Flame Monitor 3.0
Kit purchase
Includes Arduino board |
PURCHASE LINK |
Ultimate Sensor Kit |
Arduino Uno R4 Minima |
Universal Maker Sensor Kit |
Course Introduction
In this lesson, you’ll learn how to use a Flame Sensor, an I2C LCD Display, and the Arduino UNO R4 to monitor fire intensity. The LCD shows real-time readings, while buzzer provide sound alerts for different flame levels.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R4 Minima |
USB Type-C cable |
Breadboard |
Wires |
Several |
Flame Sensor Module |
Buzzer Modudle |
7 |
I2C LCD 1602 |
Common Connections:
Flame Sensor Module
A0: Connect to A0 on the Arduino.
Buzzer Modudle
I/O: Connect to 10 on the Arduino.
I2C LCD 1602
SDA: Connect to A4 on the Arduino.
SCL: Connect to A5 on the Arduino.
Writing the Code
To install the library, use the Arduino Library Manager and search for LiquidCrystal_I2C and install it.
Don’t forget to select the board(Arduino UNO R4 Minima) and the correct port before clicking the Upload button.
#include <Wire.h>
// Pin definitions
const int sensorPin = A0; // Flame sensor analog pin
const int buzzerPin = 10; // Buzzer pin
// Threshold values
const int safeThreshold = 100;
const int dangerThreshold = 700;
// LCD object (address 0x27, 16 columns, 2 rows)
LiquidCrystal_I2C lcd(0x27, 16, 2);
int flameValue = 0;
Serial.begin(9600);
lcd.init();
lcd.backlight();
pinMode(buzzerPin, OUTPUT);
// Startup screen
lcd.setCursor(0, 0);
lcd.print("Flame Monitor");
lcd.setCursor(0, 1);
lcd.print("Initializing");
delay(1200);
lcd.clear();
// Read sensor value
int rawValue = analogRead(sensorPin);
// Convert to intuitive value
flameValue = 1023 - rawValue;
// Serial output for debugging
Serial.print("Flame Sensor Value: ");
Serial.println(flameValue);
// Status detection
if (flameValue < safeThreshold) {
displayStatus("Status: Safe");
noTone(buzzerPin);
else if (flameValue < dangerThreshold) {
displayStatus("Status: Warning");
tone(buzzerPin, 800, 200);
else {
displayStatus("Status: Danger");
tone(buzzerPin, 1000, 400);
// Display value
lcd.print("Value: ");
lcd.print(flameValue);
delay(200);
// Function to display status on first row
void displayStatus(const char* text) {
lcd.print(" "); // clear first row
lcd.print(text);
