RFID Access10.0
Kit purchase
Includes Arduino board |
PURCHASE LINK |
Elite Explorer Kit |
Arduino Uno R4 WiFi |
Inventor Lab Kit |
Arduino Uno R3 |
Course Introduction
In this lesson, we’ll build a 10.0 access-control system using the I2C LCD, MFRC522 module, MQ-2 gas sensor, a digital servo motor, buzzer module, flame sensor module.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R4 Minima/Arduino UNO R4 WIFI |
USB Type-C cable |
Breadboard |
Wires |
Several |
Flame Sensor Module |
Buzzer Modudle |
7 |
MFRC522 Module |
8 |
Power Supply Module |
9 |
Digital Servo Motor |
10 |
MQ-2 Gas Sensor Module |
11 |
I2C LCD 1602 |
Common Connections:
MFRC522 Module
IRQ: Connect to 7 on the ESP32.
SDA: Connect to 6 on the ESP32.
SCK: Connect to 5 on the ESP32.
MOSI: Connect to 4 on the ESP32.
MISO: Connect to 3 on the ESP32.
RST: Connect to 2 on the ESP32.
3.3V: Connect to breadboard’s passive power bus.
A0: Connect to A0 on the Arduino.
Buzzer Module
I/0: Connect to 10 on the Arduino.
+: Connect to breadboard’s red power bus.
-: Connect to breadboard’s negative power bus.
Digital Servo Motor
Connect to breadboard’s positive power bus.
Connect to 9 on the Arduino.
Flame Sensor Module
D0: Connect to 11 on the Arduino.
GND: Connect to GND on the Arduino.
VCC: Connect to 5V on the Arduino.
I2C LCD 1602
SDA: Connect to A4 on the Arduino.
SCL: Connect to A5 on the Arduino.
Writing the Code
The
RFID1library is used here. You can click hereRFID1.zipto download it.To install the library, use the Arduino Library Manager and search for LiquidCrystal_I2C and install it.
Don’t forget to select the board(Arduino UNO R4 WIFI) and the correct port before clicking the Upload button.
#include <Wire.h>
#include <rfid1.h>
#include <Servo.h>
#define ID_LEN 4 // Length of RFID UID
// Pin definitions
const int servoPin = 9; // Servo motor for door
const int buzzerPin = 10; // Buzzer
const int flamePin = 11; // Flame sensor (digital)
const int smokePin = A0; // Smoke sensor (analog)
// Objects
RFID1 rfid;
Servo myServo;
LiquidCrystal_I2C lcd(0x27, 16, 2);
// Authorized RFID card UID
uchar userId[ID_LEN] = {0x36, 0xE2, 0xC4, 0xF7};
uchar userIdRead[ID_LEN];
// Servo movement control
int targetPos = 0; // Target angle
int currentPos = 0; // Current angle
// Door state after valid card
bool cardAction = false;
unsigned long cardTimer = 0;
// Emergency control flags
bool emergencyAlert = false;
bool emergencyRecovering = false;
unsigned long emergencyRecoverStart = 0;
// Smoke sensor threshold
int smokeValue = 0;
const int smokeThreshold = 200;
// System states for LCD display
enum SystemState {
STATE_BOOT,
STATE_IDLE,
STATE_ACCESS_GRANTED,
STATE_ACCESS_DENIED,
STATE_EMERGENCY
SystemState currentState = STATE_BOOT;
SystemState lastState = STATE_IDLE;
// Emergency type for LCD message
enum EmergencyType {
EM_NONE,
EM_SMOKE,
EM_FIRE,
EM_BOTH
EmergencyType emergencyType = EM_NONE;
// Set servo target angle (0–90 degrees)
void setServoAngle(int angle) {
targetPos = constrain(angle, 0, 90);
// Move servo smoothly without blocking the program
void servoSmoothRun() {
static unsigned long lastStep = 0;
if (millis() - lastStep >= 15) {
lastStep = millis();
if (currentPos < targetPos) currentPos++;
else if (currentPos > targetPos) currentPos--;
myServo.write(currentPos);
// Short beep for authorized card
void beepShort() {
tone(buzzerPin, 2000);
delay(80);
noTone(buzzerPin);
