Flame Monitor 1.0
Kit purchase
../_images/umsk_kit.png
Includes Arduino board
PURCHASE LINK
Ultimate Sensor Kit
Arduino Uno R4 Minima
Universal Maker Sensor Kit
Course Introduction
In this lesson, you’ll learn how to use a Flame Sensor and an OLED Display with the Arduino UNO R4. The OLED shows the flame intensity in real time and alerts with “FIRE!” when a flame is detected.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino UNO R4 Minima
USB Type-C cable
Wires
Several
Flame Sensor Module
OLED Display Module
../_images/Flame_Monitor1.0_bb.png
Common Connections:
  • Flame Sensor Module
    • A0: Connect to A0 on the Arduino.
  • OLED Display Module
    • SDA: Connect to A4 on the Arduino.
    • SCK: Connect to A5 on the Arduino.
Writing the Code
  • To install the library, use the Arduino Library Manager and search for Adafruit SSD1306 and Adafruit GFX and install it.
  • Don’t forget to select the board(Arduino UNO R4 Minima) and the correct port before clicking the Upload button.
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128   // OLED display width in pixels
#define SCREEN_HEIGHT 64   // OLED display height in pixels
#define OLED_RESET -1      // Reset pin (not used here)
#define SCREEN_ADDRESS 0x3C // I2C address of the OLED display
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
#define FLAME_PIN A0       // Analog pin connected to the flame sensor
  Serial.begin(9600);                         // Start serial communication
  Serial.println(F("Flame Sensor with OLED test!"));
  // Initialize the OLED display
  if (!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS)) {
    Serial.println(F("SSD1306 allocation failed"));
    for (;;); // Stop if OLED initialization fails
  display.clearDisplay();                     // Clear the display buffer
  display.setTextColor(WHITE);                // Set text color to white
  // Read the analog value from the flame sensor (0–1023)
  int rawValue = analogRead(FLAME_PIN);
  // Invert the value: lower = no fire, higher = fire detected
  int flameValue = 1023 - rawValue;
  // Detect fire if the value is higher than 300 (adjust as needed)
  bool fireDetected = (flameValue > 300);
  // Print sensor data to the Serial Monitor
  Serial.print("Flame Sensor Value: ");
  Serial.println(flameValue);
  if (fireDetected) {
    Serial.println("** Fire detected!!! **");
  } else {
    Serial.println("No Fire detected");
  // Clear previous display content
  // Display the flame intensity value
  display.setTextSize(1);              // Small text for label
  display.setCursor(0, 0);             // Set cursor at the top-left
  display.println("Flame Intensity:");
  display.setTextSize(2);              // Larger text for the value
  display.setCursor(0, 10);            // Move slightly down
  display.print(flameValue);
  // Display flame status message
  display.setCursor(0, 40);            // Lower part of the screen
  display.println("Status:");
  display.setTextSize(2);              // Larger text for status message
  display.setCursor(0, 50);            // Bottom area for output
  if (fireDetected) {
    display.print("FIRE!");
  } else {
    display.print("SAFE");
  // Update the OLED with new content
  display.display();
  // Short delay before next reading
  delay(500);
