Parking Lot 2.0
Kit purchase
../_images/ultimate_sensor_kit.png
Includes Arduino board
PURCHASE LINK
Elite Explorer Kit
Arduino Uno R4 WiFi
3 in 1 Ultimate Starter Kit
Arduino Uno R4 Minima
Course Introduction
In this project, you’ll use an Arduino board, an ultrasonic sensor, a servo motor, LEDs, and a buzzer to create a smart parking gate system.
The system automatically opens the gate for incoming vehicles, tracks the number of cars, and uses LEDs and a buzzer to indicate when the lot is full. A reset button allows manual system control for testing or restarting.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino UNO R4 Minima/Arduino UNO R4 WIFI
USB Type-C cable
Wires
Several
Ultrasonic Sensor Module
Digital Servo Motor
Active Buzzer
LED
Button
../_images/parking_lot2.0_bb.png
Common Connections:
  • Button
    • Connect to breadboard’s negative power bus.
    • Connect to 9 on the Arduino.
  • Ultrasonic Sensor Module
    • Trig: Connect to 2 on the Arduino.
    • Echo: Connect to 3 on the Arduino.
  • Active Buzzer
    • +: Connect to 8 on the Arduino.
    • -: Connect to breadboard’s negative power bus.
  • Digital Servo Motor
    • Connect to breadboard’s positive power bus.
    • Connect to 4 on the Arduino.
  • LEDS
    • Connect the LED anode to 5~7 on the Arduino, and the cathode to a 1kΩ resistor, then to the negative power bus on the breadboard.
Writing the Code
  • Don’t forget to select the board(Arduino UNO R4 Minima/WIFI) and the correct port before clicking the Upload button.
#include <Servo.h>
// Pins
#define TRIG_PIN 2
#define ECHO_PIN 3
#define SERVO_PIN 4
#define LED1 5
#define LED2 6
#define LED3 7
#define BUZZER 8
#define BUTTON 9
// Objects
Servo gateServo;
// Variables
int vehicleCount = 0;
bool alertMode = false;
long distance;
unsigned long lastFlashTime = 0;
bool ledState = false;
  Serial.begin(9600);
  pinMode(TRIG_PIN, OUTPUT);
  pinMode(ECHO_PIN, INPUT);
  pinMode(LED1, OUTPUT);
  pinMode(LED2, OUTPUT);
  pinMode(LED3, OUTPUT);
  pinMode(BUZZER, OUTPUT);
  pinMode(BUTTON, INPUT_PULLUP); // Using internal pull-up
  gateServo.attach(SERVO_PIN);
  gateServo.write(0); // Gate down
  // Turn off LEDs and buzzer at start
  digitalWrite(LED1, LOW);
  digitalWrite(LED2, LOW);
  digitalWrite(LED3, LOW);
  digitalWrite(BUZZER, LOW);
  distance = getDistance();
  // Button pressed: reset system
  if (digitalRead(BUTTON) == LOW) {
    vehicleCount = 0;
    alertMode = false;
    Serial.println("System Reset");
    delay(500); // Debounce
  // Vehicle detected within 10 cm range
  if (distance > 0 && distance < 10) {
    handleVehicleDetection();
    delay(1000); // Prevent multiple counts for same vehicle
  // If over capacity and vehicle still there, alert
  if (vehicleCount >= 3 && distance > 0 && distance < 10) {
    alertMode = true;
  } else {
    alertMode = false;
  if (alertMode) {
    flashLEDs();
    digitalWrite(BUZZER, HIGH);
// Function to measure distance from ultrasonic sensor
long getDistance() {
  digitalWrite(TRIG_PIN, LOW);
  delayMicroseconds(2);
  digitalWrite(TRIG_PIN, HIGH);
  delayMicroseconds(10);
  long duration = pulseIn(ECHO_PIN, HIGH, 30000); // Timeout 30ms
  if (duration == 0) return -1; // Timeout
  return duration * 0.034 / 2;
// Vehicle enters: open gate, count, close
void handleVehicleDetection() {
  if (vehicleCount < 3) {
    vehicleCount++;
    Serial.print("Vehicle Count: ");
    Serial.println(vehicleCount);
    updateLEDs();
    gateServo.write(90); // Gate up
    delay(3000);
// Update LEDs based on vehicle count
void updateLEDs() {
  digitalWrite(LED1, vehicleCount >= 1 ? HIGH : LOW);
  digitalWrite(LED2, vehicleCount >= 2 ? HIGH : LOW);
  digitalWrite(LED3, vehicleCount >= 3 ? HIGH : LOW);
// Flash LEDs in alert mode
void flashLEDs() {
  unsigned long now = millis();
  if (now - lastFlashTime >= 500) {
    ledState = !ledState;
    digitalWrite(LED1, ledState);
    digitalWrite(LED2, ledState);
    digitalWrite(LED3, ledState);
    lastFlashTime = now;
