Bird Dash
Kit purchase
Includes Arduino board |
PURCHASE LINK |
Ultimate Sensor Kit |
Arduino Uno R4 Minima |
Elite Explorer Kit |
Arduino Uno R4 WiFi |
3 in 1 Ultimate Starter Kit |
Universal Maker Sensor Kit |
Course Introduction
This Arduino project lets you play a simple dinosaur running game using a 1602 LCD, a button, and a passive buzzer.
The game displays obstacles and a bird character on the LCD. Press the button to make the bird jump and avoid obstacles.
Each successful dodge increases your score, while collisions reduce your lives. The buzzer sounds for each collision, and your final score is shown when the game ends.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R4 WIFI |
USB Type-C cable |
Breadboard |
Wires |
Several |
I2C LCD 1602 |
Button |
7 |
Passive buzzer |
Common Connections:
I2C LCD 1602
SDA: Connect to A4 on the Arduino.
SCL: Connect to A5 on the Arduino.
Passive Buzzer
+: Connect to 9 on the Arduino.
-: Connect to breadboard’s negative power bus.
Button
Connect to 3 on the Arduino.
Button
Connect to 6 on the Arduino.
Writing the Code
To install the library, use the Arduino Library Manager and search for LiquidCrystal I2C and install it.
Don’t forget to select the board(Arduino UNO R4 Minima) and the correct port before clicking the Upload button.
#include <Wire.h>
#define BUTTON_PIN 3 // jump button pin
#define RESTART_PIN 6 // restart button pin
#define BUZZER_PIN 9 // buzzer pin
#define BIRD_X 5 // fixed bird column
LiquidCrystal_I2C lcd(0x27, 16, 2);
// custom character IDs
#define BIRD_CHAR 0
#define PIPE_CHAR 1
#define HEART_CHAR 2
// custom character data: bird, pipe, heart
byte birdChar[8] = {
0b00000,
0b00000,
0b00110,
0b10111,
0b10110,
0b11110,
0b11110,
0b01100
byte pipeChar[8] = {
0b11111,
0b11111,
0b01110,
0b01110,
0b01110,
0b01110,
0b01110,
0b01110
byte heart[8] = {
0b00000,
0b01010,
0b11111,
0b11111,
0b01110,
0b00100,
0b00000,
0b00000
// game state
bool isUp = false; // bird position flag
bool gameOver = false;
int lives = 3; // starting lives
int distance = 0; // frame counter
int hundreds = 0; // hundreds digit for score
int totalSteps = 0; // total score
// obstacle positions
int obstacleX1, obstacleX2, obstacleX3;
int oldObstacleX1, oldObstacleX2, oldObstacleX3;
// speed control
int obstacleSpeed = 200; // initial frame delay
const int minSpeed = 120;
const int speedIncrement = 20;
int oldPlayerRow; // last bird row
lcd.init(); // initialize LCD
lcd.backlight(); // turn on backlight
// load custom characters
lcd.createChar(BIRD_CHAR, birdChar);
lcd.createChar(PIPE_CHAR, pipeChar);
lcd.createChar(HEART_CHAR, heart);
pinMode(BUTTON_PIN, INPUT_PULLUP);
pinMode(RESTART_PIN, INPUT_PULLUP);
pinMode(BUZZER_PIN, OUTPUT);
randomSeed(analogRead(A0) ^ micros());
startGame(); // reset game
// check restart button
if (digitalRead(RESTART_PIN) == LOW) {
startGame();
delay(200);
return;
// read jump button
isUp = (digitalRead(BUTTON_PIN) == LOW);
if (!gameOver) moveObstacle(); // run game frame
// pick number of pipes with probability
int pickCluster() {
int r = random(10);
if (totalSteps >= 100) {
