Mini Piano
👉 Need faster updates or support? Click [here] join our Facebook community
👉 Or join our WhatsApp group: Click [here]
🎁 Looking for parts?Check out our all-in-one kits below — packed with components, beginner-friendly guides, and tons of fun.
Includes Arduino board |
PURCHASE LINK |
Electronic Kit |
Elite Explorer Kit |
Arduino Uno R4 WiFi |
3 in 1 Ultimate Starter Kit |
Arduino Uno R4 Minima |
Course Introduction
In this lesson, you’ll learn how to create a mini piano using LEDs, buttons, and a passive buzzer with Arduino.
Pressing different buttons will light up the corresponding LED and play the matching pitch on the buzzer.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R4 Minima |
USB Type-C cable |
Breadboard |
Wires |
Several |
1kΩ resistor |
Several |
Button |
7 |
LED |
Several |
8 |
Passive buzzer |
Common Connections:
LED
Connect the LEDs cathode to a 1kΩ resistor then to the negative power bus on the breadboard, and the LEDs anode to 10, 8, 6, 4, 2 on the Arduino.
Button
Connect to the LED’s cathode on the breadboard, then connect a 1kΩ resistor from the LED’s negative terminal to the negative power bus on the breadboard.
Connect to 11, 9, 7, 5, 3, 1 on the Arduino.
Passive Buzzer
+: Connect to 12 on the Arduino.
-: Connect to breadboard’s negative power bus.
Writing the Code
Before you begin, you need to upload the pitches.h library to your Arduino. Copy the contents of the library into the Arduino IDE, save it as pitches.h and then upload it to your Arduino.
* Public Constants
#define NOTE_B0 31
#define NOTE_C1 33
#define NOTE_CS1 35
#define NOTE_D1 37
#define NOTE_DS1 39
#define NOTE_E1 41
#define NOTE_F1 44
#define NOTE_FS1 46
#define NOTE_G1 49
#define NOTE_GS1 52
#define NOTE_A1 55
#define NOTE_AS1 58
#define NOTE_B1 62
#define NOTE_C2 65
#define NOTE_CS2 69
#define NOTE_D2 73
#define NOTE_DS2 78
#define NOTE_E2 82
#define NOTE_F2 87
#define NOTE_FS2 93
#define NOTE_G2 98
#define NOTE_GS2 104
#define NOTE_A2 110
#define NOTE_AS2 117
#define NOTE_B2 123
#define NOTE_C3 131
#define NOTE_CS3 139
#define NOTE_D3 147
#define NOTE_DS3 156
#define NOTE_E3 165
#define NOTE_F3 175
#define NOTE_FS3 185
#define NOTE_G3 196
#define NOTE_GS3 208
#define NOTE_A3 220
#define NOTE_AS3 233
#define NOTE_B3 247
#define NOTE_C4 262
#define NOTE_CS4 277
#define NOTE_D4 294
#define NOTE_DS4 311
#define NOTE_E4 330
#define NOTE_F4 349
#define NOTE_FS4 370
#define NOTE_G4 392
#define NOTE_GS4 415
#define NOTE_A4 440
#define NOTE_AS4 466
#define NOTE_B4 494
#define NOTE_C5 523
#define NOTE_CS5 554
#define NOTE_D5 587
#define NOTE_DS5 622
#define NOTE_E5 659
#define NOTE_F5 698
#define NOTE_FS5 740
#define NOTE_G5 784
#define NOTE_GS5 831
#define NOTE_A5 880
#define NOTE_AS5 932
#define NOTE_B5 988
#define NOTE_C6 1047
#define NOTE_CS6 1109
#define NOTE_D6 1175
#define NOTE_DS6 1245
#define NOTE_E6 1319
#define NOTE_F6 1397
#define NOTE_FS6 1480
#define NOTE_G6 1568
#define NOTE_GS6 1661
#define NOTE_A6 1760
#define NOTE_AS6 1865
#define NOTE_B6 1976
#define NOTE_C7 2093
#define NOTE_CS7 2217
#define NOTE_D7 2349
#define NOTE_DS7 2489
#define NOTE_E7 2637
#define NOTE_F7 2794
#define NOTE_FS7 2960
#define NOTE_G7 3136
#define NOTE_GS7 3322
#define NOTE_A7 3520
#define NOTE_AS7 3729
#define NOTE_B7 3951
#define NOTE_C8 4186
#define NOTE_CS8 4435
#define NOTE_D8 4699
#define NOTE_DS8 4978
Don’t forget to select the board(Arduino UNO R4 Minima) and the correct port before clicking the Upload button.
#include "pitches.h"
// LED pin numbers (C, D, E, F, G, A)
const int ledPins[6] = {0, 2, 4, 6, 8, 10};
// Button pin numbers (C, D, E, F, G, A)
const int buttonPins[6] = {1, 3, 5, 7, 9, 11};
// Passive buzzer pin
const int buzzerPin = 12;
// Note frequencies (C4 to A4)
const int noteFrequencies[6] = {
NOTE_C4, NOTE_D4, NOTE_E4,
NOTE_F4, NOTE_G4, NOTE_A4
// Length of each note in milliseconds
const int noteDuration = 250;
// Pause time between notes
const int pauseDuration = 30;
// Set LED pins as outputs
for (int i = 0; i < 6; i++) {
pinMode(ledPins[i], OUTPUT);
// Set button pins as inputs with internal pull-up resistors
pinMode(buttonPins[i], INPUT_PULLUP);
pinMode(buzzerPin, OUTPUT);
// Check each button
// Button is pressed when the pin reads LOW
if (digitalRead(buttonPins[i]) == LOW) {
playNote(i);
delay(150); // Simple debounce delay
// Play a note and flash the matching LED
void playNote(int index) {
tone(buzzerPin, noteFrequencies[index], noteDuration);
digitalWrite(ledPins[index], HIGH); // Turn on LED
delay(noteDuration); // Wait for note to finish
digitalWrite(ledPins[index], LOW); // Turn off LED
noTone(buzzerPin); // Stop sound
delay(pauseDuration); // Short pause between notes
