Height Measurement
Kit purchase
Includes Arduino board |
PURCHASE LINK |
Ultimate Sensor Kit |
Arduino Uno R4 Minima |
Elite Explorer Kit |
Arduino Uno R4 WiFi |
3 in 1 Ultimate Starter Kit |
Universal Maker Sensor Kit |
Course Introduction
This project uses an ultrasonic sensor, an Arduino, and a TM1637 7‑segment display to measure object height.
A button triggers the measurement, calculating height based on the fixed sensor position. The result is shown on the 7‑segment display with 0.1 cm accuracy, and detailed distance and height data are also sent to the serial monitor.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R4 Minima |
USB Type-C cable |
Breadboard |
Wires |
Several |
Ultrasonic Sensor Module |
Button |
7 |
4-Digit Segment Display Module |
Common Connections:
CLK: Connect to 3 on the Arduino.
DIO: Connect to 2 on the Arduino.
Button
Connect to 4 on the Arduino.
Trig: Connect to 9 on the Arduino.
Echo: Connect to 10 on the Arduino.
Writing the Code
To install the library, use the Arduino Library Manager and search for TM1637Display and install it.
Don’t forget to select the board(Arduino UNO R4 Minima/WIFI) and the correct port before clicking the Upload button.
#include <TM1637Display.h>
#define TRIG_PIN 9
#define ECHO_PIN 10
#define CLK 2
#define DIO 3
#define BUTTON_PIN 4
TM1637Display display(CLK, DIO);
const int sensorHeight = 15; // Fixed sensor height (cm)
bool buttonState = HIGH; // Current button state
bool lastButtonState = HIGH; // Previous button state
unsigned long debounceDelay = 50; // Debounce time
unsigned long lastDebounceTime = 0;
Serial.begin(9600);
pinMode(TRIG_PIN, OUTPUT);
pinMode(ECHO_PIN, INPUT);
pinMode(BUTTON_PIN, INPUT_PULLUP); // Button with pull-up input
display.setBrightness(0x0f);
display.showNumberDec(0, true); // Initial display 0000
int reading = digitalRead(BUTTON_PIN);
// Button state change detection (debounce)
if (reading != lastButtonState) {
lastDebounceTime = millis();
if ((millis() - lastDebounceTime) > debounceDelay) {
if (reading != buttonState) {
buttonState = reading;
// Button press detected
if (buttonState == LOW) {
measureHeight();
lastButtonState = reading;
void measureHeight() {
// Trigger ultrasonic pulse
digitalWrite(TRIG_PIN, LOW);
delayMicroseconds(2);
digitalWrite(TRIG_PIN, HIGH);
delayMicroseconds(10);
// Receive echo
long duration = pulseIn(ECHO_PIN, HIGH);
float distance = duration * 0.0343 / 2.0;
float height = sensorHeight - distance;
if (height < 0) height = 0;
Serial.print("Distance: ");
Serial.print(distance);
Serial.print(" cm, Height: ");
Serial.print(height);
Serial.println(" cm");
// Display on 7-segment display (accuracy 0.1cm)
int displayHeight = (int)(height * 10); // 12.3cm -> 123
display.showNumberDecEx(displayHeight, 0b01000000, false); // Show with decimal point
