RFID Jukebox
Kit purchase
Includes Arduino board |
PURCHASE LINK |
Elite Explorer Kit |
Arduino Uno R4 WiFi |
Inventor Lab Kit |
Arduino Uno R3 |
Course Introduction
In this lesson, we’ll build a Jukebox using an MFRC522 module, an LED strip, and a passive buzzer.
First we’ll write track data to an RFID card, then scanning it will trigger music playback and lighting effects.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R4 Minima/Arduino UNO R4 WIFI |
USB Type-C cable |
Breadboard |
Wires |
Several |
Passive Buzzer |
MFRC522 Module |
7 |
Power Supply Module |
8 |
LED Strip |
Common Connections:
MFRC522 Module
SDA: Connect to 10 on the Arduino.
SCK: Connect to 13 on the Arduino.
MOSI: Connect to 11 on the Arduino.
MISO: Connect to 12 on the Arduino.
RST: Connect to 9 on the Arduino.
3.3V: Connect to breadboard’s passive power bus.
Passive Buzzer
+: Connect to 6 on the Arduino.
-: Connect to breadboard’s negative power bus.
LED Strip
Din: Connect to 3 on the Arduino.
+5V: Connect to breadboard’s passive power bus.
Writing the Code
To install the library, use the Arduino Library Manager and search for FastLED and install it.
To install the library, use the Arduino Library Manager and search for MFRC522 and install it.
Don’t forget to select the board(Arduino UNO R4 WIFI) and the correct port before clicking the Upload button.
Information writing
#include <SPI.h>
#include <MFRC522.h>
#define SS_PIN 10 // SDA (SS) pin for RFID module
#define RST_PIN 9 // RST pin for RFID module
MFRC522 rfid(SS_PIN, RST_PIN); // Create RFID reader instance
Serial.begin(9600); // Initialize serial communication
SPI.begin(); // Initialize SPI bus
rfid.PCD_Init(); // Initialize MFRC522 module
Serial.println("Place your RFID card near the reader to write a melody...");
if (!rfid.PICC_IsNewCardPresent() || !rfid.PICC_ReadCardSerial()) {
return;
// ==== Write data block ====
// Melody 1: Custom melody example (can be replaced)
// byte dataBlock[16] = {'C','D','E','F','G','A','B',' ',
// 'B','A','G','F','E','D','C'};
// Melody 2: Ode to Joy (commented out)
byte dataBlock[16] = {'E','E','F','G','G','F','E','D',
'C','C','D','E','E','D','D'};
// ==== End of melody selection ====
byte block = 4;
MFRC522::MIFARE_Key key;
for (byte i = 0; i < 6; i++) {
key.keyByte[i] = 0xFF;
MFRC522::StatusCode status = rfid.PCD_Authenticate(
MFRC522::PICC_CMD_MF_AUTH_KEY_A,
block,
&key,
&(rfid.uid)
if (status != MFRC522::STATUS_OK) {
Serial.print("Authentication failed: ");
Serial.println(rfid.GetStatusCodeName(status));
return;
status = rfid.MIFARE_Write(block, dataBlock, 16);
Serial.print("Write failed: ");
} else {
Serial.println("✅ Melody successfully written to RFID card!");
rfid.PICC_HaltA();
rfid.PCD_StopCrypto1();
delay(1500);
Information reading
#include <SPI.h>
#include <FastLED.h>
#define SS_PIN 10 // MFRC522 SDA/SS
#define RST_PIN 9 // MFRC522 RST
#define BUZZER_PIN 6 // Passive buzzer
#define LED_PIN 3 // WS2812 DIN
#define NUM_LEDS 8 // Number of LEDs
#define NOTE_DURATION 300 // ms per note
CRGB leds[NUM_LEDS];
// Base notes → fixed LED indices
const char baseNotes[8] = {'C','D','E','F','G','A','B',' '};
// Map note to LED index (C→0 … ' '→7)
int mapNoteToLED(char note) {
for (int i = 0; i < NUM_LEDS; i++) {
if (note == baseNotes[i]) return i;
return -1;
// Note → frequency
int getNoteFrequency(char note) {
switch (note) {
case 'C': return 261;
case 'D': return 294;
case 'E': return 329;
case 'F': return 349;
case 'G': return 392;
case 'A': return 440;
case 'B': return 493;
default: return 0; // rest
Serial.begin(9600);
SPI.begin();
rfid.PCD_Init();
pinMode(BUZZER_PIN, OUTPUT);
FastLED.addLeds<WS2812, LED_PIN, GRB>(leds, NUM_LEDS);
// startup all-blue
for (int i = 0; i < NUM_LEDS; i++) leds[i] = CRGB::Blue;
FastLED.show();
Serial.println("Waiting for RFID card to play melody...");
return;
// authenticate & read block 4
byte block = 4, buffer[18], size = sizeof(buffer);
for (byte i = 0; i < 6; i++) key.keyByte[i] = 0xFF;
auto status = rfid.PCD_Authenticate(
MFRC522::PICC_CMD_MF_AUTH_KEY_A, block, &key, &rfid.uid
Serial.print("Auth failed: ");
return;
status = rfid.MIFARE_Read(block, buffer, &size);
Serial.print("Read failed: ");
return;
Serial.print("Melody: ");
for (int i = 0; i < 16; i++) Serial.print((char)buffer[i]);
Serial.println();
// play with LED feedback
char lastNote = '\0';
int lastLED = -1;
for (int i = 0; i < 16; i++) {
char noteChar = (char)buffer[i];
int ledIdx = mapNoteToLED(noteChar);
int freq = getNoteFrequency(noteChar);
// sound
if (freq > 0) tone(BUZZER_PIN, freq, NOTE_DURATION);
// LED update: only change previous and current
if (lastLED >= 0) {
leds[lastLED] = CRGB::Blue;
if (ledIdx >= 0) {
leds[ledIdx] = CRGB::Red;
FastLED.show();
delay(NOTE_DURATION);
noTone(BUZZER_PIN);
lastNote = noteChar;
lastLED = ledIdx;
rfid.PICC_HaltA();
delay(1000);
