RFID Access5.0
Kit purchase
Includes Arduino board
PURCHASE LINK
Elite Explorer Kit
Arduino Uno R4 WiFi
Inventor Lab Kit
Arduino Uno R3
Course Introduction
In this lesson, we’ll build a 5.0 access-control system using the MFRC522 module, active buzzer, a digital servo motor, and flame sensor module.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino UNO R4 Minima/Arduino UNO R4 WIFI
USB Type-C cable
Wires
Several
Flame Sensor Module
Active Buzzer
MFRC522 Module
Power Supply Module
Digital Servo Motor
../_images/RFID_Access5.0_bb.png
Common Connections:
  • MFRC522 Module
    • IRQ: Connect to 7 on the Arduino.
    • SDA: Connect to 6 on the Arduino.
    • SCK: Connect to 5 on the Arduino.
    • MOSI: Connect to 4 on the Arduino.
    • MISO: Connect to 3 on the Arduino.
    • RST: Connect to 2 on the Arduino.
    • 3.3V: Connect to breadboard’s passive power bus.
  • Flame Sensor Module
    • D0: Connect to 12 on the Arduino.
  • Active Buzzer
    • +: Connect to 11 on the Arduino.
    • -: Connect to breadboard’s negative power bus.
  • Digital Servo Motor
    • Connect to breadboard’s positive power bus.
    • Connect to breadboard’s negative power bus.
    • Connect to 9 on the Arduino.
Writing the Code
  • The RFID1 library is used here. You can click here RFID1.zip to download it.
  • Don’t forget to select the board(Arduino UNO R4 WIFI) and the correct port before clicking the Upload button.
#include <rfid1.h>
#include <Servo.h>
#define ID_LEN 4
RFID1 rfid;
Servo myServo;
// Pin setup
const int servoPin  = 9;     // Servo motor pin
const int buzzerPin = 11;    // Active buzzer pin
const int flamePin  = 12;    // Flame sensor (LOW = fire detected)
// Your RFID card UID (you changed it)
uchar userId[ID_LEN] = {0x33, 0xF8, 0xB8, 0x1A};
uchar userIdRead[ID_LEN];
// State
bool cardAction       = false;
unsigned long cardTimer = 0;
bool flameAlert       = false;
bool flameRecovering  = false;
unsigned long flameRecoverStart = 0;
// Servo status
int targetPos  = 0;
int currentPos = 0;
// Set target servo angle (0–90)
void setServoAngle(int angle) {
  targetPos = constrain(angle, 0, 90);
// Move servo smoothly (non-blocking)
void servoSmoothRun() {
  static unsigned long lastStep = 0;
  if (millis() - lastStep >= 15) {
    lastStep = millis();
    if (currentPos < targetPos) currentPos++;
    else if (currentPos > targetPos) currentPos--;
    myServo.write(currentPos);
// Beep without delay() (used for fire alarm)
void buzzerBeepNonBlock() {
  static unsigned long lastBeep = 0;
  static bool buzzState = false;
  if (millis() - lastBeep >= 120) {
    lastBeep = millis();
    buzzState = !buzzState;
    digitalWrite(buzzerPin, buzzState);
// Read UID from RFID card
void getId() {
  uchar status, str[MAX_LEN];
  status = rfid.anticoll(str);
  if (status == MI_OK) {
    for (int i = 0; i < ID_LEN; i++) userIdRead[i] = str[i];
    rfid.halt();
// Check if UID matches
bool idVerify() {
    if (userIdRead[i] != userId[i]) return false;
  return true;
// Clear UID buffer
void clearBuffer() {
  for (int i = 0; i < ID_LEN; i++) userIdRead[i] = 0;
// Faster beeps for invalid card (100ms)
void denyAccessBeep() {
  for (int i = 0; i < 4; i++) {
    digitalWrite(buzzerPin, HIGH); delay(100);
    digitalWrite(buzzerPin, LOW);  delay(100);
// Setup runs once
  rfid.begin(7, 5, 4, 3, 6, 2);
  rfid.init();
  pinMode(buzzerPin, OUTPUT);
  pinMode(flamePin, INPUT);
  myServo.attach(servoPin);
  myServo.write(0);            // Door starts closed
  currentPos = 0;
  targetPos  = 0;
// Main loop
  // ------------ Valid card → open → hold → close ------------
  if (cardAction) {
    // Keep opening until fully open
    if (currentPos < 90) {
      servoSmoothRun();
      return;
    // Start hold timer (1.5s) after fully opened
    if (cardTimer == 0) {
      cardTimer = millis();
    // 1.5s hold time reached → close door
    if (millis() - cardTimer >= 1500) {
      setServoAngle(0);
      cardAction = false;
      cardTimer  = 0;
    servoSmoothRun();
    return;
  // ------------ Flame detection & alarm ------------
  bool flameDetected = (digitalRead(flamePin) == LOW);
  bool allowRFID = false;
  if (flameDetected) {
    flameAlert       = true;
    setServoAngle(90);         // Open immediately
    buzzerBeepNonBlock();      // Alarm (non-blocking)
    allowRFID = false;
  else {
    if (flameAlert) {          // Fire just stopped
      if (!flameRecovering) {
        flameRecovering = true;
        flameRecoverStart = millis();
      // Keep alarm 1.5s more after fire stops
      if (millis() - flameRecoverStart < 1500) {
        allowRFID = false;
      } else {
        flameAlert       = false;
        setServoAngle(0);     // Close door
        allowRFID = true;
    } else {
      allowRFID = true;
  // ------------ RFID scanning if allowed ------------
  if (allowRFID) {
    status = rfid.request(PICC_REQIDL, str);
      getId();
      if (idVerify()) {
        // 🔔 Short beep feedback when opening door
        digitalWrite(buzzerPin, HIGH); delay(80);
        setServoAngle(90);
        cardAction = true;
        cardTimer  = 0;
      } else {
        denyAccessBeep();
      clearBuffer();
  // Keep servo smooth always
  servoSmoothRun();
