RFID Access9.0
Kit purchase
Includes Arduino board |
PURCHASE LINK |
Elite Explorer Kit |
Arduino Uno R4 WiFi |
Inventor Lab Kit |
Arduino Uno R3 |
Course Introduction
In this lesson, we’ll build a 9.0 access-control system using the MFRC522 module, MQ-2 gas sensor, a digital servo motor, buzzer module, flame sensor module.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R4 Minima/Arduino UNO R4 WIFI |
USB Type-C cable |
Breadboard |
Wires |
Several |
Flame Sensor Module |
Buzzer Modudle |
7 |
MFRC522 Module |
8 |
Power Supply Module |
9 |
Digital Servo Motor |
10 |
MQ-2 Gas Sensor Module |
Common Connections:
MFRC522 Module
IRQ: Connect to 7 on the ESP32.
SDA: Connect to 6 on the ESP32.
SCK: Connect to 5 on the ESP32.
MOSI: Connect to 4 on the ESP32.
MISO: Connect to 3 on the ESP32.
RST: Connect to 2 on the ESP32.
3.3V: Connect to breadboard’s passive power bus.
A0: Connect to A0 on the Arduino.
Buzzer Module
I/0: Connect to 10 on the Arduino.
+: Connect to breadboard’s red power bus.
-: Connect to breadboard’s negative power bus.
Digital Servo Motor
Connect to breadboard’s positive power bus.
Connect to 9 on the Arduino.
Flame Sensor Module
D0: Connect to 11 on the Arduino.
GND: Connect to GND on the Arduino.
VCC: Connect to 5V on the Arduino.
Writing the Code
The
RFID1library is used here. You can click hereRFID1.zipto download it.Don’t forget to select the board(Arduino UNO R4 WIFI) and the correct port before clicking the Upload button.
#include <rfid1.h>
#include <Servo.h>
#define ID_LEN 4 // RFID UID length
// Hardware pins
const int servoPin = 9; // Servo for door control
const int buzzerPin = 10; // Buzzer for sound feedback
const int flamePin = 11; // Flame sensor (digital)
const int smokePin = A0; // Smoke sensor (analog)
// Objects
RFID1 rfid;
Servo myServo;
// Authorized RFID card UID
uchar userId[ID_LEN] = {0x33, 0xF8, 0xB8, 0x1A};
uchar userIdRead[ID_LEN];
// Servo position control (smooth movement)
int targetPos = 0;
int currentPos = 0;
// Door action state (opened by RFID)
bool cardAction = false;
unsigned long cardTimer = 0;
// Emergency state (smoke or flame)
bool emergencyAlert = false;
bool emergencyRecovering = false;
unsigned long emergencyRecoverStart = 0;
// Smoke sensor threshold
int smokeValue = 0;
const int smokeThreshold = 200;
// Set the target angle for the servo
// The servo will move to this angle smoothly
void setServoAngle(int angle) {
targetPos = constrain(angle, 0, 90);
// Move the servo step by step without blocking the program
void servoSmoothRun() {
static unsigned long lastStep = 0;
if (millis() - lastStep >= 15) {
lastStep = millis();
if (currentPos < targetPos) currentPos++;
else if (currentPos > targetPos) currentPos--;
myServo.write(currentPos);
// Short beep for access granted
void beepShort() {
tone(buzzerPin, 2000);
delay(80);
noTone(buzzerPin);
// Beep pattern for access denied
void beepDenied() {
for (int i = 0; i < 4; i++) {
tone(buzzerPin, 1600);
delay(100);
noTone(buzzerPin);
delay(100);
// Continuous alarm sound without delay
void beepAlarmNonBlock() {
static unsigned long t = 0;
static bool buz = false;
if (millis() - t > 120) {
t = millis();
buz = !buz;
if (buz) tone(buzzerPin, 1500);
else noTone(buzzerPin);
// Read RFID card UID
void getId() {
uchar status, str[MAX_LEN];
status = rfid.anticoll(str);
if (status == MI_OK) {
for (int i = 0; i < ID_LEN; i++) {
userIdRead[i] = str[i];
rfid.halt();
// Check if the scanned card is authorized
bool idVerify() {
if (userIdRead[i] != userId[i]) return false;
return true;
// Clear UID buffer after each scan
void clearBuffer() {
userIdRead[i] = 0;
// Initialize RFID module (library-specific pins)
rfid.begin(7, 5, 4, 3, 6, 2);
rfid.init();
pinMode(buzzerPin, OUTPUT);
pinMode(flamePin, INPUT);
// Initialize servo (door closed)
myServo.attach(servoPin);
myServo.write(0);
currentPos = 0;
targetPos = 0;
// Read sensors
smokeValue = analogRead(smokePin);
bool flameDetected = (digitalRead(flamePin) == LOW);
bool emergencyDetected =
(smokeValue > smokeThreshold) || flameDetected;
bool allowRFID = true;
// Emergency logic: force door open
if (emergencyDetected) {
emergencyAlert = true;
setServoAngle(90);
beepAlarmNonBlock();
allowRFID = false;
else {
// Wait for emergency to fully clear before closing the door
if (emergencyAlert) {
if (!emergencyRecovering) {
emergencyRecovering = true;
emergencyRecoverStart = millis();
if (millis() - emergencyRecoverStart < 1500) {
allowRFID = false;
else {
setServoAngle(0);
noTone(buzzerPin);
allowRFID = true;
// RFID access control
if (allowRFID && !cardAction) {
status = rfid.request(PICC_REQIDL, str);
getId();
if (idVerify()) {
beepShort();
setServoAngle(90);
cardAction = true;
cardTimer = 0;
else {
beepDenied();
clearBuffer();
// Auto close door after RFID access
if (cardAction) {
if (currentPos >= 90) {
if (cardTimer == 0) cardTimer = millis();
if (millis() - cardTimer >= 1500) {
setServoAngle(0);
if (currentPos <= 3 && targetPos == 0) {
cardAction = false;
cardTimer = 0;
servoSmoothRun();
