Light Show 2.0
Kit purchase
Includes Arduino board
PURCHASE LINK
Ultimate Sensor Kit
Arduino Uno R4 Minima
Elite Explorer Kit
Arduino Uno R4 WiFi
3 in 1 Ultimate Starter Kit
Universal Maker Sensor Kit
Course Introduction
In this lesson, you will learn how to use Arduino along with LEDs, and resistors to create a light show.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino UNO R4 Minima
USB Type-C cable
Wires
Several
1kΩ resistor
Several
LED
Several
../_images/Light_Show_bb.png
Common Connections:
  • LED
    • Connect the LEDs cathode to negative power bus on the breadboard, and the LEDs anode to a 1kΩ resistor then to the 2 to 13 on the Arduino.
Writing the Code
  • Don’t forget to select the board(Arduino UNO R4 Minima) and the correct port before clicking the Upload button.
// LED Light Show - For Beginners
// Created for 12 LEDs connected to pins 2–13
// Effect 1: Ping-Pong
// Effect 2: Waterfall
// Effect 3: Wave (two rounds)
// Effect 4: Bouncing (two rounds)
// Effect 5: Progressive Keep (two directions)
// Effect 6: Running Back
// Effect 7: Ladder (two directions)
// Effect 8: Alternating
// Effect 9: Grouped Flash (two times)
// Effect 10: Cross Blink (two times)
const int ledPins[] = {2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13};
const int numLeds = 12;
  // Set all LED pins as outputs
  for (int i = 0; i < numLeds; i++) {
    pinMode(ledPins[i], OUTPUT);
    digitalWrite(ledPins[i], LOW);
  pingPongEffect();          // Effect 1
  waterfallEffect();         // Effect 2
  waveEffect();              // Effect 3
  bouncingEffect();          // Effect 4
  progressiveKeepEffect();   // Effect 5
  runningBackEffect();       // Effect 6
  ladderEffect();            // Effect 7
  alternatingEffect();       // Effect 8
  // Keep consistent loop structure for repeated effects
  for (int i = 0; i < 2; i++) {
    groupedFlashEffect();    // Effect 9 - Repeat twice
    crossBlinkEffect();      // Effect 10 - Repeat twice
void pingPongEffect() {
  // Move light from left to right
    digitalWrite(ledPins[i], HIGH);
    delay(80);
  // Move light from right to left
  for (int i = numLeds - 1; i >= 0; i--) {
    delay(80);
void waterfallEffect() {
  // Flow from left to right
    delay(50);
    delay(50);
  // Flow from right to left
    delay(50);
    delay(50);
void waveEffect() {
  for (int repeat = 0; repeat < 2; repeat++) {
    // Left to right wave
      if (i > 1) digitalWrite(ledPins[i - 2], LOW);
      delay(50);
    // Right to left wave
      if (i < numLeds - 2) digitalWrite(ledPins[i + 2], LOW);
      delay(50);
    // Turn off last two LEDs
      digitalWrite(ledPins[numLeds - 1 - i], LOW);
void bouncingEffect() {
    // Move inward
    for (int i = 0; i < numLeds / 2; i++) {
      digitalWrite(ledPins[numLeds - 1 - i], HIGH);
      delay(50);
    // Turn off inward
      delay(50);
    // Move outward
    for (int i = numLeds / 2 - 1; i >= 0; i--) {
      delay(50);
    // Turn off outward
      delay(50);
void progressiveKeepEffect() {
  // Left to right progressive
  for (int round = 0; round < numLeds; round++) {
    for (int i = 0; i < numLeds; i++) digitalWrite(ledPins[i], LOW);
    for (int i = numLeds - 1; i >= numLeds - round; i--) {
    for (int i = 0; i < numLeds - round; i++) {
      if (i > 0) digitalWrite(ledPins[i - 1], LOW);
      delay(50);
    if (numLeds - round - 1 >= 0) digitalWrite(ledPins[numLeds - round - 1], LOW);
  // Right to left progressive
    for (int i = 0; i < round; i++) digitalWrite(ledPins[i], HIGH);
    for (int i = numLeds - 1; i >= round; i--) {
      if (i < numLeds - 1) digitalWrite(ledPins[i + 1], LOW);
      delay(50);
    if (round < numLeds) digitalWrite(ledPins[round], LOW);
void runningBackEffect() {
  // Forward
    delay(50);
  // Backward
    delay(50);
void ladderEffect() {
  // Left to right
    delay(50);
    delay(50);
  // Right to left
    delay(50);
    delay(50);
void alternatingEffect() {
  for (int i = 0; i < 5; i++) {
    // Even LEDs ON, odd LEDs OFF
    for (int j = 0; j < numLeds; j += 2) {
      digitalWrite(ledPins[j], HIGH);
      if (j + 1 < numLeds) digitalWrite(ledPins[j + 1], LOW);
    delay(300);
    // Even LEDs OFF, odd LEDs ON
      digitalWrite(ledPins[j], LOW);
      if (j + 1 < numLeds) digitalWrite(ledPins[j + 1], HIGH);
    delay(300);
  // Turn off all LEDs
void groupedFlashEffect() {
  int groupSize = 4; // 4 LEDs per group
  for (int g = 0; g < numLeds; g += groupSize) {
    for (int i = g; i < g + groupSize && i < numLeds; i++) digitalWrite(ledPins[i], HIGH);
    delay(300);
    for (int i = g; i < g + groupSize && i < numLeds; i++) digitalWrite(ledPins[i], LOW);
void crossBlinkEffect() {
    // Opposite LEDs ON/OFF alternately
    delay(300);
    delay(300);
