Lamb Run
Kit purchase
Includes Arduino board |
PURCHASE LINK |
Ultimate Sensor Kit |
Arduino Uno R4 Minima |
Elite Explorer Kit |
Arduino Uno R4 WiFi |
3 in 1 Ultimate Starter Kit |
Universal Maker Sensor Kit |
Course Introduction
In this lesson, you’ll learn how to use a OLED Display Module, a button with the Arduino R4 UNO to create a Lamb Run Game. We’ll cover using the Adafruit SSD1306 and GFX libraries to display on the screen.
The OLED Screen will display the game screen, and players can use button to control the game.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R4 Minima |
USB Type-C cable |
Breadboard |
Wires |
Several |
Button |
OLED Display Module |
Common Connections:
OLED Display Module
SDA: Connect to SDA on the Arduino.
SCK: Connect to SCL on the Arduino.
Writing the Code
To install the library, use the Arduino Library Manager and search for Adafruit SSD1306 and Adafruit GFX and install it.
Don’t forget to select the board(Arduino UNO R4 Minima) and the correct port before clicking the Upload button.
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
// Pin definitions
#define BUTTON_PIN 2 // Button for jump and restart
#define OLED_RESET 4 // OLED reset pin
// OLED display parameters
const uint8_t SCREEN_WIDTH = 128;
const uint8_t SCREEN_HEIGHT = 64;
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
// Game frame timing and ground position
const unsigned long FRAME_RATE = 30; // Time per frame in milliseconds
const int GROUND_Y = 54; // Y coordinate of the ground line
// Sheep character parameters
const int SHEEP_X = 20; // Fixed X position of the sheep
const int SHEEP_W = 18; // Width of the sheep sprite
const int SHEEP_H = 16; // Height of the sheep sprite
const int JUMP_VELOCITY = -12; // Initial jump speed (upward)
const int GRAVITY = 2; // Gravity acceleration (downward)
int sheepY; // Current vertical position of the sheep
int sheepVY; // Current vertical velocity of the sheep
bool isJumping; // Is the sheep currently jumping?
int hangCounter; // Frames to pause at the top of the jump
// Player health (number of hearts)
int lifePoints; // 3 hearts total
// Distance traveled used as the score
int distanceTraveled;
// Obstacle parameters
const int MAX_OBSTACLES = 4;
const unsigned long SPAWN_INTERVAL = 1500; // Time between spawns (ms)
const int ROCK_W = 12;
const int ROCK_H = 12;
const int ROCK_SPEED = 2;
const int WOLF_W = 21;
const int WOLF_H = 16;
const int WOLF_SPEED = 3;
struct Obstacle {
bool active; // Is this obstacle active on screen?
int x, y; // Position of the obstacle
bool isWolf; // True if this obstacle is a wolf, false if rock
} obstacles[MAX_OBSTACLES];
unsigned long lastFrameTime; // Timestamp of last frame update
unsigned long lastSpawnTime; // Timestamp of last obstacle spawn
bool gameOver; // Has the game ended?
pinMode(BUTTON_PIN, INPUT_PULLUP);
display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
display.clearDisplay();
display.display();
randomSeed(analogRead(A0));
resetGame();
// Wait for next frame
if (millis() - lastFrameTime < FRAME_RATE) return;
lastFrameTime = millis();
// Restart game when button pressed after game over
if (gameOver && digitalRead(BUTTON_PIN) == LOW) {
resetGame();
// Update game state if not over
if (!gameOver) {
updateSheep();
spawnObstacles();
updateObstacles();
checkCollisions();
distanceTraveled++;
// Draw everything to the screen
drawScreen();
void resetGame() {
