Distance Display
Kit purchase
Includes Arduino board
PURCHASE LINK
Ultimate Sensor Kit
Arduino Uno R4 Minima
Elite Explorer Kit
Arduino Uno R4 WiFi
3 in 1 Ultimate Starter Kit
Universal Maker Sensor Kit
Course Introduction
In this project, we use an ultrasonic sensor and an I2C 1602 LCD with an Arduino board to create a real-time distance measurement display system.
The ultrasonic sensor continuously measures the distance to an obstacle, and the result is shown on the LCD screen in centimeters.
The system updates the display approximately every 800 milliseconds, making it suitable for simple proximity detection applications.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino UNO R4 WIFI
USB Type-C cable
Wires
Several
Ultrasonic Sensor Module
I2C LCD 1602
../_images/Distance_Display_bb.png
Common Connections:
  • I2C LCD 1602
    • SDA: Connect to A4 on the Arduino.
    • SCL: Connect to A5 on the Arduino.
  • Ultrasonic Sensor Module
    • Trig: Connect to 4 on the Arduino.
    • Echo: Connect to 3 on the Arduino.
Writing the Code
  • To install the library, use the Arduino Library Manager and search for LiquidCrystal I2C and install it.
  • Don’t forget to select the board(Arduino UNO R4 WIFI) and the correct port before clicking the Upload button.
LiquidCrystal_I2C lcd(0x27, 16, 2);  // initialize the Liquid Crystal Display object with the I2C address 0x27, 16 columns and 2 rows
// Define the pin numbers for the ultrasonic sensor
const int echoPin = 3;
const int trigPin = 4;
  pinMode(echoPin, INPUT);   // Set echo pin as input
  pinMode(trigPin, OUTPUT);  // Set trig pin as output
  lcd.init();       // initialize the LCD
  lcd.clear();      // clear the LCD display
  lcd.backlight();  // Make sure backlight is on
  float distance = readDistance();  // Call the function to read the sensor data and get the distance
  lcd.setCursor(0, 0);           //Place the cursor at Line 1, Column 1. From here the characters are to be displayed
  lcd.print("Distance:");        ////Print Distance: on the LCD
  lcd.setCursor(0, 1);           //Set the cursor at Line 1, Column 0
  lcd.print("               ");  //Here is to leave some spaces after the characters so as to clear the previous characters that may still remain.
  lcd.setCursor(7, 1);           //Set the cursor at Line 1, Column 7.
  lcd.print(distance);           // print on the LCD the value of the distance converted from the time between ping sending and receiving.
  lcd.setCursor(14, 1);          //Set the cursor at Line 1, Column 14.
  lcd.print("cm");               //print the unit "cm"
  delay(800);  // Delay for 800 milliseconds before repeating the loop
// Function to read the sensor data and calculate the distance
float readDistance() {
  digitalWrite(trigPin, LOW);   // Set trig pin to low to ensure a clean pulse
  delayMicroseconds(2);         // Delay for 2 microseconds
  digitalWrite(trigPin, HIGH);  // Send a 10 microsecond pulse by setting trig pin to high
  delayMicroseconds(10);
  digitalWrite(trigPin, LOW);  // Set trig pin back to low
  // Measure the pulse width of the echo pin and calculate the distance value
  float distance = pulseIn(echoPin, HIGH) / 58.00;  // Formula: (340m/s * 1us) / 2
  return distance;
