Light Sensing
  • 🎁 Looking for parts?Check out our all-in-one kits below — packed with components, beginner-friendly guides, and tons of fun.
Includes Arduino board
PURCHASE LINK
Ultimate Sensor Kit
Arduino Uno R4 Minima
Elite Explorer Kit
Arduino Uno R4 WiFi
3 in 1 Ultimate Starter Kit
Course Introduction
In this lesson, you’ll build a light detection system using an Arduino UNO R4, an LDR, and a TM1637 display.
The display shows a 0–100 value that increases with light intensity, allowing real-time brightness monitoring.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino UNO R4 Minima/Arduino UNO R4 WIFI
USB Type-C cable
Wires
Several
4-Digit Segment Display Module
Photoresistor
10kΩ resistor
../_images/light_measure_bb.png
Common Connections:
  • Photoresistor
    • Connect to A0 on the Arduino. Then connect a 10k resistor to the negative power bus of the breadboard
    • Connect to breadboard’s red power bus.
  • 4-Digit Segment Display Module
    • CLK: Connect to 3 on the Arduino.
    • DIO: Connect to 2 on the Arduino.
Writing the Code
  • To install the library, use the Arduino Library Manager and search for TM1637Display and install it.
  • Don’t forget to select the board(Arduino UNO R4 Minima/WIFI) and the correct port before clicking the Upload button.
#include <TM1637Display.h>
// -------- TM1637 pins (UNO R4) --------
#define CLK_PIN 3     // TM1637 CLK
#define DIO_PIN 2     // TM1637 DIO
TM1637Display display(CLK_PIN, DIO_PIN);
// -------- LDR analog pin --------
const int LDR_PIN = A0;
// -------- timing --------
const unsigned long SAMPLE_MS = 50;    // sample period
const unsigned long CALIB_MS  = 3000;  // auto-calibration duration
// auto-calibration range (updated during first CALIB_MS)
int adcMinSeen = 1023;
int adcMaxSeen = 0;
// simple low-pass filter (EMA)
float ema = 0.0f;
const float ALPHA = 0.25f; // 0~1, higher = more responsive
unsigned long t0;
  display.setBrightness(7);
  display.clear();
  // UNO R4 analogRead default is 0~1023 (10-bit), keep default
  // For higher resolution, you can enable: analogReadResolution(12); // 0~4095
  // Show "CAL " during calibration
  display.showNumberDecEx(0, 0, true, 4, 0); // clear
  display.setSegments((const uint8_t[]){0x39, 0x77, 0x38, 0x00}); // display "CAL "
  // If your library version doesn't support this, you can comment these two lines
  t0 = millis();
  static unsigned long last = 0;
  unsigned long now = millis();
  if (now - last < SAMPLE_MS) return;
  last = now;
  int adc = analogRead(LDR_PIN);   // 0(dark)~1023(bright) or reversed depending on wiring
  // 1) Auto-calibration during the first 3 seconds
  if (now - t0 < CALIB_MS) {
    if (adc < adcMinSeen) adcMinSeen = adc;
    if (adc > adcMaxSeen) adcMaxSeen = adc;
    return; // During calibration, do not update display
  // If calibration range is too narrow, set default values
  if (adcMaxSeen - adcMinSeen < 50) {
    adcMinSeen = 100;
    adcMaxSeen = 900;
  // 2) Map ADC to 0~100 (based on calibration range)
  // Regardless of wiring direction, map so that brighter = larger value
  int span = adcMaxSeen - adcMinSeen;
  long mapped = (long)(adc - adcMinSeen) * 100 / (span <= 0 ? 1 : span);
  if (mapped < 0)   mapped = 0;
  if (mapped > 100) mapped = 100;
  // 3) EMA smoothing
  ema = (1.0f - ALPHA) * ema + ALPHA * mapped;
  int value = (int)(ema + 0.5f);
  // 4) Display on TM1637 (0~100)
  // Right aligned: e.g. “  85”, “ 100”
  display.showNumberDec(value, true, 3, 1); // use last 3 digits for better centering
  // If you want right alignment using all 4 digits: display.showNumberDec(value, true);
  // (Optional) Update min/max boundaries slowly over time to adapt to environment:
  // if (value < 5)  adcMinSeen = (adcMinSeen*3 + adc)/4;
  // if (value > 95) adcMaxSeen = (adcMaxSeen*3 + adc)/4;