// Reset sheep position and state
sheepY = GROUND_Y - SHEEP_H;
sheepVY = 0;
isJumping = false;
hangCounter = 0;
// Reset health and score
lifePoints = 3;
distanceTraveled = 0;
gameOver = false;
// Clear obstacles
lastSpawnTime = millis();
for (int i = 0; i < MAX_OBSTACLES; i++) {
obstacles[i].active = false;
void updateSheep() {
// Start jump on button press
if (!isJumping && digitalRead(BUTTON_PIN) == LOW) {
isJumping = true;
sheepVY = JUMP_VELOCITY;
hangCounter = FRAME_RATE * 0.3; // Pause ~0.3 secs at apex
if (isJumping) {
// Apply vertical movement and gravity
sheepY += sheepVY;
sheepVY += GRAVITY;
// Pause at jump apex when starting to fall
if (sheepVY > 0 && hangCounter > 0) {
sheepVY = 0;
hangCounter--;
// Check landing
if (sheepY >= GROUND_Y - SHEEP_H) {
sheepVY = 0;
isJumping = false;
hangCounter = 0;
void spawnObstacles() {
// Spawn new obstacle after a delay
if (millis() - lastSpawnTime < SPAWN_INTERVAL) return;
if (!obstacles[i].active) {
obstacles[i].active = true;
obstacles[i].x = SCREEN_WIDTH;
obstacles[i].isWolf = (random(100) < 30);
obstacles[i].y = GROUND_Y - (obstacles[i].isWolf ? WOLF_H : ROCK_H);
break;
void updateObstacles() {
// Move obstacles left and deactivate off-screen ones
if (!obstacles[i].active) continue;
int speed = obstacles[i].isWolf ? WOLF_SPEED : ROCK_SPEED;
obstacles[i].x -= speed;
int w = obstacles[i].isWolf ? WOLF_W : ROCK_W;
if (obstacles[i].x + w < 0) {
void checkCollisions() {
// Simple bounding-box collision detection
int ox = obstacles[i].x;
int oy = obstacles[i].y;
int ow = obstacles[i].isWolf ? WOLF_W : ROCK_W;
int oh = obstacles[i].isWolf ? WOLF_H : ROCK_H;
bool hitX = (SHEEP_X + SHEEP_W > ox) && (SHEEP_X < ox + ow);
bool hitY = (sheepY + SHEEP_H > oy);
if (hitX && hitY) {
lifePoints--;
if (lifePoints <= 0) gameOver = true;
void drawScreen() {
display.drawLine(0, GROUND_Y, SCREEN_WIDTH, GROUND_Y, WHITE);
// Draw sheep
display.fillRect(SHEEP_X, sheepY + 4, 13, 8, WHITE);
display.fillRect(SHEEP_X+11, sheepY+2, 5, 5, WHITE);
display.drawTriangle(SHEEP_X-3, sheepY+10,
SHEEP_X, sheepY+8,
SHEEP_X, sheepY+13,
WHITE);
display.fillRect(SHEEP_X+3, sheepY+13, 3, 5, WHITE);
display.fillRect(SHEEP_X+8, sheepY+13, 3, 5, WHITE);
// Draw hearts (health)
for (int i = 0; i < lifePoints; i++) {
int hx = SCREEN_WIDTH - 10 - i*10;
display.fillCircle(hx+2, 4, 2, WHITE);
display.fillCircle(hx+5, 4, 2, WHITE);
display.fillTriangle(hx+1,6, hx+8,6, hx+4,10, WHITE);
// Draw obstacles and flipped wolves
if (obstacles[i].isWolf) {
// Wolf head left, body right
display.fillRect(ox, oy+3, 7, 5, WHITE);
display.fillRect(ox+7, oy+5, 14, 8, WHITE);
display.fillTriangle(ox+1,oy+3, ox,oy+1, ox+3,oy+2, WHITE);
display.fillTriangle(ox+5,oy+3, ox+7,oy+1, ox+6,oy+2, WHITE);
display.fillTriangle(ox+21,oy+8, ox+29,oy+5, ox+21,oy+10, WHITE);
} else {
// Rock made of three circles
display.fillCircle(ox+4, oy+9, 3, WHITE);
display.fillCircle(ox+8, oy+7, 4, WHITE);
display.fillCircle(ox+12,oy+9, 3, WHITE);
// Display game over and score in center
if (gameOver) {
display.setTextSize(1);
display.setTextColor(WHITE);
const char* msg = "GAME OVER";
int16_t tw = strlen(msg)*6;
display.setCursor((SCREEN_WIDTH - tw)/2, (SCREEN_HEIGHT - 8)/2 - 10);
display.print(msg);
char buf[16];
snprintf(buf, sizeof(buf), "SCORE: %d", distanceTraveled);
int16_t tw2 = strlen(buf)*6;
display.setCursor((SCREEN_WIDTH - tw2)/2, (SCREEN_HEIGHT - 8)/2 + 2);
display.print(buf);
display.display();
