TempHumid Monitor 2.0
Kit purchase
../_images/ultimate_sensor_kit.png
Includes Arduino board
PURCHASE LINK
Elite Explorer Kit
Arduino Uno R4 WiFi
3 in 1 Ultimate Starter Kit
Arduino Uno R4 Minima
Course Introduction
This Arduino project uses a DHT11 sensor, a 16×2 I2C LCD, LEDs, and a buzzer to monitor temperature and humidity in real time. It indicates comfort levels with different LED colors and buzzer patterns, switching between green, yellow, and red as temperature changes, while continuously updating readings on the display.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino UNO R4 WIFI
USB Type-C cable
Wires
Several
DHT-11 Module
I2C LCD 1602
Traffic Light LED
Buzzer Modudle
../_images/Temp_Monitor2.0_bb.png
Common Connections:
  • DHT-11 Module
    • OUT: Connect to 13 on the Arduino.
    • -: Connect to breadboard’s negative power bus.
    • +: Connect to breadboard’s red power bus.
  • I2C LCD 1602
    • SDA: Connect to A4 on the Arduino.
    • SCL: Connect to A5 on the Arduino.
  • Buzzer Modudle
    • I/O: Connect to 10 on the Arduino.
  • Traffic light LED
    • R: Connect to 5 on the Arduino.
    • Y: Connect to 4 on the Arduino.
    • G: Connect to 3 on the Arduino.
Writing the Code
  • Before you begin, you need to upload the pitches.h library to your Arduino. Copy the contents of the library into the Arduino IDE, save it as pitches.h and then upload it to your Arduino.
* Public Constants
#define NOTE_B0  31
#define NOTE_C1  33
#define NOTE_CS1 35
#define NOTE_D1  37
#define NOTE_DS1 39
#define NOTE_E1  41
#define NOTE_F1  44
#define NOTE_FS1 46
#define NOTE_G1  49
#define NOTE_GS1 52
#define NOTE_A1  55
#define NOTE_AS1 58
#define NOTE_B1  62
#define NOTE_C2  65
#define NOTE_CS2 69
#define NOTE_D2  73
#define NOTE_DS2 78
#define NOTE_E2  82
#define NOTE_F2  87
#define NOTE_FS2 93
#define NOTE_G2  98
#define NOTE_GS2 104
#define NOTE_A2  110
#define NOTE_AS2 117
#define NOTE_B2  123
#define NOTE_C3  131
#define NOTE_CS3 139
#define NOTE_D3  147
#define NOTE_DS3 156
#define NOTE_E3  165
#define NOTE_F3  175
#define NOTE_FS3 185
#define NOTE_G3  196
#define NOTE_GS3 208
#define NOTE_A3  220
#define NOTE_AS3 233
#define NOTE_B3  247
#define NOTE_C4  262
#define NOTE_CS4 277
#define NOTE_D4  294
#define NOTE_DS4 311
#define NOTE_E4  330
#define NOTE_F4  349
#define NOTE_FS4 370
#define NOTE_G4  392
#define NOTE_GS4 415
#define NOTE_A4  440
#define NOTE_AS4 466
#define NOTE_B4  494
#define NOTE_C5  523
#define NOTE_CS5 554
#define NOTE_D5  587
#define NOTE_DS5 622
#define NOTE_E5  659
#define NOTE_F5  698
#define NOTE_FS5 740
#define NOTE_G5  784
#define NOTE_GS5 831
#define NOTE_A5  880
#define NOTE_AS5 932
#define NOTE_B5  988
#define NOTE_C6  1047
#define NOTE_CS6 1109
#define NOTE_D6  1175
#define NOTE_DS6 1245
#define NOTE_E6  1319
#define NOTE_F6  1397
#define NOTE_FS6 1480
#define NOTE_G6  1568
#define NOTE_GS6 1661
#define NOTE_A6  1760
#define NOTE_AS6 1865
#define NOTE_B6  1976
#define NOTE_C7  2093
#define NOTE_CS7 2217
#define NOTE_D7  2349
#define NOTE_DS7 2489
#define NOTE_E7  2637
#define NOTE_F7  2794
#define NOTE_FS7 2960
#define NOTE_G7  3136
#define NOTE_GS7 3322
#define NOTE_A7  3520
#define NOTE_AS7 3729
#define NOTE_B7  3951
#define NOTE_C8  4186
#define NOTE_CS8 4435
#define NOTE_D8  4699
#define NOTE_DS8 4978
  • To install the library, use the Arduino Library Manager and search for DHT , LiquidCrystal_I2C and Adafruit GFX and install it.
