Stacker Blocks 2.0
  • 🎁 Looking for parts?Check out our all-in-one kits below — packed with components, beginner-friendly guides, and tons of fun.
Includes Arduino board
PURCHASE LINK
Elite Explorer Kit
Arduino Uno R4 WiFi
Ultimate Sensor Kit
Arduino Uno R4 Minima
Electronic Kit
Universal Maker Sensor Kit
Course Introduction
In this lesson, you’ll learn how to use a MAX7219 Dot Matrix Module, a button with the Arduino R4 UNO to create a stacker blocks game.
The MAX7219 Dot Matrix Module will display the game, and players can use the button to control the gameplay in the stacker blocks game.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino UNO R4 Minima
USB Type-C cable
Wires
Several
Button
I2C LCD 1602
../_images/Stacker_Blocks2.0_bb.png
Common Connections:
  • MAX7219 Dot Matrix Module
    • CLK: Connect to 5 on the Arduino.
    • CS: Connect to 3 on the Arduino.
    • DIN: Connect to 6 on the Arduino.
  • Button
    • Connect to breadboard’s negative power bus.
    • Connect to 11 on the Arduino.
  • I2C LCD 1602
    • SDA: Connect to A4 on the Arduino.
    • SCL: Connect to A5 on the Arduino.
Writing the Code
  • To install the library, use the Arduino Library Manager and search for LiquidCrystal_I2C and LedControl and install it.
  • Don’t forget to select the board(Arduino UNO R4 Minima) and the correct port before clicking the Upload button.
#include "LedControl.h"
#include <Wire.h>
// ==== LED matrices (4 modules) ====
LedControl lc = LedControl(6, 5, 3, 4); // DIN=6, CLK=5, CS=3, 4 modules
// ==== LCD (I2C 16x2) ====
// Change 0x27 to 0x3F if your LCD uses that address
LiquidCrystal_I2C lcd(0x27, 16, 2);
// ==== Function prototypes ====
void updateDisplay();
void updatePlacedBlockDisplay(int layerIndex);
bool checkButton();
void clearMovingBlock();
void displayMovingBlock();
void playSuccessSound();
void playGameOverSound();
void updateMaxPosition();
void placeBlock();
void displayLayer(int level);
void updateLCD();
// ==== Constants ====
const int buttonPin = 11;    // Button input (active LOW)
const int buzzerPin = 9;     // Buzzer (optional)
const int blockColumns = 2;  // Each layer uses 2 columns
// ==== Game state ====
int currentWidth = 4;        // Vertical height of moving block
int currentPos = -4;         // Top row index (can be negative to allow off-screen)
int direction = 1;           // 1=down, -1=up
int moveDelay = 150;         // Movement speed (ms)
bool gameOver = false;
bool gameWon = false;
unsigned long lastMoveTime = 0;
int maxPosition = 0;         // 7 + currentWidth
int buttonPressCount = 0;
int currentLayerCount = 0;   // Placed layers count
struct BlockLayer {
  int position;   // top row
  int width;      // height in rows
  int startCol;   // start column (0..31)
  int colWidth;   // always 2
BlockLayer layers[32];
// ==== Helpers ====
void lcdPrintCentered(uint8_t row, const char* msg) {
  int len = 0;
  while (msg[len] != '\0') len++;       // simple strlen
  int col = (16 - len) / 2;
  if (col < 0) col = 0;                 // clamp left
  lcd.setCursor(col, row);
  lcd.print(msg);
// ==== Rendering (full refresh) ====
void updateDisplay() {
  for (int i = 0; i < 4; i++) lc.clearDisplay(i);
  // Draw placed layers
  for (int i = 0; i < currentLayerCount; i++) {
    int startCol = layers[i].startCol;
    int colWidth = layers[i].colWidth;
    for (int colOffset = 0; colOffset < colWidth; colOffset++) {
      int currentCol = startCol + colOffset;
      int module = currentCol / 8;
      int col = 7 - (currentCol % 8);
      if (module >= 4) continue;
      for (int j = 0; j < layers[i].width; j++) {
        int row = layers[i].position + j;
        if (row >= 0 && row < 8) lc.setLed(module, row, col, true);
  // Draw moving block if playing
  if (!gameOver) {
    int startCol = currentLayerCount * blockColumns;
    for (int colOffset = 0; colOffset < blockColumns; colOffset++) {
      for (int j = 0; j < currentWidth; j++) {
        int row = currentPos + j;
// ==== Rendering (placed layer, local) ====
void updatePlacedBlockDisplay(int layerIndex) {
  int startCol = layers[layerIndex].startCol;
  int colWidth = layers[layerIndex].colWidth;
    // clear that column
    for (int row = 0; row < 8; row++) lc.setLed(module, row, col, false);
    // redraw the layer pixels
    for (int j = 0; j < layers[layerIndex].width; j++) {
      int row = layers[layerIndex].position + j;
// ==== Button (active LOW, simple debounce) ====
bool checkButton() {
  if (digitalRead(buttonPin) == LOW) {
    delay(20);
