Water Level 2.0
Kit purchase
Includes Arduino board |
PURCHASE LINK |
Elite Explorer Kit |
Arduino Uno R4 WiFi |
3 in 1 Ultimate Starter Kit |
Arduino Uno R4 Minima |
Course Introduction
In this lesson, you’ll learn how to build a simple water level indicator using an analog water level sensor and 8 LEDs with the Arduino UNO R4.
As the water level rises, more LEDs light up to visually display the current level in real time.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R4 Minima/Arduino UNO R4 wifi |
USB Cable |
Breadboard |
Wires |
Several |
Water Level Detection Module |
Resistor |
1KΩ |
7 |
LED |
Several |
Common Connections:
A: Connect to A0 on the Arduino.
G: Connect to breadboard’s negative power bus.
V: Connect to breadboard’s red power bus.
LEDS
Connect the LED cathode to a 1KΩ resistor then to the negative power bus on the breadboard, and the anode to the 2~9 on the Arduino.
Writing the Code
Don’t forget to select the board(Arduino UNO R4 Minima/WIFI) and the correct port before clicking the Upload button.
// LED pin array
const int ledPins[] = {2, 3, 4, 5, 6, 7, 8, 9};
const int numLEDs = 8;
// Water level sensor analog input pin
const int sensorPin = A0;
Serial.begin(9600);
// Set all LED pins as output
for (int i = 0; i < numLEDs; i++) {
pinMode(ledPins[i], OUTPUT);
// Read the water level sensor value (0~1023)
int sensorValue = analogRead(sensorPin);
Serial.print("Water level analog value: ");
Serial.println(sensorValue);
// Map the analog value to number of LEDs (0~8)
int level = map(sensorValue, 0, 450, 0, numLEDs);
// Turn on LEDs according to the water level
if (i < level) {
digitalWrite(ledPins[i], HIGH);
} else {
digitalWrite(ledPins[i], LOW);
delay(500); // Delay before next update