  • Don’t forget to select the board(Arduino UNO R4 Minima) and the correct port before clicking the Upload button.
#include <Wire.h>
#include <DHT.h>
#include "pitches.h" // uses NOTE_E5 / NOTE_A5; you can replace with raw Hz if preferred
// -------- Pins --------
#define DHTPIN   12
#define DHTTYPE  DHT11
const int PIN_G   = 3;   // green LED
const int PIN_Y   = 4;   // yellow LED
const int PIN_R   = 5;   // red LED
const int PIN_BUZ = 10;  // passive buzzer
// -------- Objects (global, before setup/loop) --------
DHT dht(DHTPIN, DHTTYPE);
#define LCD_ADDR 0x27         // change to 0x3F if your LCD uses that address
LiquidCrystal_I2C lcd(LCD_ADDR, 16, 2);
// -------- Thresholds (by Temperature, Celsius) --------
const float TEMP_GREEN_MAX = 30.0; // <30  -> GREEN
const float TEMP_RED_MIN   = 35.0; // >=35 -> RED (else YELLOW)
const float HYST           = 0.5;  // hysteresis band
// -------- Timing (ms) --------
const unsigned long READ_INTERVAL = 2000; // DHT sample
const unsigned long LCD_INTERVAL  = 1000; // LCD refresh
// Yellow: 1 Hz blink (0.5 s on / 0.5 s off), buzzer sync with ON phase
const unsigned long Y_ON_MS  = 500;
const unsigned long Y_OFF_MS = 500;
// Red: fast blink (~4 Hz), buzzer sync with ON phase
const unsigned long R_ON_MS  = 120;
const unsigned long R_OFF_MS = 120;
// -------- Tones --------
const int NOTE_YELLOW = NOTE_E5;  // gentle hint
const int NOTE_RED    = NOTE_A5;  // urgent
// -------- State --------
enum State { GREEN, YELLOW, RED };
State stateNow = GREEN;
unsigned long tLastRead = 0;
unsigned long tLastLCD  = 0;
// Yellow blink phase
bool yOn = false;
unsigned long yPhaseStart = 0;
// Red blink phase
bool rOn = false;
unsigned long rPhaseStart = 0;
// Latest readings
float lastT = NAN, lastH = NAN;
// LCD diff buffers (to avoid flicker)
char line0_prev[17] = {0};
char line1_prev[17] = {0};
// ---------------- Helpers ----------------
void setLights(bool g, bool y, bool r) {
  digitalWrite(PIN_G, g ? HIGH : LOW);
  digitalWrite(PIN_Y, y ? HIGH : LOW);
  digitalWrite(PIN_R, r ? HIGH : LOW);
void stopBuzzer() { noTone(PIN_BUZ); }
// Decide state using temperature only (with hysteresis)
State decideStateByTemp(float tC) {
  if (isnan(tC)) return stateNow;
  switch (stateNow) {
    case GREEN:
      if (tC >= TEMP_GREEN_MAX + HYST) return (tC >= TEMP_RED_MIN) ? RED : YELLOW;
      return GREEN;
    case YELLOW:
      if (tC >= TEMP_RED_MIN + HYST)   return RED;
      if (tC <  TEMP_GREEN_MAX - HYST) return GREEN;
      return YELLOW;
    case RED:
      if (tC <  TEMP_RED_MIN - HYST)   return (tC < TEMP_GREEN_MAX - HYST) ? GREEN : YELLOW;
      return RED;
  return GREEN;
// Safe write to LCD only when content changed
void lcdWriteIfChanged(const char* l0, const char* l1) {
  if (strncmp(l0, line0_prev, 16) != 0) {
    lcd.setCursor(0, 0); lcd.print("                ");
    lcd.setCursor(0, 0); lcd.print(l0);
    strncpy(line0_prev, l0, 16);
  if (strncmp(l1, line1_prev, 16) != 0) {
    lcd.setCursor(0, 1); lcd.print("                ");
    lcd.setCursor(0, 1); lcd.print(l1);