      while (digitalRead(buttonPin) == LOW) {} // wait release
      return true;
  return false;
// (unused helper, kept for completeness)
void displayLayer(int level) {
  int startCol = layers[level].startCol;
  int colWidth = layers[level].colWidth;
    for (int j = 0; j < layers[level].width; j++) {
      int row = layers[level].position + j;
// ==== Moving block draw/clear ====
void displayMovingBlock() {
void clearMovingBlock() {
      if (row >= 0 && row < 8) lc.setLed(module, row, col, false);
// ==== Sounds ====
void playSuccessSound() {
  tone(buzzerPin, 523, 100);
void playGameOverSound() {
  tone(buzzerPin, 392, 200);
  delay(200);
  tone(buzzerPin, 349, 400);
  delay(400);
// ==== Motion bounds ====
void updateMaxPosition() {
  maxPosition = 7 + currentWidth;
// ==== LCD update ====
void updateLCD() {
  lcd.clear();
  if (gameOver) {
    // Centered end-state messages
    if (gameWon) {
      lcdPrintCentered(0, "You Win!");
    } else {
      lcdPrintCentered(0, "Game Over");
    // Second line tip (exactly 16 chars, auto-centered to col 0)
    lcdPrintCentered(1, "Press to Restart");
    return;
  // In-game info (Layers starts from 0 as requested)
  lcd.setCursor(0, 0); lcd.print("Blocks: "); lcd.print(currentWidth);
  lcd.setCursor(0, 1); lcd.print("Layers: "); lcd.print(currentLayerCount);
// ==== Place logic ====
void placeBlock() {
  buttonPressCount++;
  if (buttonPressCount == 4)  moveDelay = 120;
  else if (buttonPressCount == 8)  moveDelay = 90;
  else if (buttonPressCount == 12) moveDelay = 60;
  // First layer: no previous to compare
  if (currentLayerCount == 0) {
    layers[0].position = currentPos;
    layers[0].width = currentWidth;
    layers[0].startCol = 0;
    layers[0].colWidth = blockColumns;
    currentLayerCount = 1;
    currentPos = random(-currentWidth, maxPosition + 1);
    playSuccessSound();
    updatePlacedBlockDisplay(0);
    updateLCD();
    return;
  // Overlap with previous layer
  int prevPos = layers[currentLayerCount - 1].position;
  int prevWidth = layers[currentLayerCount - 1].width;
  int overlapTop = max(prevPos, currentPos);
  int overlapBottom = min(prevPos + prevWidth - 1, currentPos + currentWidth - 1);
  // No overlap -> game over
  if (overlapBottom < overlapTop) {
    clearMovingBlock();
    gameOver = true;
    gameWon = false;
    updateLCD();
    return;
  // Save overlap as new layer
  layers[currentLayerCount].position = overlapTop;
  layers[currentLayerCount].width = overlapBottom - overlapTop + 1;
  layers[currentLayerCount].startCol = currentLayerCount * blockColumns;
  layers[currentLayerCount].colWidth = blockColumns;
  // Update moving block height and count
  currentWidth = overlapBottom - overlapTop + 1;
  currentLayerCount++;
  playSuccessSound();
  // Win condition: 16 layers (32 columns)
  int totalUsedCols = currentLayerCount * blockColumns;
  if (totalUsedCols >= 32) {
    updatePlacedBlockDisplay(currentLayerCount - 1);
    gameOver = true;
    gameWon = true;
    updateLCD();
    return;
  updateLCD();
// ==== Setup ====
  pinMode(buttonPin, INPUT_PULLUP);
  pinMode(buzzerPin, OUTPUT);
  // LCD init
  Wire.begin();
  lcd.init();
  lcd.backlight();
  // Matrices init
  for (int i = 0; i < 4; i++) {
    lc.shutdown(i, false);
    lc.setIntensity(i, 8);
    lc.clearDisplay(i);
  currentPos = -currentWidth;
  randomSeed(analogRead(0));
  updateDisplay();
  updateLCD();
// ==== Loop ====
  // Game over: blink matrices; LCD shows final text
  if (gameOver) {
    static bool blinkState = false;
    static unsigned long lastBlinkTime = 0;
    if (millis() - lastBlinkTime > 500) {
      lastBlinkTime = millis();
      blinkState = !blinkState;
      if (blinkState) updateDisplay();
      else for (int i = 0; i < 4; i++) lc.clearDisplay(i);
    // Reset on button
    if (checkButton()) {
      gameOver = false;
      gameWon = false;
      currentWidth = 4;
      moveDelay = 150;
      direction = 1;
      updateDisplay();
      updateLCD();
    return;
  // Movement
  unsigned long currentTime = millis();
  if (currentTime - lastMoveTime > moveDelay) {
    lastMoveTime = currentTime;
    clearMovingBlock();
    currentPos += direction;
    // Reflect at bounds
    if (currentPos < -currentWidth) {
      int overshoot = (-currentWidth) - currentPos;
      currentPos = -currentWidth + overshoot;
      direction = -direction;
    } else if (currentPos > maxPosition) {
      int overshoot = currentPos - maxPosition;
      currentPos = maxPosition - overshoot - (currentWidth - 1);
  // Place on button
    placeBlock();
