Smart Coaster
Kit purchase
Includes Arduino board |
PURCHASE LINK |
Ultimate Sensor Kit |
Arduino Uno R4 Minima |
Universal Maker Sensor Kit |
Course Introduction
In this lesson, you’ll learn how to build a smart reminder coaster using an Arduino, an IR sensor, a TM1637 4-digit display, and a buzzer.
This experiment detects when a cup is placed, starts a 15-minute countdown, and triggers an alarm to remind you to drink water.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R4 Minima/Arduino UNO R4 WIFI |
USB Type-C cable |
Breadboard |
Wires |
Several |
4-Digit Segment Display Module |
IR Obstacle Avoidance Sensor Module |
7 |
Buzzer Modudle |
Common Connections:
OUT: Connect to 2 on the Arduino.
CLK: Connect to 9 on the Arduino.
DIO: Connect to 8 on the Arduino.
Buzzer Module
I/0: Connect to 3 on the Arduino.
+: Connect to breadboard’s red power bus.
-: Connect to breadboard’s negative power bus.
Writing the Code
To install the library, use the Arduino Library Manager and search for TM1637Display and install it.
Don’t forget to select the board(Arduino UNO R4 Minima/WIFI) and the correct port before clicking the Upload button.
#include <TM1637Display.h>
// ---------------------- Pin Definitions ----------------------
const int CLK_PIN = 9;
const int DIO_PIN = 8;
const int IR_PIN = 2;
const int BUZZER_PIN = 3;
// ---------------------- Display Object -----------------------
TM1637Display display(CLK_PIN, DIO_PIN);
// ---------------------- Timer Settings -----------------------
const unsigned long COUNTDOWN_TIME = 15UL * 60UL * 1000UL; // 15 minutes
const unsigned long LOST_DELAY = 1000; // ignore very short signal loss (1 second)
// ---------------------- State Variables ----------------------
bool cupPresent = false;
bool lastCupPresent = false;
bool timerRunning = false;
bool alarmActive = false;
unsigned long startTime = 0;
unsigned long remainingTime = COUNTDOWN_TIME;
unsigned long lostStartTime = 0;
bool lostTiming = false;
// ---------------------- Buzzer Settings ----------------------
unsigned long lastBeepToggle = 0;
bool beepState = false;
const unsigned long beepInterval = 300;
// ---------------------- IR Logic -----------------------------
// Most IR obstacle avoidance modules output LOW when an object is detected.
// If your module behaves the opposite way, change LOW to HIGH.
const int IR_ACTIVE_STATE = LOW;
// Show time in MM:SS format
void showTime(unsigned long timeMs) {
unsigned long totalSeconds = timeMs / 1000;
int minutes = totalSeconds / 60;
int seconds = totalSeconds % 60;
int displayValue = minutes * 100 + seconds;
display.showNumberDecEx(displayValue, 0b01000000, true); // show colon
void showIdleDisplay() {
display.showNumberDec(0, true); // 0000
void stopBuzzer() {
noTone(BUZZER_PIN);
beepState = false;
void handleAlarmBuzzer() {
unsigned long currentMillis = millis();
if (currentMillis - lastBeepToggle >= beepInterval) {
lastBeepToggle = currentMillis;
beepState = !beepState;
if (beepState) {
tone(BUZZER_PIN, 2000);
} else {
noTone(BUZZER_PIN);
void startNewCountdown() {
timerRunning = true;
startTime = millis();
stopBuzzer();
showTime(remainingTime);
void resetSystem() {
stopBuzzer();
showIdleDisplay();
pinMode(IR_PIN, INPUT);
pinMode(BUZZER_PIN, OUTPUT);
display.setBrightness(7);
showIdleDisplay();
int irState = digitalRead(IR_PIN);
bool currentDetected = (irState == IR_ACTIVE_STATE);
// ---------------- Cup detection with brief-loss tolerance ----------------
if (currentDetected) {
cupPresent = true;
lostTiming = false;
} else {
// Start timing only if cup was previously present
if (cupPresent && !lostTiming) {
lostTiming = true;
lostStartTime = millis();
// If object is gone long enough, treat as removed
if (cupPresent && lostTiming && (millis() - lostStartTime >= LOST_DELAY)) {
cupPresent = false;
lostTiming = false;
// ---------------- Cup placed ----------------
if (cupPresent && !lastCupPresent) {
startNewCountdown();
// ---------------- Cup removed ----------------
if (!cupPresent && lastCupPresent) {
resetSystem();
// ---------------- Countdown ----------------
if (cupPresent && timerRunning && !alarmActive) {
unsigned long elapsed = millis() - startTime;
if (elapsed >= COUNTDOWN_TIME) {
remainingTime = 0;
alarmActive = true;
showTime(0);
} else {
remainingTime = COUNTDOWN_TIME - elapsed;
// ---------------- Alarm ----------------
if (cupPresent && alarmActive) {
showTime(0);
handleAlarmBuzzer();
lastCupPresent = cupPresent;