    strncpy(line1_prev, l1, 16);
  pinMode(PIN_G, OUTPUT);
  pinMode(PIN_Y, OUTPUT);
  pinMode(PIN_R, OUTPUT);
  pinMode(PIN_BUZ, OUTPUT);
  Serial.begin(9600);
  dht.begin();
  lcd.init(); lcd.backlight(); lcd.clear();
  lcd.setCursor(0,0); lcd.print("Comfort Monitor");
  lcd.setCursor(0,1); lcd.print("Init...");
  setLights(true, false, false); // start GREEN
  yOn = false; yPhaseStart = millis();
  rOn = false; rPhaseStart = millis();
  unsigned long now = millis();
  // ---- DHT periodic read ----
  if (now - tLastRead >= READ_INTERVAL) {
    tLastRead = now;
    float h  = dht.readHumidity();
    float tC = dht.readTemperature(); // Celsius
    if (!isnan(h) && !isnan(tC)) {
      lastH = h;
      lastT = tC;
      State next = decideStateByTemp(lastT);
      if (next != stateNow) {
        stateNow = next;
        // reset blink phases on state change
        yOn = false; yPhaseStart = now;
        rOn = false; rPhaseStart = now;
        stopBuzzer();
      // Debug to Serial
      Serial.print(F("T=")); Serial.print(lastT,1); Serial.print(F("C  "));
      Serial.print(F("H=")); Serial.print(lastH,0); Serial.print(F("%  -> "));
      if (stateNow==GREEN) Serial.println(F("GREEN"));
      else if (stateNow==YELLOW) Serial.println(F("YELLOW"));
      else Serial.println(F("RED"));
    } else {
      Serial.println(F("DHT read failed"));
  // ---- Drive LEDs & buzzer (non-blocking, in sync) ----
  if (stateNow == GREEN) {
    stopBuzzer();
  else if (stateNow == YELLOW) {
    // 0.5s ON / 0.5s OFF; buzzer ON during ON phase
    unsigned long phaseDur = yOn ? Y_ON_MS : Y_OFF_MS;
    if (now - yPhaseStart >= phaseDur) {
      yOn = !yOn;
      yPhaseStart = now;
      if (yOn) tone(PIN_BUZ, NOTE_YELLOW, Y_ON_MS);
      else     stopBuzzer();
    setLights(false, yOn, false);
  else { // RED
    // fast blink; buzzer ON during ON phase
    unsigned long phaseDur = rOn ? R_ON_MS : R_OFF_MS;
    if (now - rPhaseStart >= phaseDur) {
      rOn = !rOn;
      rPhaseStart = now;
      if (rOn) tone(PIN_BUZ, NOTE_RED, R_ON_MS);
      else     stopBuzzer();
    setLights(false, false, rOn);
  // ---- LCD: Row0=Humidity, Row1=Temperature (no degree symbol) ----
  if (now - tLastLCD >= LCD_INTERVAL) {
    tLastLCD = now;
    // Build "Hum: 56%" without float printf (AVR friendly)
    char l0[17]; l0[0] = 0;
    if (!isnan(lastH)) {
      int hInt = (int)(lastH + 0.5f);
      // "Hum: " + 2-3 digits + "%"
      snprintf(l0, sizeof(l0), "Hum: %d%%", hInt);
    } else {
      snprintf(l0, sizeof(l0), "Hum: --%%");
    // Build "Temp: 25.4C" using dtostrf for float to string (AVR friendly)
    char tbuf[8]; // width=4, precision=1 -> e.g. "25.4"
    char l1[17]; l1[0] = 0;
    if (!isnan(lastT)) {
      dtostrf(lastT, 4, 1, tbuf); // (val, width, precision, buf)
      // ensure no leading spaces in narrow displays
      // Compose: "Temp: " + tbuf + "C"
      snprintf(l1, sizeof(l1), "Temp: %sC", tbuf);
    } else {
      snprintf(l1, sizeof(l1), "Temp: --.-C");
    l0[16] = '\0'; l1[16] = '\0';
    lcdWriteIfChanged(l0, l1);
