Light tracing
Kit purchase
../_images/ultimate_sensor_kit.png
Includes Arduino board
PURCHASE LINK
Elite Explorer Kit
Arduino Uno R4 WiFi
3 in 1 Ultimate Starter Kit
Arduino Uno R4 Minima
Course Introduction
This Arduino project uses an LDR to detect ambient light changes and control a servo. The original code supports two LDRs, but this experiment uses only one. You can try adding a second LDR for further exploration.
The servo adjusts its angle based on light intensity, simulating responsive movement. A tolerance threshold reduces jitter from small changes. This system is ideal for light-following robots or sun trackers.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino UNO R4 Minima
USB Type-C cable
Wires
Several
Digital Servo Motor
Photoresistor Module
../_images/light_tracing_bb.png
Common Connections:
  • Digital Servo Motor
    • Connect to breadboard’s positive power bus.
    • Connect to breadboard’s negative power bus.
    • Connect to 9 on the Arduino.
  • Photoresistor Module
    • A0: Connect to A0 on the Arduino.
    • If there is another light-dependent resistor (LDR), then A0 Connect to A1 on the Arduino.
Writing the Code
  • Don’t forget to select the board(Arduino UNO R4 Minima/WIFI) and the correct port before clicking the Upload button.
#include <Servo.h>
Servo myServo;
const int ldrLeft = A0;
const int ldrRight = A1;
int servoPin = 9;
int pos = 90; // Initial angle centered
int tolerance = 10; // Threshold to reduce jitter
  myServo.attach(servoPin);
  myServo.write(pos);
  Serial.begin(9600);
  int leftValue = analogRead(ldrLeft);
  int rightValue = analogRead(ldrRight);
  int difference = leftValue - rightValue;
  Serial.print("Left: ");
  Serial.print(leftValue);
  Serial.print(" | Right: ");
  Serial.print(rightValue);
  Serial.print(" | Diff: ");
  Serial.println(difference);
  if (abs(difference) > tolerance) {
    if (difference > 0 && pos < 360) {
      pos++;
    } else if (difference < 0 && pos > 0) {
      pos--;
    myServo.write(pos);
  delay(20); // Proper delay to avoid movement too fast
