PIN Lock 1.0
Kit purchase
Includes Arduino board |
PURCHASE LINK |
Ultimate Sensor Kit |
Arduino Uno R4 Minima |
Universal Maker Sensor Kit |
Course Introduction
This project creates a PIN lock system with an Arduino, a 4×4 keypad, servo, LED, and buzzer.
Users enter the PIN to unlock the servo door. The LED shows lock status, and the buzzer gives audio feedback for key presses, success, and errors.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R4 Minima/Arduino UNO R4 WIFI |
USB Type-C cable |
Breadboard |
Wires |
Several |
Passive buzzer |
KeyPad |
7 |
LED |
8 |
Digital Servo Motor |
9 |
1kΩ resistor |
Common Connections:
Keypad
RowPins: Connect to 5 to 8 on the Arduino.
ColPins: Connect to 9 to 12 on the Arduino.
Digital Servo Motor
Connect to breadboard’s positive power bus.
Connect to breadboard’s negative power bus.
Connect to 9 on the Arduino.
Passive buzzer
+: Connect to 2 on the Arduino.
-: Connect to breadboard’s negative power bus.
LED
Connect the LEDs cathode to the negative power bus on the breadboard, and the LED anode to a 1kΩ resistor then to 3 on the Arduino.
Writing the Code
To install the library, use the Arduino Library Manager and search for Adafruit_Keypad install it.
Don’t forget to select the board(Arduino UNO R4 WIFI) and the correct port before clicking the Upload button.
#include <Adafruit_Keypad.h>
#include <Servo.h>
// -------- Pins --------
const int PIN_SERVO = 2; // Servo signal on D2
const int PIN_LED_R = 3; // Red LED on D3
const int PIN_BUZZER = 4; // Buzzer on D4
// -------- Keypad --------
const byte ROWS = 4, COLS = 4;
// If '#' becomes 'D' on your keypad, switch to VARIANT 1.
#define KEYPAD_VARIANT 0
#if KEYPAD_VARIANT == 0
char keys[ROWS][COLS] = {
{'1','2','3','A'},
{'4','5','6','B'},
{'7','8','9','C'},
{'*','0','#','D'}
#else
{'1','2','3','A'},
{'4','5','6','B'},
{'7','8','9','C'},
{'*','0','D','#'}
#endif
byte rowPins[ROWS] = {5, 6, 7, 8};
byte colPins[COLS] = {9, 10, 11, 12};
Adafruit_Keypad keypad = Adafruit_Keypad(makeKeymap(keys), rowPins, colPins, ROWS, COLS);
// -------- Servo (smooth, non-blocking) --------
Servo door;
int currentAngle = 90; // locked posture
int targetAngle = 90;
bool servoIsAttached = false;
unsigned long lastStepAt = 0;
const unsigned long stepInterval = 15; // 1° per 15ms
// -------- App State --------
enum State { STATE_LOCKED, STATE_INPUT, STATE_ACTION };
State state = STATE_LOCKED;
String pinCode = "1234";
const byte PIN_LEN = (byte)pinCode.length();
String inputBuf = "";
// -------- Error red LED blink scheduler (non-blocking) --------
const int ERROR_BLINK_COUNT = 6; // how many blinks on error
int errBlinkToggles = 0; // internal: toggles = blinks * 2
unsigned long lastErrBlinkAt = 0;
const unsigned long errBlinkInterval = 120; // ms between toggles
bool redBlinkState = false; // internal toggle state
// -------- Buzzer feedback (tone uses Timer2; Servo uses Timer1 on UNO) --------
void beepKey() { tone(PIN_BUZZER, 1800, 40); } // short key click
void beepOK() { tone(PIN_BUZZER, 900, 120); delay(20); tone(PIN_BUZZER, 1400, 120); } // small sync gap
void beepError() { tone(PIN_BUZZER, 350, 220); } // low, longer
void beepAction() { tone(PIN_BUZZER, 1200, 50); } // enter action hint
// -------- LED helpers --------
void setLED(bool r) { digitalWrite(PIN_LED_R, r ? HIGH : LOW); }
void setLockedLED() { setLED(true); } // red ON when locked
void setIdleLED() { setLED(false); } // red OFF during input/action
void triggerErrorBlink() {
// N blinks => 2N toggles
errBlinkToggles = ERROR_BLINK_COUNT * 2;
lastErrBlinkAt = 0; // force immediate
// -------- Servo helpers --------
void servoAttachOnce() {
