorized card
else {
clearBuffer();
deniedSequence();
