Ardu Bird
Kit purchase
Includes Arduino board
PURCHASE LINK
Ultimate Sensor Kit
Arduino Uno R4 Minima
Elite Explorer Kit
Arduino Uno R4 WiFi
3 in 1 Ultimate Starter Kit
Universal Maker Sensor Kit
Course Introduction
This Arduino project uses an OLED display, Button to play a classic Flappy Bird game with Button-controlled moves.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino UNO R4 Minima/Arduino UNO R4 WIFI
USB Type-C cable
Wires
Several
Button
OLED Display Module
../_images/flappy_bb.png
Common Connections:
  • OLED Display Module
    • SDA: Connect to A4 on the Arduino.
    • SCK: Connect to A5 on the Arduino.
  • Button
    • Connect to the breadboard’s negative power bus, and the other end to 2 on the Arduino board.
Writing the Code
  • To install the library, use the Arduino Library Manager and search for Adafruit_GFX and Adafruit SSD1306 and install it.
  • Don’t forget to select the board(Arduino UNO R4 Minima) and the correct port before clicking the Upload button.
#include <Arduino.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
// OLED display settings
const int SCREEN_WIDTH = 128;
const int SCREEN_HEIGHT = 64;
const int OLED_RESET = -1;
const int SCREEN_ADDRESS = 0x3C; // I2C address of the display, see datasheet
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
const bool DEBUG_PRINT = false;  // set to true for debug output in Serial Monitor
// Button & physics
const int BUTTON_PIN = 2; // push button on digital pin 2
const int SCALE_FACTOR = 10;  // scale factor 10 for more precise movement
const int GRAVITY = 5; // gravity applied to the character each frame
const int JUMP_STRENGTH = -25; // jump acceleration when push button is pressed
const int PIPE_WIDTH = 15 * SCALE_FACTOR; // pipes are 15px wide on display
const int PIPE_GAP = 30 * SCALE_FACTOR; // gap in pipes 30px high
const int PIPE_SPEED = 10; // side scroll speed
const int PIPE_SPACING = 65 * SCALE_FACTOR;  // default spacing between 2 pipes
// Size of player sprite
const int BIRD_WIDTH_PX = 10;
const int BIRD_HEIGHT_PX = 8;
// Game variables
int birdY; // vertical position of the player (scaled by SCALE_FACTOR)
float velocity = 0; // combined vertical velocity of the player (scaled)
bool gameOver = false;
int score = 0;
unsigned long frameCounter = 0;
unsigned long gameOverTime = 0;
// Game state
enum GameState { STARTSCREEN,
                HIGHSCORE,
                PLAYING };
GameState gameState = STARTSCREEN;
// Data type for a pipe (x-position, height of the upper part)
struct Pipe {
  int x;
  int height;
// Maximum 3 pipes simultaneously
const int MAX_PIPES = 3;
Pipe pipes[MAX_PIPES];
// Highscore
long highscores[5] = {};
int newHighscoreIndex = -1;
unsigned long highscoreTime = 0;
bool showBlink = true;
unsigned long lastBlinkTime = 0;
// Framerate control
const int FRAME_TIME = 40;  // 40ms per frame = 25 FPS
unsigned long lastFrameTime = 0;
// Graphics for player sprite
// converted from PNG with https://javl.github.io/image2cpp/
// 'bird1', 10x8px
const uint8_t epd_bitmap_bird1[] PROGMEM = {
  0x0e, 0x00, 0x15, 0x00, 0x60, 0x80, 0x81, 0x80, 0xfc, 0xc0, 0xfb, 0x80, 0x71, 0x00, 0x1e, 0x00
// 'bird2', 10x8px
const uint8_t epd_bitmap_bird2[] PROGMEM = {
  0x0e, 0x00, 0x15, 0x00, 0x70, 0x80, 0xf9, 0x80, 0xfc, 0xc0, 0x83, 0x80, 0x71, 0x00, 0x1e, 0x00
// Array of all bitmaps for convenience. (Total bytes used to store images in PROGMEM = 64)
const int epd_bitmap_allArray_LEN = 2;
const uint8_t* epd_bitmap_allArray[2] = {
  epd_bitmap_bird1,
  epd_bitmap_bird2
  Serial.begin(9600);
  pinMode(BUTTON_PIN, INPUT_PULLUP);
  randomSeed(analogRead(A0)); // use A0 on UNO R4 cores
  // IMPORTANT for UNO R4:
  // Keep using the default Wire() instance; wiring remains as provided.