if (r < 5) return 1; // 50% single
else if (r < 8) return 2; // 30% double
else return 3; // 20% triple
} else {
if (r < 2) return 1; // 20% single
else if (r < 6) return 2; // 40% double
else return 3; // 40% triple
void startGame() {
// reset variables
isUp = false;
gameOver = false;
lives = 3;
distance = 0;
hundreds = 0;
totalSteps = 0;
oldPlayerRow = 1;
// initial obstacle cluster
int cluster = pickCluster();
obstacleX1 = 13;
obstacleX2 = (cluster >= 2) ? 14 : -1;
obstacleX3 = (cluster >= 3) ? 15 : -1;
oldObstacleX1 = obstacleX1;
oldObstacleX2 = obstacleX2;
oldObstacleX3 = obstacleX3;
// show start screen
lcd.clear();
lcd.setCursor(0, 0);
lcd.print(" Bird Run 16x2 ");
lcd.setCursor(0, 1);
lcd.print(" Press BTN... ");
delay(1000);
lcd.clear();
void moveObstacle() {
static unsigned long lastTime = 0;
unsigned long now = millis();
if (now - lastTime < obstacleSpeed) return;
lastTime = now;
// clear old pipes
if (oldObstacleX1 >= 0) lcd.setCursor(oldObstacleX1, 1), lcd.write(' ');
if (oldObstacleX2 >= 0) lcd.setCursor(oldObstacleX2, 1), lcd.write(' ');
if (oldObstacleX3 >= 0) lcd.setCursor(oldObstacleX3, 1), lcd.write(' ');
// update score
distance++;
if (distance > 99) {
distance = 0;
hundreds++;
totalSteps = hundreds * 100 + distance;
// activate second pipe after 100
if (totalSteps >= 100 && obstacleX2 < 0) obstacleX2 = 16;
// move pipes left
if (obstacleX1 >= 0) obstacleX1--;
if (obstacleX2 >= 0) obstacleX2--;
if (obstacleX3 >= 0) obstacleX3--;
// regenerate cluster when first pipe off-screen
if (obstacleX1 < 0) {
obstacleX1 = 13;
if (obstacleSpeed > minSpeed) {
obstacleSpeed -= speedIncrement;
if (obstacleSpeed < minSpeed) obstacleSpeed = minSpeed;
// update lives display
for (int i = 0; i < 3; i++) lcd.setCursor(i, 0), lcd.write(' ');
for (int i = 0; i < lives; i++) lcd.setCursor(i, 0), lcd.write(byte(HEART_CHAR));
// draw bird
int playerRow = isUp ? 0 : 1;
if (playerRow != oldPlayerRow) {
lcd.setCursor(BIRD_X, oldPlayerRow);
lcd.write(' ');
lcd.setCursor(BIRD_X, playerRow);
lcd.write(byte(BIRD_CHAR));
oldPlayerRow = playerRow;
// draw pipes
if (obstacleX1 >= 0) lcd.setCursor(obstacleX1, 1), lcd.write(byte(PIPE_CHAR));
if (obstacleX2 >= 0) lcd.setCursor(obstacleX2, 1), lcd.write(byte(PIPE_CHAR));
if (obstacleX3 >= 0) lcd.setCursor(obstacleX3, 1), lcd.write(byte(PIPE_CHAR));
// draw score
lcd.setCursor(14, 0);
lcd.print(hundreds);
lcd.setCursor(14, 1);
lcd.print(distance / 10);
lcd.setCursor(15, 1);
lcd.print(distance % 10);
// collision check
if ((obstacleX1 == BIRD_X || obstacleX2 == BIRD_X || obstacleX3 == BIRD_X) && !isUp) {
lives--;
tone(BUZZER_PIN, 200, 200);
delay(250);
noTone(BUZZER_PIN);
if (lives <= 0) {
gameOver = true;
endGame();
// end game: show message then play melody
void endGame() {
lcd.clear();
lcd.setCursor(2, 0);
lcd.print("GAME OVER!!!");
lcd.setCursor(1, 1);
lcd.print("Steps: ");
lcd.print(totalSteps);
tone(BUZZER_PIN, 400, 100);
delay(150);
tone(BUZZER_PIN, 600, 100);
delay(150);
tone(BUZZER_PIN, 800, 150);
delay(200);
tone(BUZZER_PIN, 600, 150);
delay(200);
tone(BUZZER_PIN, 400, 200);
delay(250);
noTone(BUZZER_PIN);
