Gas Leak Monitor 4.0
Kit purchase
../_images/umsk_kit.png
Includes Arduino board
PURCHASE LINK
Ultimate Sensor Kit
Arduino Uno R4 Minima
Universal Maker Sensor Kit
Course Introduction
This Arduino project uses an MQ-2 gas sensor, LEDs, and a buzzer to detect gas concentration in real time.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino UNO R4 WIFI
USB Type-C cable
Wires
Several
Buzzer Modudle
LED
Several
MQ-2 Gas Sensor Module
1kΩ resistor
Several
../_images/Gas_Monitor4.0_bb.png
Common Connections:
  • MQ-2 Gas Sensor Module
    • A0: Connect to A0 on the Arduino.
  • Buzzer Modudle
    • I/O: Connect to 2 on the Arduino.
  • LED
    • Connect the LEDs cathode to the negative power bus on the breadboard, and the LEDs anode to 1kΩ resistor then to 4 to 11 on the Arduino.
Writing the Code
  • Don’t forget to select the board(Arduino UNO R4 WIFI) and the correct port before clicking the Upload button.
// -------- Pin definitions --------
#define PIN_SMOKE  A0    // MQ-2 smoke sensor
#define PIN_BUZZER 2     // Buzzer
int ledPins[] = {4, 5, 6, 7, 8, 9, 10, 11}; // LED bar
const int LED_COUNT = 8;
// -------- Thresholds --------
#define LED_START_TH 50     // LED starts lighting
#define LED_STEP     50     // One LED per 50
#define WARN_TH      100    // Warning threshold
#define ALARM_TH     300    // Alarm threshold (same as traffic light project)
// -------- Setup --------
  pinMode(PIN_BUZZER, OUTPUT);
  for (int i = 0; i < LED_COUNT; i++) {
    pinMode(ledPins[i], OUTPUT);
    digitalWrite(ledPins[i], LOW);
  Serial.begin(9600);
// -------- Main loop --------
  int smokeValue = analogRead(PIN_SMOKE); // Read smoke value
  ledBarDisplay(smokeValue);              // LED display
  buzzerService(smokeValue);              // Buzzer (same behavior as before)
  Serial.print("Smoke value: ");
  Serial.println(smokeValue);
// -------- LED bar display --------
// 50  -> D11
// 100 -> D11, D10
// 150 -> D11, D10, D9 ...
void ledBarDisplay(int value) {
  int ledCount = 0;
  if (value >= LED_START_TH) {
    ledCount = (value - LED_START_TH) / LED_STEP + 1;
  if (ledCount > LED_COUNT) {
    ledCount = LED_COUNT;
  // Light LEDs from D11 to D4
    int index = LED_COUNT - 1 - i;
    digitalWrite(ledPins[index], (i < ledCount) ? HIGH : LOW);
// -------- Buzzer behavior --------
// WARN  (100–299): short beep every 1 second (same as yellow)
// ALERT (>=300): fast alarm beep (same as red)
void buzzerService(int value) {
  unsigned long now = millis();
  // -------- ALERT mode --------
  if (value >= ALARM_TH) {
    const unsigned long period = 250;
    unsigned long phase = now % period;
    if (phase < 120) {
      tone(PIN_BUZZER, 2000);   // Alarm ON
    } else {
      noTone(PIN_BUZZER);       // Alarm OFF
    return;
  // -------- WARN mode --------
  if (value >= WARN_TH) {
    const unsigned long period = 1000;
    if (phase < 80) {
      tone(PIN_BUZZER, 1200);   // Short reminder beep
    } else {
      noTone(PIN_BUZZER);
    return;
  // -------- SAFE mode --------
  noTone(PIN_BUZZER);