  // Initialize display or pause on error
  if (!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS)) {
    Serial.println(F("SSD1306 allocation failed"));
    while (1) {
      delay(100);
  unsigned long currentTime = millis();
  // ensure that the next frame is only calculated after FRAME_TIME
  if (currentTime - lastFrameTime < FRAME_TIME) return;
  lastFrameTime = currentTime;
  frameCounter++;
  switch (gameState) {
    case STARTSCREEN:
      renderStartScreen();
      if (anyKeyPressed()) {
        resetGame(); // reset variables
        gameState = PLAYING; // start game
      break;
    case PLAYING:
      if (gameOver) {
        // after game over, automatically switch to highscore screen after 3 seconds
        if (millis() - gameOverTime > 3000) {
          gameState = HIGHSCORE;
          highscoreTime = millis();
        // or player presses button (1 sec pause), then start new game immediately
        if ((millis() - gameOverTime > 1000) && anyKeyPressed()) {
          resetGame();
      } else {
        // if button pressed, add negative acceleration (upwards)
        if (digitalRead(BUTTON_PIN) == LOW) velocity = JUMP_STRENGTH;
        velocity += GRAVITY; // apply gravity
        velocity = constrain(velocity, -50.0f, 50.0f); // limit velocity to prevent too fast falling or rising
        // calculate player position
        birdY += (int)velocity;
        // if player at top (y=0), do not go off screen
        if (birdY < 0) birdY = 0;
        if (DEBUG_PRINT) {
          Serial.print("Vel: ");
          Serial.println(velocity);
        movePipes();
        checkCollision();
      drawGame();
      break;
    case HIGHSCORE:
      renderHighscoreScreen();
      // after 8 seconds without button press, switch to start screen
      if (millis() - gameOverTime > 8000) {
      // or start new game if button pressed
        resetGame();
      break;
// PULLUP logic: LOW means pressed
bool anyKeyPressed() {
  return digitalRead(BUTTON_PIN) == LOW;
// ---- Reset game ---- //
void resetGame() {
  // set start position of the player to 1/5 of the screen height
  birdY = SCREEN_HEIGHT * SCALE_FACTOR / 5;
  velocity = 0;
  score = 0;
  gameOver = false;
  // create first pipe just outside the screen edge
  pipes[0].x = SCREEN_WIDTH * SCALE_FACTOR;
  pipes[0].height = generatePipeHeight();
  // create pipes 2 and 3 with random variation in spacing
  for (int i = 1; i < MAX_PIPES; i++) {
    pipes[i].x = SCREEN_WIDTH * SCALE_FACTOR + i * PIPE_SPACING + random(-20, 20) * SCALE_FACTOR;
    pipes[i].height = generatePipeHeight();
// generate random height of the upper pipe section,
// leaving at least space for gap and 10px for lower part
int generatePipeHeight() {
  return random(10 * SCALE_FACTOR, SCREEN_HEIGHT * SCALE_FACTOR - PIPE_GAP - 10 * SCALE_FACTOR);
// move pipes toward the player
void movePipes() {
  int currentSpeed = PIPE_SPEED + score; // pipes move faster and faster
  for (int i = 0; i < MAX_PIPES; i++) {
    // move pipe position left by currentSpeed
    pipes[i].x -= currentSpeed;
    // if pipe leaves the left edge, immediately create a new pipe at the right edge
    if (pipes[i].x < -PIPE_WIDTH) {
      pipes[i].x = findFurthestPipe() + PIPE_SPACING + random(-20, 20) * SCALE_FACTOR;  // place new pipe far right
      pipes[i].height = random(10 * SCALE_FACTOR, SCREEN_HEIGHT * SCALE_FACTOR - PIPE_GAP - 10 * SCALE_FACTOR);
      score++;
// helper function to find the pipe farthest to the right
int findFurthestPipe() {
  int maxX = 0;
    if (pipes[i].x > maxX) {
      maxX = pipes[i].x;
  return maxX;
// ---- Collision detection ---- //
void checkCollision() {
  // collision check with a 2px smaller hitbox (Collision Forgiveness),
  // because the player is more round → avoids unfair edge hits
