Smart Stop 1.0
Kit purchase
../_images/ultimate_sensor_kit.png
Includes Arduino board
PURCHASE LINK
Elite Explorer Kit
Arduino Uno R4 WiFi
3 in 1 Ultimate Starter Kit
Arduino Uno R4 Minima
Course Introduction
In this lesson, you’ll learn how to use an L9110 Motor Driver Module, an Ultrasonic Sensor Module, and a TT motor with the Arduino UNO R3 to create a Smart Stop 1.0 system.
As the obstacle gets closer to the Ultrasonic Sensor Module, the TT motor gradually slows down until it comes to a stop.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino UNO R3
USB Cable
Wires
Several
TT Motor
../_images/Smart_Stop_01_bb.png
Common Connections:
  • Ultrasonic Sensor Module
    • Trig: Connect to 4 on the Arduino.
    • Echo: Connect to 3 on the Arduino.
  • TT Motor
    • Connect to MOTOR B on the L9110 Motor Driver Module.
  • L9110 Motor Driver Module
    • B-1B: Connect to 9 on the Arduino.
    • B-1A: Connect to 10 on the Arduino.
Writing the Code
  • Don’t forget to select the board(Arduino UNO R3) and the correct port before clicking the Upload button.
// Define pins for ultrasonic sensor and motor
const int echoPin = 3;
const int trigPin = 4;
const int motorB_1A = 9;
const int motorB_2A = 10;
  Serial.begin(9600); // Initialize serial communication at 9600 baud rate
  pinMode(echoPin, INPUT); // Set echo pin as input for receiving signals
  pinMode(trigPin, OUTPUT); // Set trig pin as output for sending signals
  pinMode(motorB_1A, OUTPUT); // Set motor control pin 1 as output
  pinMode(motorB_2A, OUTPUT); // Set motor control pin 2 as output
  float distance = readSensorData(); // Get distance from ultrasonic sensor using the new function name
  Serial.print("Distance: "); // Print distance for debugging
  Serial.print(distance);
  Serial.println(" cm");
  controlMotor(distance); // Control motor speed based on distance
  delay(100); // Delay to reduce sensor noise impact
float readSensorData() {
  digitalWrite(trigPin, LOW); // Ensure clean pulse
  delayMicroseconds(2); // Wait for 2 microseconds
  digitalWrite(trigPin, HIGH); // Send high pulse for 10 microseconds
  delayMicroseconds(10);
  digitalWrite(trigPin, LOW); // Reset trig pin to low
  unsigned long duration = pulseIn(echoPin, HIGH); // Measure echo pulse width
  float distance = duration / 58.00; // Calculate distance in cm, simplifying the calculation
  return distance;
void controlMotor(float distance) {
  if (distance < 5) {
    analogWrite(motorB_1A, 0); // Stop motor if distance is less than 5 cm
    analogWrite(motorB_2A, 0);
  } else if (distance < 8) {
    analogWrite(motorB_1A, 85); // Set speed to 85 if distance is less than 8 cm
  } else if (distance < 11) {
    analogWrite(motorB_1A, 170); // Set speed to 170 if distance is less than 11 cm
  } else if (distance > 14) {
    analogWrite(motorB_1A, 255); // Set speed to maximum if distance is more than 14 cm
