Speed Meter
Kit purchase
Includes Arduino board |
PURCHASE LINK |
Elite Explorer Kit |
Arduino Uno R4 WiFi |
3 in 1 Ultimate Starter Kit |
Arduino Uno R4 Minima |
Course Introduction
In this lesson, you’ll learn how to use an L9110 Motor Driver Module, a TT motor, and an OLED display with the Arduino to build a simple Motor Speed Control system.
A button press cycles through multiple speed levels, and the motor speed is displayed on the OLED as both a numeric RPM value and a bar graph.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R4 Minima/Arduino UNO R4 WIFI |
USB Cable |
Breadboard |
Wires |
Several |
L9110 Motor Driver Module |
OLED Display Module |
7 |
TT Motor |
8 |
Button |
Common Connections:
OLED Display Module
SDA: Connect to A4 on the Arduino.
SCK: Connect to A5 on the Arduino.
Button
Connect to 2 on the Arduino.
TT Motor
Connect to MOTOR A on the L9110 Motor Driver Module.
A-1B: Connect to 6 on the Arduino.
A-1A: Connect to 5 on the Arduino.
Writing the Code
To install the library, use the Arduino Library Manager and search for Adafruit SSD1306 and Adafruit GFX and install it.
Don’t forget to select the board(Arduino UNO R4) and the correct port before clicking the Upload button.
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 64
#define OLED_RESET -1
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
// Motor pins (L9110)
#define MOTOR_PIN1 5
#define MOTOR_PIN2 6
// Button pin
#define BUTTON_PIN 2
// Motor speed levels (PWM values)
int speedLevels[5] = {0, 100, 150, 200, 255};
int currentLevel = 0;
// Button debounce
bool lastButtonState = HIGH;
unsigned long lastDebounceTime = 0;
const unsigned long debounceDelay = 200;
pinMode(MOTOR_PIN1, OUTPUT);
pinMode(MOTOR_PIN2, OUTPUT);
pinMode(BUTTON_PIN, INPUT_PULLUP);
// Initialize OLED
if (!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) {
for (;;) ; // Stop if OLED not found
display.clearDisplay();
display.display();
handleButton();
updateMotor();
drawSpeed();
delay(50);
void handleButton() {
bool buttonState = digitalRead(BUTTON_PIN);
if (buttonState == LOW && lastButtonState == HIGH && (millis() - lastDebounceTime) > debounceDelay) {
currentLevel++;
if (currentLevel > 4) currentLevel = 0; // Loop back to stop
lastDebounceTime = millis();
lastButtonState = buttonState;
void updateMotor() {
int speed = speedLevels[currentLevel];
if (speed == 0) {
analogWrite(MOTOR_PIN1, 0);
analogWrite(MOTOR_PIN2, 0);
} else {
analogWrite(MOTOR_PIN1, speed);
void drawSpeed() {
int pwm = speedLevels[currentLevel];
float rpm = (pwm / 255.0) * 200.0; // Approximate RPM (TT motor max ~200RPM)
// Calculate bar length (max 100px)
int barLength = map(pwm, 0, 255, 0, 100);
// --- Display numeric speed (big font) ---
display.setTextSize(2); // Large font
display.setTextColor(SSD1306_WHITE);
display.setCursor(0, 0); // Position at top-left
display.print("RPM");
display.setCursor(0, 20); // Second line
display.print((int)rpm);
// --- Draw bar graph ---
display.drawRect(10, 50, 100, 10, SSD1306_WHITE); // Outline
display.fillRect(10, 50, barLength, 10, SSD1306_WHITE); // Filled part
display.display();