if (!servoIsAttached) {
door.attach(PIN_SERVO);
servoIsAttached = true;
door.write(currentAngle); // sync immediately to avoid jump
delay(10); // tiny settle for first pulse
void servoDetachIfIdle() {
if (servoIsAttached) {
door.detach();
void setTarget(int ang) {
targetAngle = constrain(ang, 0, 180);
if (currentAngle != targetAngle) {
servoAttachOnce();
lastStepAt = millis(); // start stepping
bool atTarget() { return currentAngle == targetAngle; }
void tickServo(unsigned long now) {
if (currentAngle == targetAngle) { servoDetachIfIdle(); return; }
if ((long)(now - lastStepAt) >= (long)stepInterval) {
lastStepAt = now;
currentAngle += (currentAngle < targetAngle) ? 1 : -1;
// -------- Action sequence --------
const int lockAngle = 90;
const int openAngle = 0;
enum ActionPhase { PHASE_IDLE, PHASE_TO_ZERO, PHASE_WAIT_1S, PHASE_BACK_TO_90 };
ActionPhase actionPhase = PHASE_IDLE;
unsigned long actionPhaseStart = 0;
void startActionSequence() {
actionPhase = PHASE_TO_ZERO;
actionPhaseStart = millis();
setTarget(openAngle);
beepAction(); // brief audible hint
setIdleLED(); // unlocked visual: red OFF
void updateActionSequence(unsigned long now) {
switch (actionPhase) {
case PHASE_TO_ZERO:
if (atTarget()) {
actionPhase = PHASE_WAIT_1S;
actionPhaseStart = now;
break;
case PHASE_WAIT_1S:
if ((long)(now - actionPhaseStart) >= 1000) {
actionPhase = PHASE_BACK_TO_90;
setTarget(lockAngle);
break;
case PHASE_BACK_TO_90:
if (atTarget()) {
setLockedLED(); // red ON again
break;
default: break;
// -------- State transitions --------
void enterState(State s) {
state = s;
if (s == STATE_LOCKED) {
inputBuf = "";
} else if (s == STATE_INPUT) {
inputBuf = "";
setIdleLED(); // red OFF
} else if (s == STATE_ACTION) {
startActionSequence();
// -------- Key handling --------
void handleKey(char k) {
if (state == STATE_LOCKED) {
if (k == '*') {
// NEW: give audible feedback when entering INPUT from LOCKED
beepKey(); // <-- added so '*' immediately clicks
enterState(STATE_INPUT);
return;
if (state == STATE_INPUT) {
// audible key click for every key during input
beepKey();
if (k >= '0' && k <= '9') {
if (inputBuf.length() < PIN_LEN) inputBuf += k;
} else if (k == 'D') {
if (inputBuf.length() > 0) inputBuf.remove(inputBuf.length()-1);
} else if (k == 'C') {
inputBuf = "";
} else if (k == '#' || k == 'A') {
if (inputBuf.length() == PIN_LEN && inputBuf == pinCode) {
beepOK();
enterState(STATE_ACTION);
} else {
beepError();
triggerErrorBlink(); // red LED quick-blink N times
inputBuf = "";
return;
if (state == STATE_ACTION) {
// ignore keys during action
return;
// -------- LED scheduler (handles error blink) --------
void tickLEDs(unsigned long now) {
if (errBlinkToggles > 0) {
if (lastErrBlinkAt == 0 || (long)(now - lastErrBlinkAt) >= (long)errBlinkInterval) {
lastErrBlinkAt = now;
redBlinkState = !redBlinkState;
digitalWrite(PIN_LED_R, redBlinkState ? HIGH : LOW);
errBlinkToggles--;
if (errBlinkToggles == 0) {
// restore LED according to current state
if (state == STATE_LOCKED) setLockedLED();
else setIdleLED();
// -------- Setup & Loop --------
pinMode(PIN_LED_R, OUTPUT);
pinMode(PIN_BUZZER, OUTPUT);
setLockedLED();
keypad.begin();
// Servo boot settle at 90°, keep pulses a while, then detach
currentAngle = lockAngle;
targetAngle = lockAngle;
delay(700);
enterState(STATE_LOCKED);
unsigned long now = millis();
// keypad events
keypad.tick();
while (keypad.available()) {
keypadEvent e = keypad.read();
if (e.bit.EVENT == KEY_JUST_PRESSED) handleKey((char)e.bit.KEY);
// servo smoothing
tickServo(now);
// action phases
if (state == STATE_ACTION) updateActionSequence(now);
// LED blink scheduler
tickLEDs(now);
