Rrotary Sprinkler
Kit purchase
../_images/ultimate_sensor_kit.png
Includes Arduino board
PURCHASE LINK
Elite Explorer Kit
Arduino Uno R4 WiFi
3 in 1 Ultimate Starter Kit
Arduino Uno R4 Minima
Course Introduction
In this lesson, you’ll use a servo motor, a water pump driven by a TA6586 motor driver, and a button with Arduino to create a toggle-controlled watering system.
Pressing the button starts the pump and sweeps the servo back and forth to distribute water. Pressing it again stops the system, allowing for simple and hands-free operation.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino UNO R4 WIFI
USB Type-C cable
Wires
Several
Power Supply
Digital Servo Motor
TA6586 - Motor Driver Chip
Centrifugal Pump
Button
../_images/rotary_sprinkler_bb.png
Common Connections:
  • Digital Servo Motor
    • Connect to breadboard’s positive power bus.
    • Connect to breadboard’s negative power bus.
    • Connect to 9 on the Arduino.
  • TA6586 - Motor Driver Chip
    • BI: Connect to 6 on the Arduino.
    • FI: Connect to 5 on the Arduino.
  • Centrifugal Pump
    • Connect to TA6586 B0.
    • Connect to TA6586 F0.
  • Button
    • Connect to the breadboard’s negative power bus, and the other end to 2 on the Arduino board.
Writing the Code
  • Don’t forget to select the board(Arduino UNO R4 Minima/WIFI) and the correct port before clicking the Upload button.
#include <Servo.h>
Servo servo;
const int servoPin = 9;
const int motorIn1 = 5;  // TA6586 IN1 (FI)
const int motorIn2 = 6;  // TA6586 IN2 (BI)
const int buttonPin = 2;
bool isRunning = false;
bool lastButtonState = HIGH;
int servoPos = 0;    // Current servo position
int servoStep = 2;   // Servo movement step
unsigned long lastServoMove = 0;
const unsigned long servoInterval = 15; // Servo movement interval (ms)
  servo.attach(servoPin);
  pinMode(motorIn1, OUTPUT);
  pinMode(motorIn2, OUTPUT);
  pinMode(buttonPin, INPUT_PULLUP); // Use internal pull-up resistor
  stopSystem();
  bool buttonState = digitalRead(buttonPin);
  // Button toggle logic (falling edge detection)
  if (lastButtonState == HIGH && buttonState == LOW) {
    isRunning = !isRunning;
    delay(200); // Debounce
  lastButtonState = buttonState;
  if (isRunning) {
    // Keep water pump running
    digitalWrite(motorIn1, HIGH);
    digitalWrite(motorIn2, LOW);
    // Non-blocking servo sweeping
    unsigned long currentMillis = millis();
    if (currentMillis - lastServoMove >= servoInterval) {
      lastServoMove = currentMillis;
      servoPos += servoStep;
      if (servoPos >= 180 || servoPos <= 0) {
        servoStep = -servoStep;
      servo.write(servoPos);
  } else {
    stopSystem();
void stopSystem() {
  // Stop water pump
  digitalWrite(motorIn1, LOW);
  // Stop servo at current position
