Rain Alarm 1.0
  • 🎁 Looking for parts?Check out our all-in-one kits below — packed with components, beginner-friendly guides, and tons of fun.
Includes Arduino board
PURCHASE LINK
Electronic Kit
Elite Explorer Kit
Arduino Uno R4 WiFi
3 in 1 Ultimate Starter Kit
Arduino Uno R4 Minima
Course Introduction
In this lesson, you’ll build a simple raindrop alarm system using a raindrop sensor, a buzzer, and LEDs with the Arduino UNO R4.
When rain is detected, the sensor triggers the buzzer to beep and the LEDs to blink as a warning. When the surface is dry, all indicators turn off automatically.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino UNO R4 Minima
USB Type-C cable
Wires
Several
Passive Buzzer
Raindrop Detection Sensor Module
LED
1kΩ resistor
../_images/rain_drop_bb.png
Common Connections:
  • LEDS
    • Red: Connect the LED anode to 9,10 on the Arduino, and the cathode to a 1kΩ resistor, then to the negative power bus on the breadboard.
  • Passive Buzzer
    • +: Connect to 8 on the Arduino.
    • -: Connect to breadboard’s negative power bus.
  • D0: Connect to 7 on the Arduino.
  • VCC: Connect to breadboard’s passive power bus.
Writing the Code
  • Don’t forget to select the board(Arduino UNO R4 Minima) and the correct port before clicking the Upload button.
  Raindrop Alarm System
  - Reads digital output (DO) from a raindrops detection sensor module.
  - When rain is detected (DO = LOW), a 3-pin buzzer beeps and two LEDs blink.
  - When no rain (DO = HIGH), buzzer and LEDs stay OFF.
  Board: Arduino Uno R4 (or R3)
  Components: Raindrops Detection Sensor Module + 3-pin Active Buzzer Module + 2 LEDs
// -------- Pin Definitions --------
const int RAIN_DO_PIN = 7;   // Raindrops sensor DO pin (LOW when rain detected)
const int BUZZER_PIN  = 8;   // 3-pin buzzer module signal pin (S/IN)
const int LED1_PIN    = 9;   // LED1 pin
const int LED2_PIN    = 10;  // LED2 pin
// -------- Blink / Beep Timing (ms) --------
const unsigned long BLINK_INTERVAL_MS = 150;  // LED blink speed
const unsigned long BEEP_INTERVAL_MS  = 150;  // buzzer beep speed
// -------- State Variables --------
unsigned long lastBlinkMs = 0;
unsigned long lastBeepMs  = 0;
bool ledState = false;
bool buzzerState = false;
  pinMode(RAIN_DO_PIN, INPUT);     // DO is a digital output from the sensor
  pinMode(BUZZER_PIN, OUTPUT);     // buzzer module control
  pinMode(LED1_PIN, OUTPUT);       // LED1 control
  pinMode(LED2_PIN, OUTPUT);       // LED2 control
  // Ensure everything is OFF at startup
  digitalWrite(BUZZER_PIN, LOW);
  digitalWrite(LED1_PIN, LOW);
  digitalWrite(LED2_PIN, LOW);
  Serial.begin(9600);
  Serial.println("Raindrop Alarm System Ready (DO LOW = Rain Detected).");
  // Read raindrop sensor digital output
  int rainDO = digitalRead(RAIN_DO_PIN);
  // Print raw DO value for debugging
  Serial.println(rainDO);
  // If rain detected (DO is LOW)
  if (rainDO == LOW) {
    unsigned long now = millis();
    // ---- LED blinking ----
    if (now - lastBlinkMs >= BLINK_INTERVAL_MS) {
      lastBlinkMs = now;
      ledState = !ledState;
      digitalWrite(LED1_PIN, ledState ? HIGH : LOW);
      digitalWrite(LED2_PIN, ledState ? LOW : HIGH); // opposite blink for nicer effect
    // ---- Buzzer beeping ----
    if (now - lastBeepMs >= BEEP_INTERVAL_MS) {
      lastBeepMs = now;
      buzzerState = !buzzerState;
      digitalWrite(BUZZER_PIN, buzzerState ? HIGH : LOW);
  else {
    // No rain: turn everything OFF
    // Reset states so the next rain starts cleanly
    ledState = false;
  // Small delay to reduce serial spam (optional)
  delay(20);