// Beep pattern for denied card (blocking)
void beepDenied() {
for (int i = 0; i < 4; i++) {
tone(buzzerPin, 1600);
delay(100);
noTone(buzzerPin);
delay(100);
// Alarm sound for emergency (non-blocking)
void beepAlarmNonBlock() {
static unsigned long t = 0;
static bool buz = false;
if (millis() - t > 120) {
t = millis();
buz = !buz;
if (buz) tone(buzzerPin, 1500);
else noTone(buzzerPin);
// Read RFID card UID
void getId() {
uchar status, str[MAX_LEN];
status = rfid.anticoll(str);
if (status == MI_OK) {
for (int i = 0; i < ID_LEN; i++) {
userIdRead[i] = str[i];
rfid.halt();
// Compare scanned UID with authorized UID
bool idVerify() {
if (userIdRead[i] != userId[i]) return false;
return true;
// Clear UID buffer after each scan
void clearBuffer() {
userIdRead[i] = 0;
// Update LCD only when system state changes
void updateLCD() {
if (currentState == lastState) return;
lcd.clear();
switch (currentState) {
case STATE_BOOT:
lcd.print("System Booting");
break;
case STATE_IDLE:
lcd.print("System Ready");
lcd.setCursor(0, 1);
lcd.print("Scan Your Card");
break;
case STATE_ACCESS_GRANTED:
lcd.print("Access Granted");
lcd.print("Door Opening");
break;
case STATE_ACCESS_DENIED:
lcd.print("Access Denied");
lcd.print("Try Again");
break;
case STATE_EMERGENCY:
lcd.print("Emergency");
if (emergencyType == EM_FIRE) lcd.print("Fire Detected!");
else if (emergencyType == EM_SMOKE) lcd.print("Smoke Detected!");
else if (emergencyType == EM_BOTH) lcd.print("Fire & Smoke!");
break;
lastState = currentState;
Wire.begin();
lcd.init();
lcd.backlight();
updateLCD();
delay(1000);
currentState = STATE_IDLE;
updateLCD();
rfid.begin(7, 5, 4, 3, 6, 2);
rfid.init();
pinMode(buzzerPin, OUTPUT);
pinMode(flamePin, INPUT);
myServo.attach(servoPin);
myServo.write(0);
smokeValue = analogRead(smokePin);
bool flameDetected = (digitalRead(flamePin) == LOW);
// Determine emergency type
if (smokeValue > smokeThreshold && flameDetected)
emergencyType = EM_BOTH;
else if (smokeValue > smokeThreshold)
emergencyType = EM_SMOKE;
else if (flameDetected)
emergencyType = EM_FIRE;
else
bool emergencyDetected = (emergencyType != EM_NONE);
bool allowRFID = true;
// Emergency handling
if (emergencyDetected) {
emergencyAlert = true;
setServoAngle(90); // Force door open
beepAlarmNonBlock();
allowRFID = false;
currentState = STATE_EMERGENCY;
else if (emergencyAlert) {
if (!emergencyRecovering) {
emergencyRecovering = true;
emergencyRecoverStart = millis();
if (millis() - emergencyRecoverStart < 1500) {
allowRFID = false;
else {
setServoAngle(0); // Start closing door
noTone(buzzerPin);
// RFID access control
if (allowRFID && !cardAction) {
status = rfid.request(PICC_REQIDL, str);
getId();
if (idVerify()) {
beepShort();
setServoAngle(90);
cardAction = true;
cardTimer = 0;
currentState = STATE_ACCESS_GRANTED;
else {
currentState = STATE_ACCESS_DENIED;
updateLCD(); // Show message immediately
beepDenied(); // Then beep
clearBuffer();
// Auto close door after valid card
if (cardAction) {
if (currentPos >= 90) {
if (cardTimer == 0) cardTimer = millis();
if (millis() - cardTimer >= 1500) {
setServoAngle(0);
if (currentPos <= 3 && targetPos == 0) {
cardAction = false;
cardTimer = 0;
// Change LCD back to idle only after door fully closes
if (!emergencyDetected &&
!emergencyAlert &&
targetPos == 0 &&
currentPos <= 3 &&
currentState == STATE_EMERGENCY) {
servoSmoothRun();
updateLCD();
