Basketball Game 1.0
Kit purchase
../_images/umsk_kit.png
Includes Arduino board
PURCHASE LINK
Ultimate Sensor Kit
Arduino Uno R4 Minima
Universal Maker Sensor Kit
Course Introduction
In this lesson, you’ll learn how to build a simple basketball score counter using an Arduino, an IR obstacle avoidance sensor, and a TM1637 4-digit display.
This experiment simulates real-time scoring by detecting each successful shot and automatically updating the score on the display.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino UNO R4 Minima/Arduino UNO R4 WIFI
USB Type-C cable
Wires
Several
4-Digit Segment Display Module
IR Obstacle Avoidance Sensor Module
../_images/basketball_bb.png
Common Connections:
  • IR Obstacle Avoidance Sensor Module
    • OUT: Connect to 2 on the Arduino.
  • 4-Digit Segment Display Module
    • CLK: Connect to 9 on the Arduino.
    • DIO: Connect to 8 on the Arduino.
Writing the Code
  • To install the library, use the Arduino Library Manager and search for TM1637Display and install it.
  • Don’t forget to select the board(Arduino UNO R4 Minima/WIFI) and the correct port before clicking the Upload button.
#include <TM1637Display.h>
// TM1637 pins
const int CLK_PIN = 9;
const int DIO_PIN = 8;
// IR sensor pin
const int IR_PIN = 2;
// Create display object
TM1637Display display(CLK_PIN, DIO_PIN);
// Score value
int score = 0;
// Sensor states
bool lastSensorState = HIGH;
// Anti-double-count timing
unsigned long lastScoreTime = 0;
const unsigned long cooldownTime = 800;  // ms
  // IR sensor input
  pinMode(IR_PIN, INPUT);
  // Set display brightness (0-7)
  display.setBrightness(7);
  // Show initial score
  display.showNumberDec(score, true);
  // Read initial sensor state
  lastSensorState = digitalRead(IR_PIN);
  bool currentSensorState = digitalRead(IR_PIN);
  // Count only when sensor changes from unblocked to blocked
  // Many IR obstacle modules output LOW when obstacle is detected
  if (lastSensorState == HIGH && currentSensorState == LOW) {
    if (millis() - lastScoreTime > cooldownTime) {
      score++;
      // Limit display range to 9999
      if (score > 9999) {
        score = 9999;
      lastScoreTime = millis();
  lastSensorState = currentSensorState;
