Mini Fan 5.0
  • 🎁 Looking for parts?Check out our all-in-one kits below — packed with components, beginner-friendly guides, and tons of fun.
Includes Arduino board
PURCHASE LINK
Elite Explorer Kit
Arduino Uno R4 WiFi
Universal Maker Sensor Kit
3 in 1 Ultimate Starter Kit
Arduino Uno R3
Course Introduction
In this lesson, you’ll build a smart fan controller using a rotary encoder, a servo, an LCD, and PWM motor control. Turning the encoder adjusts the servo angle, pressing the button switches between fan speed levels, and the LCD displays real-time angle and gear information.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino UNO R4 Minima/Arduino UNO R4 WIFI
USB Cable
Wires
Several
DC Motor
TA6586 - Motor Driver Chip
Rotary Encoder Module
Digital Servo Motor
I2C LCD 1602
../_images/Mini_Fan5.0_bb.png
Common Connections:
  • TA6586 - Motor Driver Chip
    • BI: Connect to 6 on the Arduino.
    • FI: Connect to 5 on the Arduino.
  • DC Motor
    • GND: Connect to TA6586 B0.
    • VCC: Connect to TA6586 F0.
  • Rotary Encoder Module
    • CLK: Connect to 12 on the Arduino.
    • DT: Connect to 11 on the Arduino.
    • SW: Connect to 10 on the Arduino.
  • Digital Servo Motor
    • Connect to breadboard’s positive power bus.
    • Connect to breadboard’s negative power bus.
    • Connect to 3 on the Arduino.
  • I2C LCD 1602
    • SDA: Connect to A4 on the Arduino.
    • SCL: Connect to A5 on the Arduino.
Writing the Code
  • To install the library, use the Arduino Library Manager and search for LiquidCrystal I2C and install it.
  • Don’t forget to select the board(Arduino UNO R4) and the correct port before clicking the Upload button.
#include <Servo.h>
#include <Wire.h>
// LCD using I2C (address may be 0x27 or 0x3F)
LiquidCrystal_I2C lcd(0x27, 16, 2);
// Fan output pins
const int fiPin = 5;
const int biPin = 6;
// Servo
Servo servo;
const int servoPin = 3;
// Rotary encoder pins
const int CLK = 12;    // rotation signal A
const int DT  = 11;    // rotation signal B
const int SW  = 10;    // push button (LOW when pressed)
// Encoder state tracking
int lastCLK = HIGH;
unsigned long lastPress = 0;
// Servo angle settings
int angle = 90;
const int angleMin = 45;
const int angleMax = 135;
const int angleStep = 5;   // rotate encoder = change 5 degrees
// Fan gear levels (0 = off)
int gear = 0;
int fanSpeed = 0;
// LCD update tracking
int lastAngle = -1;
int lastGear  = -1;
  // Motor pins
  pinMode(fiPin, OUTPUT);
  pinMode(biPin, OUTPUT);
  // Encoder pins with pull-ups for stable signals
  pinMode(CLK, INPUT_PULLUP);
  pinMode(DT,  INPUT_PULLUP);
  pinMode(SW,  INPUT_PULLUP);
  // Servo setup
  servo.attach(servoPin);
  servo.write(angle);
  // LCD setup
  lcd.init();
  lcd.backlight();
  lcd.clear();
  // Read rotary encoder rotation
  // Only allowed when fan gear > 0 (fan ON)
  // Falling edge of CLK gives stable step detection
  int currentCLK = digitalRead(CLK);
  if (currentCLK == LOW && lastCLK == HIGH) {
    if (gear > 0) {   // servo locked when gear = 0 (fan OFF)
      // Determine rotation direction
      if (digitalRead(DT) == HIGH) {
        angle += angleStep;    // clockwise
      } else {
        angle -= angleStep;    // counterclockwise
      // Keep angle within safe limits
      angle = constrain(angle, angleMin, angleMax);
      servo.write(angle);
  lastCLK = currentCLK;
  // Change fan gear (0 → 3) when encoder button pressed
  if (digitalRead(SW) == LOW) {
    if (millis() - lastPress > 300) {   // debounce
      gear++;
      if (gear > 3) gear = 0;           // loop back
      lastPress = millis();
  // Convert gear level to fan PWM value
  if (gear == 0) fanSpeed = 0;
  if (gear == 1) fanSpeed = 85;
  if (gear == 2) fanSpeed = 170;
  if (gear == 3) fanSpeed = 255;
  analogWrite(biPin, fanSpeed);
  analogWrite(fiPin, 0); // fixed LOW direction
  // Update LCD only when values change
  // Reduces I2C traffic → prevents encoder lag
  if (angle != lastAngle || gear != lastGear) {
    lcd.setCursor(0, 0);
    lcd.print("Angle:");
    lcd.print(angle);
    lcd.print("   ");
    lcd.setCursor(0, 1);
    lcd.print("Gear:");
    lcd.print(gear);
    lcd.print(" PWM:");
    lcd.print(fanSpeed);
    lcd.print("   ");
    lastAngle = angle;
    lastGear  = gear;