    // check if the player overlaps horizontally with a pipe
    if (pipes[i].x < (15 + 2) * SCALE_FACTOR && pipes[i].x + PIPE_WIDTH > (15 - 2) * SCALE_FACTOR) {
      // check if the player hits the pipe vertically (top or bottom)
      if ((birdY - 2 * SCALE_FACTOR) < pipes[i].height || (birdY + 2 * SCALE_FACTOR) > pipes[i].height + PIPE_GAP) {
        gameOver = true;
        gameOverTime = millis();
        saveHighscores(score);
  // if player below the screen bottom
  if (birdY >= SCREEN_HEIGHT * SCALE_FACTOR) {
    gameOver = true;
// ---- Draw game ---- //
void drawGame() {
  display.clearDisplay();
  drawBird();
  drawPipes();
  drawScore();
  if (gameOver) displayGameOver();  // if game over, display overlay
  display.display();
void drawBird() {
  int birdFrame = (frameCounter / 5) % 2;
  display.drawBitmap(15 - BIRD_WIDTH_PX / 2, birdY / SCALE_FACTOR - BIRD_HEIGHT_PX / 2,
                    epd_bitmap_allArray[birdFrame], BIRD_WIDTH_PX, BIRD_HEIGHT_PX, SSD1306_WHITE);
void drawPipes() {
  for (int pipeIndex = 0; pipeIndex < MAX_PIPES; pipeIndex++) {
    int pipeX = pipes[pipeIndex].x / SCALE_FACTOR;
    int upperPipeHeight = pipes[pipeIndex].height / SCALE_FACTOR;
    int gapHeight = PIPE_GAP / SCALE_FACTOR;
    int lowerPipeY = upperPipeHeight + gapHeight;
    int lowerPipeHeight = SCREEN_HEIGHT - lowerPipeY;
    int pipeWidth = PIPE_WIDTH / SCALE_FACTOR;
    // upper pipe segment (vertical)
    display.fillRect(pipeX, 0, pipeWidth, upperPipeHeight - 6, SSD1306_WHITE);
    // pipe head top (horizontal cap)
    display.fillRect(pipeX - 2, upperPipeHeight - 6, pipeWidth + 4, 6, SSD1306_WHITE);
    // pipe head bottom (horizontal cap below gap)
    display.fillRect(pipeX - 2, lowerPipeY, pipeWidth + 4, 6, SSD1306_WHITE);
    // lower pipe segment (vertical)
    display.fillRect(pipeX, lowerPipeY + 6, pipeWidth, lowerPipeHeight - 6, SSD1306_WHITE);
// show current score at top right of display
void drawScore() {
  display.setTextSize(1);
  display.setTextColor(SSD1306_WHITE);
  display.setCursor(110, 2);
  display.print(score);
// ---- Show start screen ---- //
void renderStartScreen() {
  display.setTextSize(2);
  display.setCursor(10, 20);
  display.println("Ardu Bird");
  display.setCursor(20, 40);
  display.println("Press to start");
  display.display();
// ---- Show Game Over ---- //
void displayGameOver() {
  display.fillRect(20, 5, SCREEN_WIDTH - 40, SCREEN_HEIGHT - 10, SSD1306_WHITE);
  display.setTextColor(SSD1306_BLACK);
  display.setCursor(38, 10);
  display.println("GAME OVER");
  display.setCursor(35, 20);
  display.println("Your score");
  int16_t x1, y1;
  uint16_t textWidth, textHeight;
  char scoreBuffer[10];               // buffer for number as string
  sprintf(scoreBuffer, "%d", score);  // convert number to string
  display.getTextBounds(scoreBuffer, 0, 0, &x1, &y1, &textWidth, &textHeight);  // calculate text width for centering
  display.setCursor(64 - textWidth / 2, 36);
  display.println(scoreBuffer);
// ---- Show Highscore list ---- //
void renderHighscoreScreen() {
  display.setCursor(25, 2);
  display.println("HIGHSCORES");
  // current achieved score should blink if in Top10, blink status changes every 100ms
  if (millis() - lastBlinkTime > 100) {
    showBlink = !showBlink;
    lastBlinkTime = millis();
  for (int i = 0; i < 5; i++) {
    if (i == newHighscoreIndex && !showBlink) {
      continue;
    display.setCursor(30, 14 + (i * 9));
    display.print(i + 1);
    display.print(".    ");
    display.print(highscores[i]);
  display.display();
// ---- Save highscores ---- //
void saveHighscores(int newScore) {
    if (newScore > highscores[i]) {
      for (int j = 4; j > i; j--) {
        highscores[j] = highscores[j - 1];
      highscores[i] = newScore;
      newHighscoreIndex = i;
      break;
