Radar Guard 6.0
Kit purchase
Includes Arduino board
PURCHASE LINK
Ultimate Sensor Kit
Arduino Uno R4 Minima
Elite Explorer Kit
Arduino Uno R4 WiFi
3 in 1 Ultimate Starter Kit
Universal Maker Sensor Kit
Course Introduction
This project uses an ultrasonic sensor, a servo motor, and an Arduino to build a radar system with LCD and OLED displays.
The servo scans for obstacles, showing distance and angle data on both screens with a semicircle radar view. If an object is closer than the set threshold, a red LED and buzzer alert; otherwise, a green LED indicates a clear path.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino UNO R4 Minima
USB Type-C cable
Wires
Several
Ultrasonic Sensor Module
Digital Servo Motor
Active Buzzer
LED
220Ω resistor
OLED Display Module
I2C LCD 1602
../_images/radar_guard6.0_bb.png
Common Connections:
  • LED
    • Red LED: Connect the LEDs anode to the 4 on Arduino, and the LEDs cathode to a 220Ω resistor then to negative power bus on the breadboard.
    • Green LED: Connect the LEDs anode to the 5 on Arduino, and the LEDs cathode to a 220Ω resistor then to negative power bus on the breadboard.
  • Active Buzzer
    • +: Connect to 6 on the Arduino.
    • -: Connect to breadboard’s negative power bus.
  • Digital Servo Motor
    • Connect to breadboard’s positive power bus.
    • Connect to breadboard’s negative power bus.
    • Connect to 9 on the Arduino.
  • Ultrasonic Sensor Module
    • Trig: Connect to 2 on the Arduino.
    • Echo: Connect to 3 on the Arduino.
  • OLED Display Module
    • SDA: Connect to SDA on the Arduino.
    • SCK: Connect to SCL on the Arduino.
  • I2C LCD 1602
    • SDA: Connect to A4 on the Arduino.
    • SCL: Connect to A5 on the Arduino.
Writing the Code
  • To install the library, use the Arduino Library Manager and search for LiquidCrystal I2C and Adafruit GFX and Adafruit SSD1306 and install it.
  • Don’t forget to select the board(Arduino UNO R4 Minima/WIFI) and the correct port before clicking the Upload button.
#include <Servo.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
// --- Servo & Ultrasonic ---
Servo servo;
const int trigPin = 2;
const int echoPin = 3;
// --- LED & Buzzer ---
const int ledGreen = 4;
const int ledRed   = 5;
const int buzzer   = 6;
// --- LCD (0x27 or 0x3F) ---
LiquidCrystal_I2C lcd(0x27, 16, 2);
// --- OLED (0x3C) ---
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 64
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
// --- Parameters ---
int angle = 0;
long distance = 0;
const int DETECT_THRESHOLD = 20;  // cm
// --- Distance measurement function ---
long getDistance() {
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  long duration = pulseIn(echoPin, HIGH, 30000); // 30ms timeout
  if (duration == 0) return 999; // timeout handling
  return duration * 0.034 / 2;   // cm
  Serial.begin(9600);
  servo.attach(9);
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  pinMode(ledGreen, OUTPUT);
  pinMode(ledRed, OUTPUT);
  pinMode(buzzer, OUTPUT);
  // LCD
  lcd.init();
  lcd.backlight();
  // OLED
  if (!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) {
    for (;;); // stop if initialization fails
  display.clearDisplay();
  display.display();
  // Left to right
  for (angle = 0; angle <= 180; angle += 3) {
    servo.write(angle);
    delay(30);
    distance = getDistance();
    radarAction(distance);
    drawRadar(angle, distance);
  // Right to left
  for (angle = 180; angle >= 0; angle -= 3) {
    servo.write(angle);
    delay(30);
// --- Buzzer/LED/LCD display control ---
void radarAction(long d) {
  lcd.clear();
  if (d < DETECT_THRESHOLD && d > 0) {
    digitalWrite(ledRed, HIGH);
    digitalWrite(ledGreen, LOW);
    digitalWrite(buzzer, HIGH);
    lcd.setCursor(0, 0);
    lcd.print("Detected Object");
    lcd.setCursor(0, 1);
    lcd.print("Dist: ");
    lcd.print(d);
    lcd.print(" cm");
  } else {
    digitalWrite(ledRed, LOW);
    digitalWrite(ledGreen, HIGH);
    digitalWrite(buzzer, LOW);
    lcd.print("No Object");
    lcd.print(d);
    lcd.print(" cm");
// --- OLED semicircle radar drawing ---
void drawRadar(int angle, long d) {
  int centerX = SCREEN_WIDTH / 2;
  int centerY = SCREEN_HEIGHT - 1;
  // --- Semicircle concentric circles ---
  for (int r = 15; r <= 60; r += 15) {
    display.drawCircle(centerX, centerY, r, SSD1306_WHITE);
  // --- Radius lines ---
  for (int a = 0; a <= 180; a += 30) {
    float rad = radians(a);
    int x = centerX + cos(rad) * 60;
    int y = centerY - sin(rad) * 60;
    display.drawLine(centerX, centerY, x, y, SSD1306_WHITE);
  // --- Scanning line ---
  float rad = radians(angle);
  int x2 = centerX + cos(rad) * 60;
  int y2 = centerY - sin(rad) * 60;
  display.drawLine(centerX, centerY, x2, y2, SSD1306_WHITE);
  // --- Detected target point ---
  if (d < 60) {
    int tx = centerX + cos(rad) * d;
    int ty = centerY - sin(rad) * d;
    display.fillCircle(tx, ty, 2, SSD1306_WHITE);
  // --- Angle/Distance text ---
  display.setTextSize(1);
  display.setTextColor(SSD1306_WHITE);
  display.setCursor(0, 0);
  display.print("Ang:");
  display.print(angle);
  display.print(" D:");
  display.print(d);
  display.display();
