Barrier Gate 3.0
👉 Need faster updates or support? Click [here] join our Facebook community
👉 Or join our WhatsApp group: Click [here]
Kit purchase
Includes Arduino board |
PURCHASE LINK |
Ultimate Sensor Kit |
Arduino Uno R4 Minima |
Elite Explorer Kit |
Arduino Uno R4 WiFi |
3 in 1 Ultimate Starter Kit |
Universal Maker Sensor Kit |
Course Introduction
In this lesson, you’ll use a button, a traffic light LED module, and a servo motor with the Arduino to simulate a manual barrier gate system.
When the button is pressed, the red light turns off, the green light turns on, and the gate opens briefly to let a car pass.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R4 Minima/Arduino UNO R4 WIFI |
USB Type-C cable |
Breadboard |
Wires |
Several |
Button |
Digital Servo Motor |
7 |
LED |
8 |
1kΩ resistor |
Common Connections:
LED
Connect the LEDs cathode to the negative power bus on the breadboard, and the LEDs anode to a 1kΩ resistor then to 3, 4 on the Arduino.
Digital Servo Motor
Connect to breadboard’s positive power bus.
Connect to breadboard’s negative power bus.
Connect to 11 on the Arduino.
Button
Connect to 2 on the Arduino.
Writing the Code
Don’t forget to select the board(Arduino UNO R4 Minima/WIFI) and the correct port before clicking the Upload button.
#include <Servo.h>
const int buttonPin = 2; // Button connected to digital pin 2
const int greenLed = 3; // Green LED connected to digital pin 3
const int redLed = 4; // Red LED connected to digital pin 4
const int servoPin = 12; // Servo signal connected to digital pin 12
Servo barrierServo;
pinMode(buttonPin, INPUT_PULLUP); // Enable internal pull-up on button pin
pinMode(greenLed, OUTPUT);
pinMode(redLed, OUTPUT);
barrierServo.attach(servoPin); // Attach servo to pin 12
barrierServo.write(0); // Start with barrier closed (0°)
digitalWrite(redLed, HIGH); // Turn on red LED initially
digitalWrite(greenLed, LOW); // Turn off green LED initially
Serial.begin(9600); // For debugging
// Check if button is pressed (active LOW)
if (digitalRead(buttonPin) == LOW) {
Serial.println("Button pressed: Opening barrier");
digitalWrite(redLed, LOW); // Turn off red LED
digitalWrite(greenLed, HIGH); // Turn on green LED
barrierServo.write(90); // Raise barrier to 90°
delay(2000); // Wait for 2 seconds
barrierServo.write(0); // Lower barrier back to 0°
delay(100); // Short delay to debounce
