Stair Light
Kit purchase
Includes Arduino board
PURCHASE LINK
Elite Explorer Kit
Arduino Uno R4 WiFi
Inventor Lab Kit
Arduino Uno R3
Course Introduction
In this lesson, you’ll use a PIR motion sensor, an LED, and a button with the Arduino R4 UNO to build a smart lighting system with three operating modes.
The system can automatically turn on the LED when motion is detected, keep it always on, or keep it always off. A single button toggles between these modes, and the LED behavior updates accordingly.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino UNO R4 Minima
USB Type-C cable
Wires
Several
PIR Motion Sensor
Button
LED
1kΩ resistor
../_images/stair_light_bb.png
Common Connections:
  • LED
    • Connect the LED cathode to the to a 220Ω resistor, then to negative power bus on the breadboard, anode to 3 on the Arduino.
  • PIR
    • +: Connect to 2 on the Arduino.
    • -: Connect to breadboard’s negative power bus.
  • Button
    • Connect to the breadboard’s negative power bus, and the other end to 4 on the Arduino board.
Writing the Code
  • Don’t forget to select the board(Arduino UNO R4 Minima) and the correct port before clicking the Upload button.
const int PIR_PIN = 2;    // PIR motion sensor signal pin
const int LED_PIN = 3;    // LED pin
const int BUTTON_PIN = 4; // Button pin
int mode = 0;  // 0 = Auto, 1 = Always ON, 2 = Always OFF
bool lastButtonState = HIGH;
unsigned long lastMotionTime = 0;
const unsigned long LIGHT_DELAY = 3000; // 3s delay
  pinMode(PIR_PIN, INPUT);
  pinMode(LED_PIN, OUTPUT);
  pinMode(BUTTON_PIN, INPUT_PULLUP); // Internal pull-up
  digitalWrite(LED_PIN, LOW);
  Serial.begin(9600);
  Serial.println("Mode 0: Auto, Mode 1: Always ON, Mode 2: Always OFF");
  // ---- Button detection (toggle between modes) ----
  bool buttonState = digitalRead(BUTTON_PIN);
  if (buttonState == LOW && lastButtonState == HIGH) {
    mode = (mode + 1) % 3;  // Cycle through 0->1->2->0
    Serial.print("Mode: ");
    if (mode == 0) Serial.println("Auto");
    else if (mode == 1) Serial.println("Always ON");
    else Serial.println("Always OFF");
    delay(200); // Debounce
  lastButtonState = buttonState;
  // ---- Mode control ----
  if (mode == 1) {
    // Always ON
    digitalWrite(LED_PIN, HIGH);
  } else if (mode == 2) {
    // Always OFF
  } else {
    // Auto mode (PIR control)
    int motion = digitalRead(PIR_PIN);
    if (motion == HIGH) {
      lastMotionTime = millis(); // Record time when motion detected
    } else if (millis() - lastMotionTime > LIGHT_DELAY) {
